Automation Suite
- Overview
- Requirements
- Prerequisite checks
- uipathctl cluster
- uipathctl cluster migration
- uipathctl cluster upgrade
- uipathctl config
- uipathctl config alerts
- uipathctl config argocd
- uipathctl health
- uipathctl health bundle
- uipathctl health check
- uipathctl health diagnose
- uipathctl health test
- uipathctl manifest
- uipathctl manifest apply
- uipathctl manifest diff
- uipathctl manifest get
- uipathctl manifest render
- uipathctl prereq
- uipathctl prereq create
- uipathctl prereq run
- uipathctl resource
- uipathctl resource report
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- uipathctl version
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Monitoring and alerting
- Cluster administration
- Troubleshooting
Automation Suite on EKS/AKS Installation Guide
Last updated Apr 19, 2024
Load the configuration file found in the parameter, and lists the applications created based on it. The runtime configuration is used to determine which applications are required. The output is always in tabular format. By default, the list is sorted alphabetically.
uipathctl manifest list-applications PATH [flags]
# List the applications which are installed based on the configuration found in input.json
uipathctl manifest list-applications input.json
# List the applications which are installed based on the configuration found in input.json.
# Sort them by the order in which they need to be installed based on dependencies between them.
uipathctl manifest list-applications input.json --sort-by topological
# List the applications without headers
uipathctl manifest list-applications input.json --no-headers
# Override the initial list of enabled components
uipathctl manifest list-applications input.json --override gatekeeper,redis
-h, --help help for list-applications
--is-required string to check whether the component needs to install
--no-headers if true, print the output without headers
--override strings optional list of components to override the components enabled in input.json file
--sort-by sortBy if set, sort the output by the given criteria. Valid values are: [alphabetical, topological] (default alphabetical)
