Managing the certificates
Certificate management overview for Automation Suite on EKS/AKS, including replacing self-signed certificates after installation.
Important:
The installation process generates self-signed certificates on your behalf. You should replace them with certificates signed by a trusted Certificate Authority (CA) as soon as installation completes.
You can use the uipathctl CLI tool to update certificates post-installation. For details, refer to uipathctl documentation.
Generating a Certificate Signing Request (CSR) and a private key​
To generate the CSR and the private key, run the following command:
# copy the machine openssl configuration locally
cp /etc/pki/tls/openssl.cnf ./openssl.tmp.cnf
# Replace the [AUTOMATION_SUITE_FQDN] value. For example, "automationsuite.corp.com"
AS_FQDN=[AUTOMATION_SUITE_FQDN]
cat >> ./openssl.tmp.cnf <<EOF
[SAN]
subjectAltName=DNS:$AS_FQDN,DNS:alm.$AS_FQDN,DNS:monitoring.$AS_FQDN,DNS:registry.$AS_FQDN,DNS:objectstore.$AS_FQDN,DNS:insights.$AS_FQDN
EOF
# create the certificate request
openssl req -new -sha256 -newkey rsa:2048 -nodes -keyout server.key -subj "/C=xx/ST=xx/O=xx/OU=xx/CN=$AS_FQDN" -reqexts SAN -config openssl.tmp.cnf -out ${AS_FQDN}.csr
[SAN]
EOF
Your IT team uses the obtained values to generate a signed certificate. The generated private key remains local.
Managing the TLS certificate​
To view more information about updating the TLS certificates, run the following command:
uipathctl config update-tls-certificates --help
Output:
Manage tls certificates
Usage:
  uipathctl config tls-certificates [flags]
  uipathctl config tls-certificates [command]
Available Commands:
  get         Get the current tls certificates
  update      Update tls certificates
Flags:
  -h, --help   help for tls-certificates
Global Flags:
Usage:
Available Commands:
Flags:
Global Flags:
Finding the TLS certificates​
Certificates are stored as a secret at Istio level. You can find certificates under the istio-ingressgateway-certs name in the istio-system namespace.
See the certificate files in the following list:
  • Server TLS certificate is stored as tls.crt
  • Server TLS private key as tls.key
  • CA bundle is stored as ca.crt
You can verify the secrets using the following command:
kubectl -n istio-system get secrets istio-ingressgateway-certs -o yaml
Certificates are also stored in the UiPath namespace. This is applicable to every UiPath® product that needs certificate information to trust incoming calls. For details, refer to Understanding the container architecture related to certificates.
Updating the TLS certificates​
Important:
You must decrypt the certificate key before updating the server certificate. Skipping the decryption step would result in an error.
To decrypt the certificate key, run the following command:
# replace /path/to/encrypted/cert/key to absolute file path of key
# replace /path/to/decrypt/cert/key to store decrypt key
# Once prompted, please entry the passphrase or password to decrypt the key
openssl rsa -in /path/to/encrypted/cert/key -out /path/to/decrypt/cert/key
To update the certificate, run the following uipathctl command. You need the path to each of the three certificate files. All the certificate file should be in pem format.
  • Certificate Authority Bundle - This bundle should contain only the chain certificates used to sign the TLS server certificate. The certificate provided in the --cacert option should not include the leaf certificates. The chain limit is up to nine certificates.
  • Server Certificate - Public server certificate
  • Private key - Private key for server certificate
uipathctl config tls-certificates update --cert server.crt --cacert ca.crt --key server.key
Accessing the TLS certificate​
To print out the certificate files, run the following command:
uipathctl config tls-certificates get
Managing additional CA certificates​
To view more information about additional CA certificates, run the following command:
uipathctl config additional-ca-certificates --help
Output:
Manage additional ca certificates
Usage:
  uipathctl config additional-ca-certificates [flags]
  uipathctl config additional-ca-certificates [command]
Available Commands:
  get         Get the current additional ca certificates
  update      Update additional ca certificates
Flags:
  -h, --help   help for additional-ca-certificates
Global Flags:
Usage:
Available Commands:
Flags:
Global Flags:
Updating the CA certificates​
This command helps you update or replace the existing configured CA certificates.
uipathctl config additional-ca-certificates update --cacert additional_ca.crt
Note:
The command above adds a new certificate to the list of existing certificates. if you want to replace all the previously configured certificates, make sure to append --replace at the end.
The CA Certificate bundle file should be a valid .pem format and can have more than one certificate present in it.
Accessing the CA certificates​
To download the already configured CA certificates, run the following command:
 uipathctl config additional-ca-certificates get
Managing identity token-signing certificates​
To view more information about identity token-signing certificates, run the following command:
uipathctl config token-signing-certificates --help
Output:
Manage token signing certificates
Usage:
  uipathctl config token-signing-certificates [flags]
  uipathctl config token-signing-certificates [command]
Available Commands:
  get         Get the current token signing certificate
  rotate      Rotate token signing certificates
  update      Update future token signing certificate
Flags:
  -h, --help   help for token-signing-certificates
Global Flags:
Usage:
Available Commands:
Flags:
Global Flags:
Updating the certificate​
To upload the new certificate to sign the token, run the following command:
Note:
The following command does not replace the existing token signing certificate.
Make sure the certificate you provide is in .pem format.
uipathctl config token-signing-certificates update --cert server.crt --key server.key
Rotating the certificate​
To rotate or replace the old certificate with the new one, run the following command:
uipathctl config token-signing-certificates rotate
After rotation, restart deployments and stateful sets by running the following commands:
kubectl -n uipath rollout restart deploy
kubectl -n uipath rollout restart sts
Accessing the certificate​
To download the current token signing certificate, run the following command:
uipathctl config token-signing-certificates get
Note:
There should be a lead time of approximately 24-48 hours between certificate update and rotate.
We need this lead time to keep supporting the authentication for cached token signed by old certificate.
Rotating the certificate too soon before the expiry of the cache token can result in downtime. In this case, you may have to restart all your robots.
Managing the external OCI-compliant registry certificate​
To update the certificate for the external OCI-compliant registry post-installation, take the following steps:
  1. Update the registry_ca_cert flag in the input.json file. For details, refer to External OCI-compliant registry configuration.
  2. Update the ArgoCD trusted CA certificate for the external OCI-compliant registry:
    uipathctl config argocd ca-certificates update --cacert [PATH]
Note:
Registries signed by a private certificate authority do not work as expected by simply providing the CA file as registry_ca_cert for AKS and EKS. You need to follow additional steps, specific to the cloud provider. For example, refer to Custom certificate authority (CA) in Azure Kubernetes Service (AKS) (preview) or Use private certificates to enable a container repository in Amazon EKS as some of the possible solutions.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
