Automation Suite
- Overview
- Requirements
- Prerequisite checks
- uipathctl cluster
- uipathctl cluster migration
- uipathctl cluster upgrade
- uipathctl config
- uipathctl config alerts
- uipathctl config argocd
- uipathctl health
- uipathctl health bundle
- uipathctl health check
- uipathctl health diagnose
- uipathctl health test
- uipathctl manifest
- uipathctl manifest apply
- uipathctl manifest diff
- uipathctl manifest get
- uipathctl manifest render
- uipathctl prereq
- uipathctl prereq create
- uipathctl prereq run
- uipathctl resource
- uipathctl resource report
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- uipathctl version
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Monitoring and alerting
- Cluster administration
- Troubleshooting
Automation Suite on EKS/AKS Installation Guide
Last updated Apr 19, 2024
Creates the external prerequisites. These are primarily object storage buckets and SQL databases. The SQL databases required
for the installation are created on the SQL server if the
sql.create_db key
is set in the config file. The object storage buckets are created in the cloud provider if the object_storage.create_bucket
key is set in the config file.
uipathctl prereq create PATH [flags]
# Create all external prerequisites
uipathctl prereq create input.json --versions versions.json
-h, --help help for create
--location location Location where the prerequisites are executed. one of [local, cluster] (default cluster)
-o, --output output Output format. one of [json,yaml,text] (default text)
--versions string Path to the versions file
--excluded strings components to be excluded from execution, defaults to none
--included strings components to be included in the execution, defaults to all
