Configuring input.json
The input.json file allows you to configure the UiPath® products you want to deploy, the parameters, settings, and preferences applied to the selected products, and the settings of your cloud infrastructure. You must update this file to change the defaults and use any advanced configuration for your cluster.
Note:
Some products may have dependencies. For details, refer to Automation Suite products.
To edit input.json, you can use your favorite text editor on your client machine.
General parametersDescription
kubernetes_distributionSpecify which Kubernetes distribution you use. Can be aks or eks.
install_typeDetermines whether the cluster is deployed in online or offline mode. If not specified, the cluster is deployed in online mode. To deploy the cluster in offline mode, you must explicitly set the value of the install_type parameter to offline.
Possible values: online or offline
Default value: online
registriesURLs to pull the docker images and helm charts for UiPath® products and Automation Suite.
registry.uipath.com
fqdnThe load balancer endpoint for Automation Suite
admin_usernameThe username that you would like to set as an admin for the host organization.
admin_passwordThe host admin password to be set.
profileDefault value, not changeable:
- ha: multi-node HA-ready production profile.
telemetry_optouttrue or false - used to opt out of sending telemetry back to UiPath®. It is set to false by default. If you want to opt out, then set to true.
fips_enabled_nodesIndicate whether you want to enable FIPS 140-2 on the nodes on which you plan to install Automation Suite on AKS. Possible values are true and false.
"kubernetes_distribution": "aks",
  "registries": {
    "docker": {
      "url": "registry.uipath.com"
    "helm": {
  "fqdn": "replace with your fqdn",
  "admin_username": "replace with your UiPath® admin username",
  "admin_password": "replace with your UiPath® admin password",
  "profile": "ha",
  "telemetry_optout": false,
  "fips_enabled_nodes": true
  "registries": {
    "docker": {
    "helm": {
  "profile": "ha",
UiPath® products
You can enable and disable products in Automation Suite at the time of installation and at any point post-installation. For more details on each product configuration, refer to Managing products.
Note:
Depending on your product selection, some configurations might not be available. For example, Insights and Task Mining do not currently support Microsoft Entra ID (formerly Azure Active Directory) authentication configuration for access to SQL, storage, and other resources that support Microsoft Entra.
Orchestrator example:
"orchestrator": {
  "enabled": true,
  "external_object_storage": {
    "bucket_name": "uipath-as-orchestrator"
  "testautomation": {
    "enabled": true
  "updateserver": {
    "enabled": true
"orchestrator": {
  "enabled": true,
  "testautomation": {
    "enabled": true
  "updateserver": {
    "enabled": true
Bring your own components
Automation Suite allows you to bring your own Gatekeeper and OPA Policies, Cert Manager, Istio, monitoring, logging components, and more. If you choose to exclude these components, ensure that they are available in your cluster before installing Automation Suite.
The following sample shows a list of excluded components. You can remove the components you would like Automation Suite to provision.
   "exclude_components": [
        "alerts",
        "auth",
        "istio",
        "cert-manager",
        "logging",
        "monitoring",
        "gatekeeper",
        "network-policies",
        "velero",
        "sfcore"
        "alerts",
        "auth",
        "istio",
        "cert-manager",
        "logging",
        "monitoring",
        "gatekeeper",
        "network-policies",
        "velero",
        "sfcore"
Excluding sfcore
If you exclude the sfcore component, make sure you have public CA-issued certificates in input.json. For details, refer to Certificate configuration.
Excluding Istio
If you bring your own Istio component, make sure to include the gateway_selector labels from your Istio gateway in the input.json file. For more details, refer to AKS input.json example or EKS input.json example.
To find your gateway selector label, take the following steps:
  1. List all the pods in the istio-system namespace by running the kubectl get pods -n istio-system command.
  2. Find the one for your Istio gateway deployment.
Excluding Cert Manager
If you choose to bring your own Cert Manager, and your TLS certificate is issued by a private or non-public CA, you must manually include both the leaf certificate and intermediate CA certificates in the TLS certificate file. In case of public CAs, they are automatically trusted by client systems, and no further action is required on your part.
If no certificate is provided at the time of installation, the installer creates self-issued certificates and configures them in the cluster.
Note:
Make sure to specify the absolute path for the certificate files. Run pwd to get the path of the directory where files are placed and append the certificate file name to the input.json.
ParameterDescription
server_certificate.ca_cert_fileAbsolute path to the Certificate Authority (CA) certificate. This CA is the authority that signs the TLS certificate. A CA bundle must contain only the chain certificates used to sign the TLS certificate. The chain limit is nine certificates.
If you use a self-signed certificate, you must specify the path to rootCA.crt, which you previously created. Leave blank if you want the installer to generate it.
server_certificate.tls_cert_fileAbsolute path to the TLS certificate (server.crt is the self-signed certificate). Leave blank if you want the installer to generate it.
server_certificate.tls_key_fileAbsolute path to the certificate key (server.key is the self-signed certificate). Leave blank if you want the installer to generate it.
identity_certificate.token_signing_cert_fileAbsolute path to the identity token signing certificate used to sign tokens (identity.pfx is the self-signed certificate). Leave blank if you want the installer to generate an identity certificate using the server certificate.
identity_certificate.token_signing_cert_passPlain text password set when exporting the identity token signing certificate.
additional_ca_certsAbsolute path to the file containing the additional CA certificates that you want to be trusted by all the services running as part of Automation Suite. All certificates in the file must be in valid PEM format.
For example, you need to provide the file containing the SQL server CA certificate if the certificate is not issued by a public certificate authority.
Infrastructure prerequisites
You must provide configurations details of the prerequisites that you configured on Azure or AWS. For input.json parameter requirements, refer to the following prerequisite sections:
External Objectstore configuration
General configuration
Automation Suite allows you to bring your own external storage provider. You can choose from the following storage providers:
  • Azure
  • AWS
  • S3-compatible
You can configure the external object storage in one of the following ways:
  • during installation;
  • post-installation, using the input.json file.
Note:
  • For Automation Suite to function properly when using pre-signed URLs, you must make sure that your external objectstore is accessible from the Automation Suite cluster, browsers, and all your machines, including workstations and robot machines.
  • The Server Side Encryption with Key Management Service (SSE-KMS) can only be enabled on the Automation Suite buckets deployed in any region created after January 30, 2014.
    SSE-KMS functionality requires pure SignV4 APIs. Regions created before January 30, 2014 do not use pure SignV4 APIs due to backward compatibility with SignV2. Therefore, SSE-KMS is only functional in regions that use SignV4 for communication. To find out when the various regions were provisioned, refer to the AWS documentation.
If you use a Private Endpoint to access the container, you must add the fqdn parameter in the input.json file and specify the Private Endpoint as value.
The following table lists out the input.json parameters you can use to configure each provider of external object storage:
ParameterAzureAWSS3-compatibleDescription
external_object_storage.enabledSpecify whether you would like to bring your own object store.
Possible values: true and false.
external_object_storage.create_bucketSpecify whether you would like to provision the bucket.
external_object_storage.storage_typeSpecify the storage provider you would like to configure. The value is case-sensitive.
Possible values: azure and s3. Many S3 objectstores require the CORS set to all the traffic from the Automation Suite cluster. You must configure the CORS policy at the objectstore level to allow the FQDN of the cluster.
external_object_storage.fqdnSpecify the FQDN of the S3 server.
Required in the case of AWS instance and non-instance profile.
external_object_storage.portSpecify the S3 port.
external_object_storage.regionSpecify the AWS region where buckets are hosted.
external_object_storage.access_keySpecify the access key for the S3 account.
Required in the case of the AWS non-instance profile.
external_object_storage.secret_keySpecify the secret key for the S3 account.
external_object_storage.use_instance_profileSpecify whether you want to use an instance profile. An AWS Identity and Access Management (IAM) instance profile grants secure access to AWS resources for applications or services running on Amazon Elastic Compute Cloud (EC2) instances. If you opt for AWS S3, an instance profile allows an EC2 instance to interact with S3 buckets without the need for explicit AWS credentials (such as access keys) to be stored on the instance.
external_object_storage.bucket_name_prefix1Indicate the prefix for the bucket names.
Optional in the case of the AWS non-instance profile.
external_object_storage.bucket_name_suffix2Indicate the suffix for the bucket names.
external_object_storage.account_keySpecify the Azure account key.
external_object_storage.account_nameSpecify the Azure account name.
external_object_storage.azure_fqdn_suffixSpecify the Azure FQDN suffix.
Optional parameter.
1 If you plan on disabling pre-signed URL access, note that this configuration is not supported by Task Mining and the following activities that upload or retrieve data from the objectstore:
2, 3 When configuring the external object storage, you must follow the naming rules and conventions from your provider for both bucket_name_prefix and bucket_name_suffix. In addition to that, the suffix and prefix must have a combined length of no more than 25 characters, and you must not end the prefix or start the suffix with a hyphen (-) as we already add the character for you automatically.
To ensure secure and compatible communication with Automation Suite, your S3-compatible objectstore must support one or more of the following secure TLS cipher suites:
  • TLS 1.3:
    • TLS_AES_128_GCM_SHA256
    • TLS_AES_256_GCM_SHA384
    • TLS_CHACHA20_POLY1305_SHA256
  • TLS 1.2:
    • TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA
    • TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA
    • TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA
    • TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA
    • TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256
    • TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384
    • TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256
    • TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384
    • TLS_ECDHE_RSA_WITH_CHACHA20_POLY1305_SHA256
    • TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305_SHA256
Note:
The list of supported cipher suites may evolve over time to align with security best practices and updates in the Go cryptographic library. For the up-to-date list, refer to the Go documentation.
Product-specific configuration
You can use the parameters described in the General configuration section to update the general Automation Suite configuration. This means that all installed products would share the same configuration.
If you want to configure one or more products differently, you can override the general configuration. You just need to specify the product(s) you want to set up external object storage for differently, and use the same parameters to define your configuration. Note that all the other installed products would continue to inherit the general configuration.
The following example shows how you can override the general configuration for Orchestrator:
  "enabled": false, // <true/false>
  "create_bucket": true, // <true/false>
  "storage_type": "s3", // <s3,azure,aws>
  "fqdn": "",  // <needed in the case of aws instance and non-instance profile>
  "port": 443, // <needed in the case of aws instance and non-instance profile>
  "region": "",
  "access_key": "", // <needed in the case of aws non instance profile>
  "secret_key": "", // <needed in the case of aws non instance profile>
  "bucket_name_prefix": "",
  "bucket_name_suffix": "",
  "account_key": "",
  "account_name": "",
  "azure_fqdn_suffix": "core.windows.net",
"orchestrator": {
    "storage_type": "s3", // <s3,azure>
    "region": "",
    "access_key": "", // <needed in case of aws non instance profile>
    "secret_key": "", // <needed in case of aws non instance profile>
    "account_key": "",
    "account_name": "",
  "region": "",
  "account_key": "",
  "account_name": "",
"orchestrator": {
    "region": "",
    "account_key": "",
    "account_name": "",
Rotating the blob storage credentials for Process Mining
To rotate the blob storage credentials for Process Mining in Automation Suite the stored secrets must be updated with the new credentials. Refer to Rotating blob storage credentials.
Pre-signed URL configuration
You can use the disable_presigned_url flag to specify whether you would like to disable pre-signed URL access at global level. By default, pre-signed URLs are enabled for the entire platform. The possible values are: true and false.
  "disable_presigned_url" : true
Note:
  • You can only change the default value of this parameter only for new installations. The operation is irreversible and does not apply to an existing cluster.
  • You can apply this configuration only to the entire platform. You cannot override the global configuration at product level.
External OCI-compliant registry configuration
To configure an external OCI-compliant registry, update the following parameters in the input.json file:
KeysValue
registries.docker.urlDefault value: registry.uipath.com The URL or FQDN of the registry to be used by Automation Suite to host the container images.
registries.docker.username registries.docker.passwordAuthentication information to be used for pulling the Docker images from the registry.
If one of the values is found in the input file, you must provide both of them when configuring the external registry.
registries.docker.pull_secret_valueThe registry pull secret.
registries.helm.urlDefault value: registry.uipath.com The URL or FQDN of the registry to be used by Automation Suite to host the Helm chart of the service.
registries.helm.username registries.helm.passwordAuthentication information to be used for pulling Helm charts from the registry.
registry_ca_certThe location of the CA file corresponding to the certificate configured for the registry.
If the registry is signed by a private certificate authority hosted on your premises, you must provide it to establish the trust.
Note:
You can use different methods to generate the encoded version of the pull_secret_value, including the one using Docker.
The following configuration sample shows a typical OCI-compliant registry setup:
    "registries": {
        "docker": {
            "url": "registry.domain.io",
            "username": "username",
            "password": "password",
            "pull_secret_value": "pull-secret-value"
        "helm": {
        "trust": {
            "enabled": true,
            "public_key": "LS0tLS1CRUdJTiBQVUJMSUMgS0VZLS0tLS0KTUZrd0V3WUhLb1pJemowQ0FRWUlLb1pJemowREFRY0RRZ0FFNE4vSzNzK2VXUTJHU3NnTTJNcUhsdEplVHlqRQp1UC9sd0dNTnNNUjhUZTI2Ui9TTlVqSVpIdnJKcEx3YmpDc0ZlZUI3L0xZaFFsQzlRdUU1WFhITDZ3PT0KLS0tLS1FTkQgUFVCTElDIEtFWS0tLS0tCg==",
            "detection_mode": false
    "registry_ca_cert": "/etc/pki/ca-trust/extracted/ca-bundle.trust.crt"
    "registries": {
        "docker": {
        "helm": {
        "trust": {
            "enabled": true,
Note:
For registries such as Harbor, which require using a project, you must append the project name to the registry URL. The requirement applies to the registries.docker.url and registries.helm.url parameters in the input.json file, as shown in the following example:
"registries": {
"docker": {
"url": "registry.domain.io/myproject",
"helm": {
"trust": {
"enabled": true,
"registries": {
"docker": {
"helm": {
"trust": {
"enabled": true,
Custom namespace label configuration
If you want the UiPath namespaces to contain custom namespace labels, add the following section to the input.json file. Make sure to add your own labels.
 "namespace_labels": {
        "install-type": "aksoffline",
        "uipathctlversion": "rc-10_0.1",
        "updatedLabel": "rerun"
Custom node toleration configuration
If you need custom taints and tolerations on the nodes on which you plan to install Automation Suite, update input.json with the following flags. Make sure to provide the appropriate values to the spec field.
"tolerations": [
    "spec": {
      "key": "example-key",
      "operator": "Exists",
      "value": "optional-value",
      "effect": "NoSchedule"
    "spec": {
      "key": "example-key2",
      "value": "optional-value2",
"tolerations": [
    "spec": {
    "spec": {
Internal load balancer configuration
You can use an internal load balancer for your deployment in both AKS and EKS installation types. To do this, you must specify this in the ingress section of the input.json file.
The AKS internal load balancer configuration field details:
azure-load-balancer-internalSpecifies if the load balancer is internal.
The EKS internal load balancer configuration field details:
aws-load-balancer-backend-protocolSpecifies the backend protocol.
aws-load-balancer-nlb-target-typeSpecifies the target type to configure for NLB. You can choose between instance and ip.
aws-load-balancer-schemeSpecifies whether the NLB will be internet-facing or internal. Valid values are internal or internet-facing. If not specified, default is internal.
aws-load-balancer-typeSpecifies the load balancer type. This controller reconciles those service resources with this annotation set to either nlb or external.
aws-load-balancer-internalSpecifies whether the NLB will be internet-facing or internal.
AKS Example
 "ingress": {
    "service_annotations": {
      "service.beta.kubernetes.io/azure-load-balancer-internal": "true"
 "ingress": {
EKS Example
  "ingress": {
      "service.beta.kubernetes.io/aws-load-balancer-backend-protocol": "ssl",
      "service.beta.kubernetes.io/aws-load-balancer-nlb-target-type": "ip",
      "service.beta.kubernetes.io/aws-load-balancer-scheme": "internal",
      "service.beta.kubernetes.io/aws-load-balancer-type": "nlb",
      "service.beta.kubernetes.io/aws-load-balancer-internal": "true"
  "ingress": {
For details on creating internal load balancers in AKS and EKS, refer to the following links:
Orchestrator-specific configuration
Orchestrator can save robot logs to an Elasticsearch server. You can configure this functionality in the orchestrator.orchestrator_robot_logs_elastic section. If not provided, robot logs are saved to Orchestrator's database.
The following table lists out the orchestrator.orchestrator_robot_logs_elastic parameters:
orchestrator_robot_logs_elasticElasticsearch configuration.
elastic_uriThe address of the Elasticsearch instance that should be used. It should be provided in the form of a URI. If provided, then username and password are also required.
elastic_auth_usernameThe Elasticsearch username used for authentication.
elastic_auth_passwordThe Elasticsearch password, used for authentication.
Insights-specific configuration
If enabling Insights, users can include SMTP server configuration that will be used to send scheduled emails/alert emails. If not provided, scheduled emails and alert emails will not function.
You can use the uipathctl command-line tool to apply configuration changes. For details, refer to the uipathctl reference guide.
The insights.smtp_configuration fields details:
tls_versionValid values are TLSv1_2, TLSv1_1, SSLv23. Omit key altogether if not using TLS.
from_emailAddress that alert/scheduled emails will be sent from.
hostHostname of the SMTP server.
portPort of the SMTP server.
usernameUsername for SMTP server authentication.
passwordPassword for SMTP server authentication.
enable_realtime_monitoringFlag to enable Insights Real-time monitoring. Valid values are true, false. Default value is false.
Example
"insights": {
    "enabled": true,
    "enable_realtime_monitoring": true,
    "smtp_configuration": {
      "tls_version": "TLSv1_2",
      "from_email": "test@test.com",
      "host": "smtp.sendgrid.com",
      "port": 587,
      "username": "login",
      "password": "password123"
"insights": {
    "enabled": true,
      "port": 587,
Process Mining-specific configuration
If enabling Process Mining, we recommend users to specify a SECONDARY SQL server to act as a data warehouse that is separate from the primary Automation Suite SQL Server. The data warehouse SQL Server will be under heavy load and can be configured in the processmining section:
sql_connection_strDotNet formatted connection string with database set as a placeholder: Initial Catalog=DB_NAME_PLACEHOLDER.
sqlalchemy_pyodbc_sql_connection_str1Sqlalchemy PYODBC formatted connection string for custom airflow metadata database location: sqlServer:1433/DB_NAME_PLACEHOLDER.
warehouse.sql_connection_strDotNet formatted SQL connection string to the processmining data warehouse SQL Server with placeholder for dbname: Initial Catalog=DB_NAME_PLACEHOLDER.
warehouse.sqlalchemy_pyodbc_sql_connection_strSqlalchemy PYODBC formatted SQL connection string to the processmining data warehouse SQL Server with placeholder for dbname: sqlServer:1433/DB_NAME_PLACEHOLDER.
warehouse.master_sql_connection_strIf the installer is creating databases through sql.create_db: true setting, a DotNet formatted master SQL connection string must be provided for the processmining data warehouse SQL Server. Database in the connection string must be set as master.
1 Examples:
mssql+pyodbc://testadmin%40myhost:mypassword@myhost:1433/AutomationSuite_Airflow?driver=ODBC+Driver+17+for+SQL+Server&TrustServerCertificate=YES&Encrypt=YES
where user: testadmin%40myhost
If there is '@' in the username, it must be URL-encoded as %40.
Example (SQL Server with Kerberos authentication):
mssql+pyodbc://:@assql2019.autosuitead.local:1433/AutomationSuite_ProcessMining_Warehouse?driver=ODBC+Driver+17+for+SQL+Server&TrustServerCertificate=YES&Encrypt=YES&Trusted_Connection=yes
Sample Process Mining connection string
"processmining": {
    "enabled": true,
    "app_security_mode": "system_managed",
    "warehouse": {
        "sql_connection_str": "Server=tcp:sfdev4515230-sql.database.windows.net,1433;Initial Catalog=AutomationSuite_ProcessMining_Warehouse;User Id=testadmin@sfdev4515230-sql.database.windows.net;Password='password';Persist Security Info=False;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;",
        "sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://testadmin%40sfdev4515230-sql.database.windows.net:<password>:@sfdev4515230-sql.database.windows.net:1433/AutomationSuite_ProcessMining_Warehouse?driver=ODBC+Driver+17+for+SQL+Server&TrustServerCertificate=YES&Encrypt=YES",
        "master_sql_connection_str": "Server=tcp:sfdev4515230-sql.database.windows.net,1433;Initial Catalog=master;Persist Security Info=False;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;"
    "sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://testadmin%40sfdev4515230-sql.database.windows.net:<password>@sfdev4515230-sql.database.windows.net:1433/AutomationSuite_Airflow?driver=ODBC+Driver+17+for+SQL+Server&TrustServerCertificate=YES&Encrypt=YES"
    "sql_connection_str": "Server=tcp:sfdev4515230-sql.database.windows.net,1433;Initial Catalog=AutomationSuite_ProcessMining_Metadata;User Id=testadmin@sfdev4515230-sql.database.windows.net;Password='password';Persist Security Info=False;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;",
"processmining": {
    "enabled": true,
    "warehouse": {
When using Kerberos authentication, utilize the Integrated Security and Trusted_Connection parameters. By setting Integrated Security to true and setting Trusted_Connection to yes, the credentials of the currently logged in user are used for the connection. In this case, you do not need to specify a separate username and password.
When setting up Microsoft SQL Server, make sure that the timezone of the SQL Server machine where the Airflow database is installed is set to UTC.
Important:
You must use the default server port 1433 for Airflow database connections. Non-standard SQL server ports are not supported.
Note:
When configuring the connection strings for the processmining data warehouse SQL Server, the named instance of the SQL Server should be omitted.
Named instances of SQL Server cannot operate on the same TCP port. Therefore, the port number alone is sufficient to distinguish between instances.
For example, use tcp:server,1445 instead of tcp:server\namedinstance,1445.
The names for the template PYODBC connection string sql_connection_string_template_sqlalchemy_pyodbc and the PYODBC connection string sqlalchemy_pyodbc_sql_connection_str used when you bring your own database are different. Connection string names are also different for the template SQL sql_connection_string_template and sql_connection_str used when you bring your own database.
If you bring your own database and configured it using the sql_connection_str and sqlalchemy_pyodbc_sql_connection_str connection strings in the processmining section of the input.json file, the template connection strings sql_connection_string_template and sql_connection_string_template_sqlalchemy_pyodbc are ignored if specified.
Automation Suite Robots-specific configuration
Automation Suite Robots can use package caching to optimize your process runs and allow them to run faster. NuGet packages are fetched from the filesystem instead of being downloaded from the Internet/network. This requires an additional space of minimum 10GB and should be allocated to a folder on the host machine filesystem of the dedicated nodes.
To enable package caching, you need to update the following input.json parameters:
ParameterDefault valueDescription
packagecachingtrueWhen set to true, robots use a local cache for package resolution.
packagecachefolder/uipath_asrobots_package_cacheThe disk location on the serverless agent node where the packages are stored.
AI Center-specific configuration
This section only applies to S3 endpoints (not needed for Azure Storage).
For AI Center to function properly, you must configure the aicenter.external_object_storage.port and aicenter.external_object_storage.fqdn parameters in the input.json file.
Note:
You must configure the parameters in the aicenter section of the input.json file even if you have configured the external_object_storage section of the file.
The following sample shows a valid input.json configuration for AI Center:
"aicenter": {
  "external_object_storage" {
    "port": 443,
    "fqdn": "s3.us-west-2.amazonaws.com"
  "enabled": true,
  "create_bucket": false,
  "region": "us-west-2",
  "use_instance_profile": true
"aicenter": {
    "port": 443,
  "enabled": true,
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
