Automation Suite
- Overview
- Requirements
- Prerequisite checks
- uipathctl cluster
- uipathctl cluster migration
- uipathctl cluster upgrade
- uipathctl config
- uipathctl config alerts
- uipathctl config argocd
- uipathctl health
- uipathctl health bundle
- uipathctl health check
- uipathctl health diagnose
- uipathctl health test
- uipathctl manifest
- uipathctl manifest apply
- uipathctl manifest diff
- uipathctl manifest get
- uipathctl manifest render
- uipathctl prereq
- uipathctl prereq create
- uipathctl prereq run
- uipathctl resource
- uipathctl resource report
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- uipathctl version
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Monitoring and alerting
- Cluster administration
- Troubleshooting
Automation Suite on EKS/AKS Installation Guide
Last updated Apr 19, 2024
Add host admin adds/updates a host admin with the provided credentials.
kubeconfig
file. If the --kubeconfig
flag is set, it uses the kubeconfig
file specified by the flag.
uipathctl config add-host-admin [flags]
# Add host admin with the provided username and password in cluster
uipathctl config add-host-admin --username newadmin --password password
# Add host admin with the provided username, password and email in cluster
uipathctl config add-host-admin --username newadmin --email email --password password
# Add host admin with the provided username and password in the cluster identified by the current context in the kubeconfig file
uipathctl config add-host-admin --username newadmin --password password --kubeconfig cluster.kubeconfig
-e, --email string host admin email
-h, --help help for add-host-admin
-p, --password string host admin password
-u, --username string host admin username
