robot
- Introdução
- Compreensão do UiPath Robot
- UiPath Assistant
- Requisitos de instalação
- Installing robots for unattended automations
- Configuring robots for unattended automations
- Connecting robots for unattended automations to Orchestrator
- Configurar o Windows Server para robôs de alta densidade
- Redirecionando Robôs por meio de um Servidor de Proxy
- Implementing authentication
- Adjusting registry settings for execution in minimized RDP windows
- Using network locations
- Configuração de robôs do Linux
- Configurando a Verificação de Assinatura de Pacote
- Configuração de pastas de pacote e caminhos de rede
- Configuração de feeds de atividades
- Deploying unattended automations
- Installing robots for attended automations
- Configuring robots for attended automations
- Integrações
- Solução de problemas
Installing with Command Line Interface
Admin Guide
Last updated 21 de out de 2024
To install unattended robots using command line interface (CLI), mix the available command line parameters. For an unattended installation, it is required to add the
RegisterService
parameter to the ADDLOCAL
command.
Importante:
The following parameters are available for the
UiPathStudio.msi
command exclusively:
ADDLOCAL
:Studio
,ExcelAddin
,Packages
,SapPlugin
SAP_SOL_MAN_HOST
Consider the following examples for your use cases. Make sure to run the command in the folder where the installer is located.
UiPathRobot.msi ADDLOCAL=DesktopFeature,Robot,RegisterService,StartupLauncher,JavaBridge /Q
UiPathRobot.msi ADDLOCAL=DesktopFeature,Robot,RegisterService,LiveStreaming
UiPathRobot.msi ADDLOCAL=DesktopFeature,Robot,RegisterService,ChromeExtension CHROME_INSTALL_TYPE=POLICYONLINE /Q
UiPathRobot.msi ADDLOCAL=DesktopFeature,Robot,RegisterService CONNECTIONSTRING=https://demo.uipath.com/api/robotsservice/GetConnectionData?tenantId=1 /Q
UiPathRobot.msi ADDLOCAL=DesktopFeature,Robot,RegisterService CUSTOM_NUGET_FEEDS="Feed Name1,https://my.custom.nuget.feed; FeedName2,D:\RPA\Activities\Packages\" /Q
UiPathRobot.msi ADDLOCAL=DesktopFeature,Robot,RegisterService,CODE=1234567890 /Q
UiPathRobot.msi ADDLOCAL=DesktopFeature,Robot,RegisterService NUGET_OPTIONS=DisableOnlineFeeds
UiPathRobot.msi REMOVE=ChromeExtension /Q
UiPathRobot.msi ADDLOCAL=DesktopFeature,Robot,RegisterService ORCHESTRATOR_URL="https://demo.uipath.com/myorg/mytenant/orchestrator_"
UiPathStudio.msi ADDLOCAL=DesktopFeature,Studio,Robot,RegisterService,Packages
You can replace
UiPathStudio.msi
with UiPathRobot.msi
UiPathStudio.msi ADDLOCAL=DesktopFeature,Robot,RegisterService NUGET_OPTIONS=DisableOnlineFeeds
UiPathStudio.msi ADDLOCAL=DesktopFeature,Robot,RegisterService,Packages,LiveStreaming
UiPathStudio.msi ADDLOCAL=DesktopFeature,Studio,Robot,RegisterService,Packages,StartupLauncher,JavaBridge /Q
UiPathStudio.msi ADDLOCAL=DesktopFeature,Studio,Robot,RegisterService,Packages,ChromeExtension CHROME_INSTALL_TYPE=POLICYONLINE /Q
Silent mode - Installing Studio, the Robot in Service Mode, and the activities packages, in a custom "D:\UiPath" folder
UiPathStudio.msi ADDLOCAL=DesktopFeature,Studio,Robot,RegisterService,Packages APPLICATIONFOLDER=D:\UiPath /Q
UiPathStudio.msi ADDLOCAL=DesktopFeature,Studio,Robot,RegisterService CUSTOM_NUGET_FEEDS="Feed Name1,https://my.custom.nuget.feed; FeedName2,D:\RPA\Activities\Packages\" /Q
You can replace
UiPathStudio.msi
.UiPathStudio.msi ADDLOCAL=DesktopFeature,Robot,RegisterService CONNECTIONSTRING=https://demo.uipath.com/api/robotsservice/GetConnectionData?tenantId=1 /Q
Silent mode - Installing and licensing Studio, the Robot in Service Mode, and the local activity feed
UiPathStudio.msi ADDLOCAL=DesktopFeature,Studio,Robot,RegisterService,Packages CODE=1234567890 /Q
You can replace
UiPathStudio.msi
.UiPathStudio.msi REMOVE=ChromeExtension /Q
You can replace
UiPathStudio.msi
.UiPathStudio.msi ADDLOCAL=DesktopFeature,Robot,RegisterService ORCHESTRATOR_URL="https://demo.uipath.com/myorg/mytenant/orchestrator_"
- UiPathRobot.msi - command prompt examples
- Silent mode - Installing the Robot in Service Mode
- Installing the live streaming feature for Robot versions 2024.10+
- Silent mode - Installing the Robot in Service Mode and the Chrome Extension using an online policy
- Silent mode - Installing the Robot in Service Mode and connect it to Orchestrator
- Silent mode - Installing the Robot in Service Mode, and add two custom activity feeds
- Silent mode - Installing and licensing the Robot in Service Mode, and the local activity feed
- Installing the Robot in Service Mode, and disabling the official online feeds
- Silent mode - Uninstalling the Chrome Extension
- Setting up the auto-update connection
- UiPathStudio.msi - command prompt examples
- Installing the Robot in Service Mode, and disable the official online feeds
- Silent mode - Installing the Desktop suite
- Silent mode - Installing the Desktop suite and the Chrome Extension using an online policy
- Silent mode - Installing Studio, the Robot in Service Mode, and the activities packages, in a custom "D:\UiPath" folder
- Silent mode - Installing Studio, the Robot in Service Mode, and add two custom activity feeds
- Silent mode - Installing and licensing Studio, the Robot in Service Mode, and the local activity feed
