- Overview
- Requirements
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Step 8: Migrating standalone Test Manager
- Monitoring and alerting
- Cluster administration
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Test Automation SQL connection string is ignored
- EKS backup failure due to Velero version
- Velero backup fails with FailedValidation error
- Accessing FQDN returns RBAC access denied error
Back up the shared platform capabilities database, AutomationSuite_Platform, using SQL Server Management Studio in Automation Suite.
To back up the database of the shared platform capabilities in Automation Suite, take the following steps. Note that the default name of this database is AutomationSuite_Platform.
Log into the Automation Suite SQL Server using SQL Server Management Studio (SSMS).
Open the context menu for Database, select Tasks, and then Export Data-tier Application.
Select the output path for the
BACPACfile. -
Finish the process.
Result
The wizard exports the platform database to a .bacpac file at the location you selected in step 3.
