- Introdução
- Compreensão do UiPath Robot
- UiPath Assistant
- Requisitos de instalação
- Installing robots for unattended automations
- Configuring robots for unattended automations
- Connecting robots for unattended automations to Orchestrator
- Configurar o Windows Server para robôs de alta densidade
- Redirecionando Robôs por meio de um Servidor de Proxy
- Implementing authentication
- Adjusting registry settings for execution in minimized RDP windows
- Using network locations
- Configuração de robôs do Linux
- Configurando a Verificação de Assinatura de Pacote
- Configuração de pastas de pacote e caminhos de rede
- Configuração de feeds de atividades
- Deploying unattended automations
- Installing robots for attended automations
- Configuring robots for attended automations
- Integrações
- Solução de problemas
Licenciamento de Robô
A licensing process most commonly starts with activating your Orchestrator license. Afterward, you license your Robot by connecting it to Orchestrator or from the Command Line, using the LicenseTool utility.
When your Robot is not connected to Orchestrator, you can activate the license with the help of the Command Prompt.
To execute attended automations, you need to allocate one or more user licenses to your robots.
For this, you need to have a robot account in Orchestrator. Once the user license is assigned to a specific username, that user can run one or more attended automations on the computer under their username.
The following user licenses are available for attended automations:
Assistido
Citizen Developer
Automation Developer
To execute unattended automations, you need to allocate one or more robot licenses (or runtimes) to your robots, specifically to the machine that hosts your robots. The number of runtimes assigned to a machine represents the execution capacity. For example, with one runtime, you can execute only one unattended automation at a time. With five runtimes, you can execute up to five unattended automations at the same time, on the same host machine.
Depending on the type of automation, allocate the runtimes as follows:
For foreground automations - allocate one runtime, as this type of automations are executed one at a time.
For background automations - Windows machines require one runtime, as they execute one background automation at a time. Windows-Server machines can execute several background automations simultaneously, which represents a concurrent execution.
For concurrent executions - allocate more than one runtime. The number of allocated runtimes determines how many automations you can execute simultaneously on the same machine.
The following runtimes are available for unattended automations:
Unattended (Production)
Não Produtivo
Teste
UiPath.LicenseTool.exe
is a command-line utility which enables you to activate your machine online or offline, and update your license information.
The LicenseTool utility activates your license locally, which requires you to select the Standalone license type when creating a robot in Orchestrator.
The following sections provide the most common commands for online, offline, and generic licensing operations. The commands need to be initiated in the same folder where the utility resides, which be default is the "C:\Program Files\UiPath\Studio" folder.
Os seguintes comandos exigem uma conexão de internet ativa para processar sua solicitação.
Ativar
activate
é usado para ativar uma licença on-line, por meio de um código de licença existente. Os seguintes parâmetros são suportados:
Parâmetro |
Description |
Prioridade |
-l , --LicenseCode |
O código de licença necessário para a ativação. |
Obrigatório |
-u , --ProxyUrl |
The URL used for the proxy connection (such as
http://your.proxy.server.com ).
Opcional |
-p , --ProxyPort |
O número de Porta da conexão de proxy. |
Opcional. Obrigatório se o parâmetro
-u for usado.
-s , --ProxyUser |
O nome de usuário associado à sua conexão de proxy. |
-u for usado.
-w , --ProxyPassword |
A senha do usuário associado à sua conexão de proxy. |
-u for usado.
C:\Program Files\UiPath\Studio\UiPath.LicenseTool.exe activate -l 1234-1234-2194-5598
License registration state: ActiveLicense
License successfully activated!
A ativação online também pode ser feita no Studio.
Atualizar
update
é usado para atualizar uma licença existente on-line. Os seguintes parâmetros são suportados:
Parâmetro |
Description |
Prioridade |
-u , --ProxyUrl |
Opcional |
-p , --ProxyPort |
-u for usado.
-s , --ProxyUser |
-u for usado.
-u for usado.
C:\Program Files\UiPath\Studio\UiPath.LicenseTool.exe update
License successfully updated!
Desativar
deactivate
é usado para desativar uma licença local. Dessa forma, a licença fica disponível para ativação em outro computador. Os seguintes parâmetros são suportados:
Parâmetro |
Description |
Prioridade |
-u , --ProxyUrl |
Opcional |
-p , --ProxyPort |
-u for usado.
-s , --ProxyUser |
-u for usado.
-u for usado.
C:\Program Files\UiPath\Studio\UiPath.LicenseTool.exe deactivate
License registration state: NoLicenseAvailable
License successfully deactivated!
Solicitação de Ativação
activation-request
é usado para gerar um token de ativação, a partir do seu código de licença. O token gerado precisa ser usado no Portal de Ativação para gerar o arquivo de licença correspondente. Os seguintes parâmetros são suportados:
Parâmetro |
Description |
Prioridade |
Obrigatório |
o , --FileName |
Grave as informações de licença no arquivo. Se esse parâmetro não for especificado, a informação de licença é exibidas na janela de prompt de comando. |
Opcional |
C:\Program Files\UiPath\Studio\UiPath.LicenseTool.exe activation-request -l 1234-2303-2194-5598
Activation Token: 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
Go to https://activate.uipath.com and paste the activation token in the dialogue box to generate the license file for offline activation.
Ativar Offline
activate-offline
é usado para ativar uma licença offline. Ele usa o arquivo de licença gerado pelo Portal de Ativação, a partir do token de ativação fornecido gerado pelo comando activation-request
Parâmetro |
Description |
Prioridade |
-f , --LicenseFile |
O caminho para o arquivo de licença obtido a partir do portal de ativação. |
Obrigatório
1 |
-i , --LicenseContent |
O conteúdo do arquivo de licença recebido após usar a operação
Activation-Request .
Obrigatório
1 |
1
- Você pode usar apenas os parâmetros-f
ou-i
com a operaçãoactivate-offline
. Eles não são suportados ao mesmo tempo.C:\Program Files\UiPath\Studio\UiPath.LicenseTool.exe activate-offline -f c:\Downloads\license.txt License registration state: ActiveLicense License successfully activated!
A ativação offline também pode ser feita a partir do Studio.
Solicitação de Atualização
update-request
é usado para gerar um token de atualização para sua licença. O token de atualização precisa ser usado no Portal de Ativação, para gerar o arquivo de licença correspondente. Os seguintes parâmetros são suportados:
Parâmetro |
Description |
Prioridade |
-o , --FileName |
Opcional |
C:\Program Files\UiPath\Studio\UiPath.LicenseTool.exe update-request
Update Token: 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
Go to https://activate.uipath.com and paste the update token in the dialogue box to generate the license file for offline update.
Atualização Offline
update-offline
é usado para atualizar uma licença offline. Ele usa o arquivo gerado pelo Portal de Ativação, a partir do token de atualização fornecido, gerado pelo comando update-request
.Os seguintes parâmetros são suportados:
Parâmetro |
Description |
Prioridade |
Obrigatório
1 |
Update-Request .
Obrigatório
1 |
1
ou-i
com a operaçãoupdate-offline
. Eles não são suportados ao mesmo tempo.C:\Program Files\UiPath\Studio\UiPath.LicenseTool.exe update-offline -f c:\Downloads\license-update.txt License registration state: ActiveLicense License successfully updated!
Solicitação de Desativação
deactivation-request
é usado para desativar uma licença local offline e gerar um token de desativação. A licença é imediatamente desativada no computador local e outra pode ser ativada se necessário. O token de desativação gerado precisa ser usado no Portal de Ativação para desativar a licença. Observe que a licença que foi desativada offline com esse comando não pode ser reutilizada até que seja liberada. Os seguintes parâmetros são suportados:
Parâmetro |
Description |
Prioridade |
-o , --FileName |
Opcional |
C:\Program Files\UiPath\Studio\UiPath.LicenseTool.exe deactivation-request
Deactivation Token: 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
License successfully deactivated locally!
To release the license on the sever side and use it on another machine, go to https://activate.uipath.com and paste the deactivation request certificate as text in the <code>Deactivate your licence</code> tab.
também contém alguns comandos genéricos. Eles fornecem informações sobre sua licença e podem ajudar você a se acostumar aos comandos e parâmetros suportados.
Command |
Description |
Exibe informações sobre a licença, como:
Exibe informações sobre todos os comandos e parâmetros suportados. |
Exibe a versão do utilitário
UiPath.LicenseTool.exe .
