Migration compatibility matrix
Version compatibility requirements for migrating standalone products to Automation Suite on EKS/AKS.
When migrating from a standalone product to Automation Suite, you must make sure the versions of the standalone product, UiPath.OrganizationMigrationApp, and Automation Suite are compatible.
The following table describes the version compatibility required to perform a migration to Automation Suite:
Standalone product version
Test Manager migration script version UiPath.OrganizationMigrationApp
version
Automation Suite version
Orchestrator Insights Test Manager
2023.10.15
2023.10.14
2023.10.11 2023.10.12 2023.10.6 2023.10.11
2023.10.13 2023.10.10 2023.10.12 2023.10.6 2023.10.10 2023.10.10
2023.10.10 2023.10.9 2023.10.10 2023.10.6 2023.10.9 2023.10.9
N/A 1
N/A 1
  2023.10.6
N/A 1
2023.10.9 2023.10.7 2023.10.9 2023.10.6 2023.10.8 2023.10.7
2023.10.8 2023.10.6 2023.10.8 2023.10.6 2023.10.7 2023.10.6
2023.10.6 2023.10.5 2023.10.6 2023.10.6 2023.10.6 2023.10.5
2023.10.5 2023.10.4 2023.10.5 2023.10.6 2023.10.5 2023.10.4
2023.10.4 2023.10.3 2023.10.4 2023.10.6 2023.10.4 2023.10.3
2023.10.3 N/A 2023.10.2 2023.10.6 2023.10.2 2023.10.2
2023.10.1 N/A 2023.10.1 2023.10.6 2023.10.1 2023.10.1
2023.10.0 N/A 2023.10.0 2023.10.6 2023.10.0 2023.10.0
1 There are no Orchestrator and Insights standalone versions compatible with Automation Suite 2023.10.8. Therefore, no UiPath.OrganizationMigrationApp version is available with Automation Suite 2023.10.8.
Note:
How to read the table
  • As an example, to migrate standalone Orchestrator 2023.10.0, you must use UiPath.OrganizationMigrationApp 2023.10.0 and make sure that you installed Automation Suite 2023.10.0.
  • For information on updates to the UiPath.OrganizationMigrationApp and the migration workflows, see the release notes for your targeted Automation Suite version. The links to the release notes are available in the Automation Suite version column.
    If there is no entry dedicated to the UiPath.OrganizationMigrationApp in the release notes, this means that we made only minor improvements to the tool.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
