- Introdução
- Compreensão do UiPath Robot
- UiPath Assistant
- Requisitos de instalação
- Installing robots for unattended automations
- Configuring robots for unattended automations
- Connecting robots for unattended automations to Orchestrator
- Configurar o Windows Server para robôs de alta densidade
- Redirecionando Robôs por meio de um Servidor de Proxy
- Implementing authentication
- Adjusting registry settings for execution in minimized RDP windows
- Using network locations
- Configuração de robôs do Linux
- Configurando a Verificação de Assinatura de Pacote
- Configuração de pastas de pacote e caminhos de rede
- Configuração de feeds de atividades
- Deploying unattended automations
- Installing robots for attended automations
- Configuring robots for attended automations
- Integrações
- Solução de problemas
Licensing robots for unattended automations
To execute unattended automations, you need to allocate one or more robot licenses (or runtimes) to your robots, specifically to the machine that hosts your robots. The number of runtimes assigned to a machine represents the execution capacity. For example, with one runtime, you can execute only one unattended automation at a time. With five runtimes, you can execute up to five unattended automations at the same time, on the same host machine.
The following runtimes are available for unattended automations:
Unattended (Production)
Não Produtivo
Teste
To license a robot for unattended automations, first upload and activate a license in Orchestrator, then connect the robot to that Orchestrator instance.
To connect a robot to Orchestrator, you need to know the client credentials (client ID and secret) generated by the machine object in Orchestrator.
In the Assistant, use the Client ID connection type, and provide the client credentials.
In the Command Line Interface, use the
--connect
command, and provide the client credentials.
activate
command in the Command Prompt. The license activation can be done offline and online.
Check out the LicenseTool utility for more commands and parameters.
UiPath.LicenseTool.exe
is found, and 1234-5678-9010-1112
is the license string.
C:\Program Files\UiPath\Studio\UiPath.LicenseTool.exe activate -l 1234-5678-9010-1112
is found, and c:\Downloads\license.txt
is the path to the license file.
C:\Program Files\UiPath\Studio\UiPath.LicenseTool.exe activate-offline -f c:\Downloads\license.txt
