Automation Suite
- Overview
- Requirements
- Prerequisite checks
- uipathctl cluster
- uipathctl cluster migration
- uipathctl cluster upgrade
- uipathctl config
- uipathctl config alerts
- uipathctl config argocd
- uipathctl health
- uipathctl health bundle
- uipathctl health check
- uipathctl health diagnose
- uipathctl health test
- uipathctl manifest
- uipathctl manifest apply
- uipathctl manifest diff
- uipathctl manifest get
- uipathctl manifest render
- uipathctl prereq
- uipathctl prereq create
- uipathctl prereq run
- uipathctl resource
- uipathctl resource report
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- uipathctl version
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Monitoring and alerting
- Cluster administration
- Troubleshooting
Automation Suite on EKS/AKS Installation Guide
Last updated Apr 19, 2024
Enable the periodical snapshot backup of the cluster.
uipathctl snapshot backup enable [flags]
-h, --help help for enable
-p, --prefix string This will prefix the names of all the snapshot backups with the given string.
This is only used if you wish to enable schedule backup.
The default value is snapshot
(default "snapshot")
-r, --retention string Retention policy in duration format Hh:Mm:Ss, for e.g 8h5m1s.
Default value of 168h.
(default "168h")
--schedule string Unix cron expression for schedule
this is only required if you wish to enable schedule backup.
Default value "*/45 * * * *" denotes every 45th minutes backup is triggered.
(default "*/45 * * * *")
(default "168h")
