Step 2: Restoring the standalone product database
Restore a standalone product database to the Automation Suite SQL Server instance using SQL Server Management Studio.
Here we introduce a way to use SQL Server Management Studio (SSMS) to restore the database of a standalone product to the Automation Suite SQL Server instance. For details on downloading and installing SQL Server Management Studio, refer to Migration prerequisites.
  1. In SQL Server Management Studio connect to the standalone product database, select Tasks, then choose Deploy Database to Azure SQL.
    SSMS Deploy Database to Azure SQL Database wizard
  2. Select Connect to connect to the Automation Suite SQL database. Provide the new database name. Choose the directory to store the temporary database file.
    Deploy Database to Azure SQL Database wizard showing the connection and new database name fields
  3. Wait for the deployment to complete.
    Deploy Database to Azure SQL Database wizard showing deployment progress
  4. Record the connection string for the restored standalone product database in Automation Suite.
Result: The standalone product database is restored to the Automation Suite SQL Server instance, and you have the connection string for later use.
Restoring the standalone Orchestrator database on EKS​
If you migrate to Automation Suite on EKS, you cannot directly restore the Orchestrator database to the Azure SQL database. You must first back up the standalone Orchestrator database to a file and then restore to the RDS database.
If Orchestrator and Identity share their database, you can skip step 4. If they have separate databases, you must back them up separately.
  1. Log into the standalone machine and log into SQL Server using SSMS.
  2. Back up the standalone Orchestrator database:
    1. Go to Databases, open the context menu for the Orchestrator database, select Tasks, and select Back Up.
      SSMS context menu for the Orchestrator database showing Tasks > Back Up
    2. Confirm the backup path.
      Back Up Database dialog showing the backup file path
    3. Complete the backup.
      Back Up Database dialog showing backup completion
  3. Restore the standalone Orchestrator database to Amazon Relational Database Service (RDS) on the Automation Suite on EKS instance on the standalone machine.
    1. Upload the backed up bak file to S3 bucket.
      aws s3 cp <local-file-path> s3://haonan-msi-asair-migration-bucket/<filename>
      Sample:
      aws s3 cp "C:\Program Files\Microsoft SQL Server\MSSQL15.SQLEXPRESS\MSSQL\Backup\20230401_0614.bak" s3://haonan-msi-asair-migration-bucket/20230401_0614.bak --region us-west-2
    2. Grant permission to the restored database on AWS.
Granting permissions to the restored database on AWS​
  1. Go to Identity and Access Management (IAM), and create a new role with AWSBackupServiceRolePolicyForRestores permissions.
    AWS IAM role creation screen with AWSBackupServiceRolePolicyForRestores permissions
  2. Go to RDS and select Option groups:
    1. Create a group and provide the following details:
      • Name: SqlServerBackupRestore
      • Description: xxx
      • Engine: Select your DB engine
      • Major Engine Version: Select version of your DB instance.
    2. Select Create.
      RDS Option Groups screen showing the Create button
    3. Select the name of created group to edit it as follows:
      1. Select Add.
      2. Select SQLSERVER_BACKUP_RESTORE.
      3. Select the IAM role you created in the previous steps.
      4. Select Immediately to schedule instant change.
      RDS option group edit screen showing the SQLSERVER_BACKUP_RESTORE option added
    4. Back to RDS Databases and select your instance.
      1. Select Modify.
      2. Select Option group you created in the previous step.
      3. Select Next.
      4. Select Apply immediately (it should not cause service downtime).
      5. Apply changes by selecting Modify DB instance.
      6. If you have connection to database from SQL Management Studio, close it and connect again.
  3. Follow AWS documentation to database backed up bak file to AWS S3 bucket.
    Sample command:
    exec msdb.dbo.rds_restore_database
        @restore_db_name='UiPath_20230531',
        @s3_arn_to_restore_from='arn:aws:s3:::haonan-msi-asair-migration-bucket/20230401_0614.bak',
        @with_norecovery=0,
        @with_norecovery=0,
  • Restoring the standalone Orchestrator database on EKS​
  • Granting permissions to the restored database on AWS​
Connect
Stay updated
