Using the monitoring stack
The monitoring stack for Automation Suite clusters includes Prometheus, Grafana, and Alertmanager, which are automatically installed unless you choose to bring your own monitoring stack.
This page describes a series of monitoring scenarios optimized to work with the monitoring tool, which is bundled with the Automation Suite cluster. If you choose to bring your own monitoring stack, make sure to follow the official documentation of your tools to monitor the health of the cluster.
Important:
When using collectors to export metrics to third-party tools, enabling application monitoring may disrupt the functionality of Automation Suite.
Accessing the monitoring tools
The monitoring stack for Automation Suite clusters includes Prometheus, Grafana, and Alert Manager.
You can access the Automation Suite monitoring tools individually using the following URLs:
ApplicationToolURLExample
MetricsPrometheushttps://monitoring.fqdn/metricshttps://monitoring.automationsuite.mycompany.com/metrics
DashboardGrafanahttps://monitoring.fqdn/grafanahttps://monitoring.automationsuite.mycompany.com/grafana
Alert ManagementAlert Managerhttps://monitoring.fqdn/alertmanagerhttps://monitoring.automationsuite.mycompany.com/alertmanager
Monitoring tool authentication
To access the monitoring tools for the first time, follow the instructions in Accessing Automation Suite.
Checking currently firing alerts
To view the alerts, navigate to Prometheus using https://monitoring.fqdn/metrics and select the Alerts tab. Here you can see all the alerts configured in Automation Suite.
  • To view the active alerts, filter the alert status by using the Firing checkbox.
  • Check Show annotations to display messages corresponding to alerts.
Silencing alerts
If alerts are too noisy, you can silence them. To do that, take the following steps:
  1. Select the Alertmanager tile in the upper left corner of the Monitoring dashboard. The following screen is displayed.
  2. Find the alert in question, and select Silence.
  3. Fill in the Creator and Comment details, and select Create. The alert should no longer show on the Monitoring Dashboard or be reported to any of the configured receivers.
Configuring the alerts
Note:
Before starting configuring the alerts, make sure to enable kubectl.
Adding a new email configuration
To add a new email configuration after an installation, run the following command:
./uipathctl config alerts add-email \
  --name test \
  --to "admin@example.com" \
  --from "admin@example.com" \
  --smtp server.mycompany.com \
  --username admin \
  --password somesecret \
  --require-tls \
  --ca-file <path_to_ca_file> \
  --cert-file <path_to_cert_file> \
  --key-file <path_to_key_file> \
  --send-resolved \
  --ASEA
  --name test \
  --username admin \
  --require-tls \
  --send-resolved \
  --ASEA
FlagDescriptionExample
nameThe name of the email configurationtestconfig
toThe email address of the receiveradmin@example.com
fromThe email address of the senderadmin@example.com
SMTPSMTP server URL or IP address and port numberserver.mycompany.com:567
usernameAuthentication usernameadmin
passwordAuthentication passwordsecurepassword
require-tlsBoolean flag to denote that TLS is enabled at the SMTP server.N/A
ca-fileFile path containing the CA Certificate of the SMTP server. This is optional if the CA is private../ca-file.crt
cert-fileFile path containing the certificate of the SMTP server. This is optional if the certificate is private../cert-file.crt
key-fileFile path containing the private key of the certificate of the SMTP server. This is required if the certificate is private../key-file.crt
send-resolvedBoolean flag to send an email once the alert is resolved.N/A
ASEABoolean flag to indicate that you installed Automation Suite on EKS or AKS.N/A
Removing an email configuration
To remove an email configuration, you must run the following command. Make sure to pass the name of the email configuration you want to remove.
./uipathctl config alerts remove-email --name test --ASEA
Updating an email configuration
To update an email configuration, you must run the following command. Make sure to pass the name of the email configuration you want to update and the additional optional parameters you want to edit. These parameters are the same as the ones for adding a new email configuration. You can pass one or more flags at the same time.
./uipathctl config alerts update-email --name test --ASEA [additional_flags]
Accessing Grafana dashboard
To access Grafana dashboards, you must retrieve your credentials and use them to log in:
  • Username:
    kubectl -n monitoring get secrets/grafana-creds -o "jsonpath={.data.admin-user}" | base64 -d; echo
  • Password:
    kubectl -n monitoring get secrets/grafana-creds -o "jsonpath={.data.admin-password}" | base64 -d; echo
Monitoring Persistent Volumes
You can monitor persistent volumes via the Kubernetes / Persistent Volumes dashboard. You can keep track of the free and used space for each volume.
You can also check the status of each volume by selecting the PersistentVolumes item within the Storage menu of the Cluster Explorer.
Monitoring hardware utilization
To check the hardware utilization per node, you can use the Nodes dashboard. Data on the CPU, Memory, Disk, and Network is available.
You can monitor the hardware utilization for specific workloads using the Kubernetes / Compute Resources / Namespace (Workloads) dashboard. Select the uipath namespace to get the needed data.
Creating shareable visual snapshot of a Grafana chart
  1. Select the downwards pointing arrow next to the chart title, and then select Share.
  2. Select the Snapshot tab, and set the Snapshot name,Expire, and Timeout.
  3. Select Publish to snapshot.raintank.io.
For more details, see the Grafana documentation on sharing dashboards.
Note:
This snapshot is viewable on the public Internet by anyone with the link.
Creating custom persistent Grafana dashboards
For details on how to create custom persisten Grafana dashboards, refer to Grafana documentation.
Querying Prometheus
On the Monitoring Dashboard, select Prometheus Graph. A new window is displayed.
Documentation on the available metrics is here:
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
