Automation Suite products
Products available in the Automation Suite bundle, including which ones can be enabled or disabled after installation in Automation Suite.
Automation Suite lets you manage your self-hosted UiPath® platform as one product. However, not all of our self-hosted products are part of Automation Suite.
The following products are part of the Automation Suite bundle. You have the ability to enable or disable products at any time after their installation.
Some Automation Suite products have additional dependencies on each other, as listed below:
Product Dependency
Apps
  • Data Service (for the Data Service integration)
Automation Hub
  • Orchestrator (for Automation Store, Studio, and Assistant integrations)
  • Task Mining (for Task Mining integration)
Automation Suite Robots
  • Orchestrator
Document Understanding
  • AI Center
Process Mining
  • Automation Hub (for sending ideas to Automation Hub, and for uploading app templates in Process Mining)
  • Orchestrator (for Automation integration)
Task Mining
  • AI Center
AI Computer Vision
  • AI Center
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
