- Overview
- Requirements
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Step 8: Migrating standalone Test Manager
- Monitoring and alerting
- Cluster administration
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Test Automation SQL connection string is ignored
- EKS backup failure due to Velero version
- Velero backup fails with FailedValidation error
- Accessing FQDN returns RBAC access denied error
Enable and disable products post-installation in Automation Suite on EKS/AKS using input.json and uipathctl.
You can enable and disable products in Automation Suite at any point post-installation.
To do that, you must access and update the input.json file and apply the new configuration via uipathctl.
Step 1: Changing the product selection in the configuration file
Change the product selection in the configuration file.
To do that, edit
input.jsonwith the editor of your choice. -
In the services list, set the
enableflags totrueorfalsefor the specific services you want to enable or disable.Note:You can manage Action Center and Apps simply by updating the
enableflag. Other products might require an additional step to configure the installation. Refer to the following instructions for details.The following examples provide configuration details for individual products.
Enabling or disabling Action Center
See the following configuration details for enabling or disabling Action Center in the input.json file:
"actioncenter": {
"enabled": "true" //Set to "false" to disable the Action Center
"actioncenter": {
Enabling or disabling Apps
Apps requires updating the enable flag and an SQL database.
If you previously set a value for sql_connection_string_template_odbc in input.json, then the default database name is AutomationSuite_Apps.
To change the default database name, you need to update the sql_connection_str inside the Apps field. This overrides the default database and connection string template set in sql_connection_string_template_odbc.
See the following configuration details for enabling or disabling Apps in the input.json file:
"apps": {
"enabled": "true" //Set to "false" to disable the Apps
"sql_connection_str": "" ////Optional and only require to override the default database name
"apps": {
Enabling or disabling AI Center
AI Center requires updating the enable flag and an SQL database.
If you previously set a value for sql_connection_string_template_jdbc in input.json, then the default AI Center database name is AutomationSuite_AICenter.
To change the default database name, you need to update the sql_connection_str inside the AI Center field. This overrides the default database and connection string template set in sql_connection_string_template_jdbc.
See the following configuration details for enabling or disabling AI Center in input.json:
"aicenter": {
"enabled": "true", //Set to "false" to disable the AICenter
"sql_connection_str": "" //Optional and only required to override the default database name
"aicenter": {
AI Center installed in Automation Suite on AKS/EKS cannot connect to an external Orchestrator.
Enabling or disabling Automation Hub
To enable Automation Hub, in the automation_hub section of the input.json file, set the enabled flag to true:
"automation_hub": {
"enabled": "true" //Set to "false" to disable Automation Hub
"sql_connection_str": "" //Optional and only require to override the default database name
"automation_hub": {
To disable Automation Hub, set the enabled flag to false in the automation_hub section of the input.json file.
Enabling or disabling Automation Ops
Automation Ops requires updating the enable flag and an SQL database.
If you previously set a value for sql_connection_string_template in input.json, then the default database name for Automation Ops is AutomationSuite_Platform.
To change the default database name, you need to update the sql_connection_str inside the Automation Ops field. This overrides the default database and connection string template set in sql_connection_string_template.
Automation Ops shares a database with the core platform, including Orchestrator. If you change the database here, you update the database for the core platform as well.
See the following configuration details for enabling or disabling Automation Ops in input.json:
"automation_ops": {
"enabled": "true", //Set to "false" to disable the Automation Ops
"automation_ops": {
Enabling or disabling Automation Suite Robots
Before enabling Automation Suite Robots, make sure you meet the requirements.
To enable Automation Suite Robots, take the following steps:
Enable the
asrobotsflag in theinput.jsonfile. If you want to enable package caching, make sure to properly configure thepackagecachingandpackagecachefolderflags as well.{ "asrobots": { "enabled": Boolean, "packagecaching": Boolean, "packagecachefolder": String } }{ "asrobots": { "enabled": Boolean, "packagecaching": Boolean, "packagecachefolder": String } }Parameter Default value Description packagecachingtrueWhen set to true, robots use a local cache for package resolution.packagecachefolder/uipath_asrobots_package_cacheThe disk location on the serverless agent node where the packages are stored. Note:Package caching optimizes your process runs and allows them to run faster. NuGet packages are fetched from the filesystem instead of being downloaded from the Internet/network. This requires an additional space of minimum 10GB and should be allocated to a folder on the host machine filesystem of the dedicated nodes.
If you use a multi-node HA-ready production setup, you must configure a specialized agent node for Automation Suite Robots.
To disable Automation Suite Robots, disable the asrobots flag in the input.json file.
Enabling or disabling Data Service
Data Service requires updating the enable flag and an SQL database.
If you previously set a value for sql_connection_string_template in input.json, then the default database name is AutomationSuite_DataService.
To change the default database name, you need to update the sql_connection_str inside the Data Service field. This overrides the default database and connection string template set in sql_connection_string_template.
See the following configuration details for enabling or disabling Data Service in input.json:
"dataservice": {
"enabled": "true", //Set to "false" to disable the Data Service,
"dataservice": {
Enabling or disabling Document Understanding
Document Understanding requires updating the enable flag and an SQL database.
If you previously set a value for sql_connection_string_template_odbc in input.json, then the default database name is AutomationSuite_DU_Datamanager.
To change the default database name, you need to update the sql_connection_str inside the Document Understanding field. This overrides the default database and connection string template set in sql_connection_string_template_odbc.
See the following configuration details for enabling or disabling Document Understanding in input.json:
"documentunderstanding": {
"enabled": true,
"sql_connection_str": "***" // dotnet connection string,
"datamanager": {
"sql_connection_str": "***" // odbc connection string
"pyodbc_sql_connection_str": "***" // python sql connection string
"enabled": true,
"datamanager": {
Enabling or disabling Insights
Insights requires updating the enable flag and an SQL database.
If you previously set a value for sql_connection_string_template in input.json, then the default database name is AutomationSuite_Insights.
To change the default database name, you need to update the sql_connection_str inside the Insights field. This overrides the default database and connection string template set in sql_connection_string_template.
To enable the Insights Real-time monitoring feature, set the enable_realtime_monitoring flag to true.
Insights has an optional SMTP configuration to enable receiving email notifications. For details, see Configuring input.json.
See the following configuration details for enabling or disabling Insights in input.json:
"insights": {
"enabled": "true", //Set to "false" to disable the Insights,
"enable_realtime_monitoring": "false", //Set to "true" to enable Insights Real-time monitoring,
"insights": {
Enabling or disabling Orchestrator
To enable Orchestrator, set the orchestrator flag to true in the input.json file.
"orchestrator": {
"enabled": "true" //Set to "false" to disable Orchestrator
"orchestrator": {
To disable Orchestrator, set the orchestrator flag to false in the input.json file.
Enabling or disabling Process Mining
To enable Process Mining, make the following changes to the input.json file:
- Enable the
processminingflag. - Configure the following connection string templates:
sql_connection_string_templatesql_connection_string_template_jdbcsql_connection_string_template_odbcsql_connection_string_template_sqlalchemy_pyodbc
- Add a separate connection string for the second SQL Server:
"processmining": { "enabled": true, "sql_connection_str": "", // dotnet connection string "sqlalchemy_pyodbc_sql_connection_str": "", "warehouse": { "sql_connection_str": "", "sqlalchemy_pyodbc_sql_connection_str": "" } }"processmining": { "enabled": true, "sql_connection_str": "", // dotnet connection string "sqlalchemy_pyodbc_sql_connection_str": "", "warehouse": { "sql_connection_str": "", "sqlalchemy_pyodbc_sql_connection_str": "" } }
To disable Process Mining, disable the processmining flag.
Enabling or disabling Task Mining
Task Mining requires update the enable flag and an SQL Database.
If you previously set a value for sql_connection_string_template in input.json, then the default database name is AutomationSuite_Task_Mining.
To change the name to something other than the default, you can update the sql_connection_str inside the Task Mining field to override the default database and connection string template set in sql_connection_string_template
Task Mining requires a few additional steps, including the provisioning of a dedicated agent node for AI-specific workloads.
See the following configuration details for enabling or disabling Task Mining in input.json:
"task_mining": {
"enabled": "true", //Set to "false" to disable the Task Mining,
"task_mining": {
Un-tainting for workloads
If desired, the Task Mining node can be repurposed as an agent node. To accomplish this, run the following commands:
- Check an actual taint using
kubectl describe node task-mining_nodenamecommand. - Run the command
kubectl taint nodes task-mining_nodename task.mining/cpu=present:NoSchedule-. - Check taint has disappeared using
Enabling or disabling Test Manager
Test Manager requires updating the enable flag and an SQL database.
If you previously set a value for sql_connection_string_template in input.json, then the default database name is AutomationSuite_Test_Manager.
To change the default database name, you need to update the sql_connection_str inside the Test Manager field. This overrides the default database and connection string template set in sql_connection_string_template.
See the following configuration details for enabling or disabling Test Manager in input.json:
"test_manager": {
"enabled": "true", //Set to "false" to disable the Test Manager,
"test_manager": {
Step 2: Running the installer to update the new product configuration
Once you update the input.json, run the following commands with the uipathctl installer to update the service configuration:
- Run the following command to get an output of what changes will be made to the cluster:
# uipathctl manifest apply --dry-run input.json --versions versions.json automationhub deleted (dry-run) platform updated (dry-run)# uipathctl manifest apply --dry-run input.json --versions versions.json automationhub deleted (dry-run) platform updated (dry-run) - To apply the changes on the cluster, run:
# uipathctl manifest apply input.json --versions versions.json --log-level info --skip-helm# uipathctl manifest apply input.json --versions versions.json --log-level info --skip-helm
- Step 1: Changing the product selection in the configuration file
- Enabling or disabling Action Center
- Enabling or disabling Apps
- Enabling or disabling AI Center
- Enabling or disabling Automation Hub
- Enabling or disabling Automation Ops
- Enabling or disabling Automation Suite Robots
- Enabling or disabling Data Service
- Enabling or disabling Document Understanding
- Enabling or disabling Insights
- Enabling or disabling Orchestrator
- Enabling or disabling Process Mining
- Enabling or disabling Task Mining
- Enabling or disabling Test Manager
- Step 2: Running the installer to update the new product configuration
