Configuring the maximum request size
Reference for configuring the maximum request size in the orchestrator-customconfig config map in Automation Suite on EKS/AKS.
You can configure the maximum request size in the orchestrator-customconfig config map using a tool such as kubectl.
The default value for the maximum request size is 300 MB, but you can edit it in the values.json file. The Orchestrator deployment should restart automatically after this configuration change.
  "Kestrel": {
    "Limits": {
      "MaxRequestBodySize": 314572800
  "Kestrel": {
    "Limits": {
The values.json file in the orchestrator-customconfig config map may also contain other values, such as AppSettings. You must not remove any other settings when configuring the maximum request size.
  "Kestrel": {
  "AppSettings": {
  "Kestrel": {
  "AppSettings": {
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
