- Overview
- Requirements
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Step 8: Migrating standalone Test Manager
- Monitoring and alerting
- Cluster administration
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Test Automation SQL connection string is ignored
- EKS backup failure due to Velero version
- Velero backup fails with FailedValidation error
- Accessing FQDN returns RBAC access denied error
Pre-migration steps
Complete mandatory pre-migration steps before migrating a standalone platform installation to Automation Suite on EKS/AKS.
To ensure you successfully migrate a standalone platform installation to Automation Suite, make sure to take the steps described in the following sections. The pre-migration steps are mandatory.
- Save the connection strings. Details...
- Create the organizations in Automation Suite. Details...
- If the name of the standalone product admin matches the name of the Automation Suite admin, make sure the email address of the standalone product admin is not null.
If the email address of the standalone product admin matches the email address of the Automation Suite admin, make sure to clear the latter.
This step is essential in the migration to Automation Suite.
