Automation Suite
- Overview
- Requirements
- Prerequisite checks
- uipathctl cluster
- uipathctl cluster migration
- uipathctl cluster upgrade
- uipathctl config
- uipathctl config alerts
- uipathctl config argocd
- uipathctl health
- uipathctl health bundle
- uipathctl health check
- uipathctl health diagnose
- uipathctl health test
- uipathctl manifest
- uipathctl manifest apply
- uipathctl manifest diff
- uipathctl manifest get
- uipathctl manifest render
- uipathctl prereq
- uipathctl prereq create
- uipathctl prereq run
- uipathctl resource
- uipathctl resource report
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- uipathctl version
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Monitoring and alerting
- Cluster administration
- Troubleshooting
Automation Suite on EKS/AKS Installation Guide
Last updated Apr 19, 2024
The following command executes the cluster migration from a source cluster to a target cluster.
There are two stages of the migration process:
Kubernetes objects are migrated from the source cluster, followed by the installation on the target cluster.
The input and version files are used to configure the migration process.
uipathctl cluster migration run [PATH] [flags]
# Migrate from source cluster to target cluster, using input.json as the target cluster configuration
uipathctl cluster migration run input.json --versions versions.json --target-kubeconfig <path> --target-kubecontext <context>
-h, --help help for run
--skip-outbound-data skip outbound data migration
--skip-pre-reqs skip prerequisite checks for data migration
--target-context string name of kubeconfig context to use for target cluster
--target-kubeconfig string target cluster kubectl configuration file
--versions string path to versions file
