Automation Suite
Banner background image
Automation Suite on EKS/AKS Installation Guide
Last updated Apr 19, 2024
Automation Suite on EKS/AKS overview
Automation Suite enables you to deploy the UiPath® business automation platform in your environment of your choice. Depending on your needs, you can deploy the platform on Linux servers (bare-metal or virtual machines) in your data center or public cloud (Azure, AWS, or GCP), or on your Kubernetes clusters in Amazon Web Services (Elastic Kubernetes Service) or Microsoft Azure (Azure Kubernetes Service).
Automation Suite includes:
  • All Server Products (except for any new products shipping in Automation Cloud first).
  • All Shared Suite Capabilities that enable you to easily configure the integration with existing enterprise systems, such as AD, AAD, or SAML, across all products; a common experience is offered across the suite for the user, tenant, external applications, and license management.
  • Common end-user portal.
This guide provides documentation for installing Automation Suite on your EKS or AKS clusters.
Key benefits
Deployment scenarios
You can deploy Automation Suite on EKS or AKS in online environment with or without a proxy.
Security and compliance
Automation Suite is pre-configured with optional OPA policies and network policies to follow the principles of the least privilege. In addition, to control the OPA policies, Automation Suite also bundles an optional Gatekeeper component.
Prerequisites
Before installing Automation Suite on EKS/AKS, you must ensure your cluster meets the infrastructure requirements.
Installation
UiPath® provides a the uipathctl CLI tool, which is optimized for Automation Suite on EKS/AKS operations, such as running prerequisite validations, installing on your EKS/AKS cluster, and upgrades.
Post-installation management
Automation Suite provides management operations via uipathctl, such as adding new products, updating certificates, configuring Automation Suite in maintenance mode, taking backups, and monitoring.
Upgrade and migration
This section provides more details on how to upgrade Automation Suite or your infrastructure underneath Automation Suite, and how to migrate from standalone products to Automation Suite.
For details, see Upgrade and .
Troubleshooting
You can run health checks and tests to help detect issues and whether they are in the infrastructure layer or within Automation Suite.
Cross-deployment model feature comparison
We aim to provide feature parity between our Automation Suite deployment models. However, there will always be some differences you should be aware of.
User scenario/FeatureEmbeddedAzure/AKSAmazon/EKS
Service capabilities
Orchestrator
YES
YESYES
AI CenterYESYESYES
AI Center with external orchestrator (standalone)YES
NO
NO
AppsYESYESYES
Action CenterYESYESYES
Automation HubYESYESYES
Automation OpsYESYESYES
Data ServiceYESYESYES
Document UnderstandingYESYESYES
InsightsYESYESYES
Automation Suite RobotsYESYESYES
Process MiningYESYESYES
Task MiningYESYESYES
Test ManagerYESYESYES
Integration Service
NO
NONO
Communications miningNONONO
Studio WebNONONO
Architecture
KubernetesRancher RKE2AKSEKS
Databases
MS SQL
Note:
Additional Microsoft SQL platforms, such as Azure SQL Database or Azure SQL Managed Instance, as well as Amazon Relational Database Service are also supported as long as the Microsoft SQL Server database engine meets the requirements.
Storage
  • Option 1: Embedded block storage (Longhorn) and Object Storage (Ceph)
  • Option 2: Embedded block storage (Longhorn) and Object storage external to the cluster
UiPath® provides the Longhorn and Ceph.
  • Object Storage: Azure Blob
  • Filesystem: Azure Filesystem
  • Block Storage: Azure Disks
  • Object Storage: AWS S3
  • Filesystem: AWS EFS
  • Block Storage: AWS EBS
Service Mesh and Routing
Rancher provided Istio Service Mesh, Routing via envoy ingress gateway
OSS Istio Service Mesh Routing via WASM plugin
OPA
OSS Gatekeeper
OSS Gatekeeper
OSS Gatekeeper
Monitoring
Rancher provided Prometheus & Grafana
OSS Prometheus & Grafana
Caching
Embedded Redis with in the cluster and provided by UiPath®
Cloud Redis outside the cluster and managed by customer
Logging Aggregation
Rancher provided Fluend/Fluent-bit
OSS Fluend/Fluent-bit
Cert Manager
OSS Cert Manager
OSS Cert Manager
OSS Cert Manager
Deployment tool
OSS ArgoCD
OSS ArgoCD
OSS ArgoCD
Deployment scenario
Single Node (Non-production)
YES
NO
NO
Multi Node (HA)
YES (requires additional HAA license)
YES
YES
Online
YES
YESYES
OfflineYES
YES
YES
Deployment method
Advanced CLIinstall-uipath.sh
uipathctl
uipathctl
Interactive Installer
YES (InstallUipathAS.sh)
NO
NO
Cloud deployment templates
YES (AWS, Azure, GCP)
NO
NO
Marketplace
YES (AWS QS Only)
NO
NO
Installation
A la carte product selection
YES
YESYES
Custom domainYESYESYES
Custom certificatesYESYESYES
Hardware requirements validationYESYESYES
Proxy configurationYESYESYES
Optional OSS/fabric component
NO
YESYES
Enterprise grade features
Disaster Recovery
YES (Active Passive deployment)
YES
(Multi-zone architecture for UiPath® services without zone affinity. Insights not supported.)
YES
(Multi-zone architecture without zone affinity. Insights not supported.)
Backup/restoreYESYESYES
Upgrade
YES
YESYES
Troubleshooting
Support bundleYES
(support-bundle.sh)
YES (uipathctl)
YES (uipathctl)
Diagnostic toolYES
(diagnostics-report.sh)
YES
(uipathctl)
YES (uipathctl)
Health Checks
NO
YES (uipathctl) YES (uipathctl)
Security
FIPS enabled host
YES
YES
NO
Gatekeeper/OPA policyYESYESYES
Network policy
NO
YESYES
Hardened Uipath® service container imagesYESYESYES
ArgoCD SSOYES (LDAP only)
NO
NO
mTLS for service communication
YES
YES
YES
Migration options
Standalone Orchestrator to Automation Suite full migrationYESYESYES
Standalone Orchestrator to Automation single tenant migration optionsYESYESYES
Automation Suite embedded to AS on AKS/EKS
YES
YES
YES
Evaluation guide
Requirements and installation
Details
Instructions
Requirements and installation instructions for Automation Suite.
Platform evaluation
Details
Instructions
Complete an initial platform configuration.
Connect your first robot
Monitor the stack, troubleshoot issues, create alerts, and view dashboards from a centralized location.
