Automation Suite
- Overview
- Requirements
- Prerequisite checks
- uipathctl cluster
- uipathctl cluster migration
- uipathctl cluster upgrade
- uipathctl config
- uipathctl config alerts
- uipathctl config argocd
- uipathctl health
- uipathctl health bundle
- uipathctl health check
- uipathctl health diagnose
- uipathctl health test
- uipathctl manifest
- uipathctl manifest apply
- uipathctl manifest diff
- uipathctl manifest get
- uipathctl manifest render
- uipathctl prereq
- uipathctl prereq create
- uipathctl prereq run
- uipathctl resource
- uipathctl resource report
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- uipathctl version
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Step 8: Deleting the default tenant
- Step 1: Removing old Identity cache keys
- Step 2: Updating AD integration and authentication
- Step 4: Validating the Insights migration
- B) Single tenant migration
- Monitoring and alerting
- Cluster administration
- Troubleshooting
Automation Suite on EKS/AKS Installation Guide
Last updated Apr 19, 2024
O remove the old Identity cache keys, take the following steps:
- Run
kubectl --kubeconfig <directory of SF cluster yaml file> get secrets/redb-redis-cluster-db -n uipath --template '{{ .data.password }}'
to get Redis password. Decode the Base64 value. - Run
kubectl --kubeconfig <directory of SF cluster yaml file> get secrets/redb-redis-cluster-db -n uipath --template '{{ .data.port }}'
to get Redis port. Decode the Base64 value. - Run
kubectl --kubeconfig <directory of SF cluster yaml file> exec -i -t -n redis-system redis-cluster-0 -c redis-enterprise-node "--" sh -c "clear; (bash || ash || sh)"
to get into Redis node. - Use port and password got from previous commands to run
redis-cli -p <Port number> -a <Password> --scan --pattern is:* | xargs redis-cli -p <Port number> -a <Password> del
to delete the old keys. - Run exit to get out.
