robot
- Introdução
- Compreensão do UiPath Robot
- UiPath Assistant
- Requisitos de instalação
- Installing robots for unattended automations
- Configuring robots for unattended automations
- Connecting robots for unattended automations to Orchestrator
- Configurar o Windows Server para robôs de alta densidade
- Redirecionando Robôs por meio de um Servidor de Proxy
- Implementing authentication
- Adjusting registry settings for execution in minimized RDP windows
- Using network locations
- Configuração de robôs do Linux
- Configurando a Verificação de Assinatura de Pacote
- Configuração de pastas de pacote e caminhos de rede
- Configuração de feeds de atividades
- Deploying unattended automations
- Installing robots for attended automations
- Configuring robots for attended automations
- Integrações
- Solução de problemas
Licensing robots for attended automations
Admin Guide
Last updated 21 de out de 2024
To execute attended automations, you need to allocate one or more user licenses to your robots.
The following user licenses are available for attended automations:
Assistido
Citizen Developer
Automation Developer
To license a robot for attended automations, first upload and activate a license in Orchestrator, then connect the robot to that Orchestrator instance.
To connect a robot to Orchestrator:
In the Assistant, use the Client ID connection type, and provide the client credentials.
In the Command Line Interface, use the
--connect
command, and provide the client credentials.
To license a robot without connecting it to Orchestrator, use the License Tool
activate
command in the Command Prompt. The license activation can be done offline and online.
Check out the LicenseTool utility for more commands and parameters.
Run the following command in the same directory where the
UiPath.LicenseTool.exe
is found, and 1234-5678-9010-1112
is the license string.
C:\Program Files\UiPath\Studio\UiPath.LicenseTool.exe activate -l 1234-5678-9010-1112
is found, and c:\Downloads\license.txt
is the path to the license file.
C:\Program Files\UiPath\Studio\UiPath.LicenseTool.exe activate-offline -f c:\Downloads\license.txt
