Automation Suite
- Overview
- Requirements
- Prerequisite checks
- uipathctl cluster
- uipathctl cluster migration
- uipathctl cluster upgrade
- uipathctl config
- uipathctl config alerts
- uipathctl config argocd
- uipathctl health
- uipathctl health bundle
- uipathctl health check
- uipathctl health diagnose
- uipathctl health test
- uipathctl manifest
- uipathctl manifest apply
- uipathctl manifest diff
- uipathctl manifest get
- uipathctl manifest render
- uipathctl prereq
- uipathctl prereq create
- uipathctl prereq run
- uipathctl resource
- uipathctl resource report
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- uipathctl version
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Monitoring and alerting
- Cluster administration
- Troubleshooting
Automation Suite on EKS/AKS Installation Guide
Last updated Apr 19, 2024
Diagnose the last unsuccessful sync operation using the Kubernetes API.
uipathctl health diagnose PATH [flags]
# Diagnose the last unsuccessful sync operation
uipathctl health diagnose input.json
-h, --help help for diagnose
--versions string path to versions file
--excluded strings components to be excluded from execution, defaults to none
--included strings components to be included in the execution, defaults to all
-o, --output output output format. one of [json,yaml,text,junit] (default text)
