Automation Suite
- Overview
- Requirements
- Prerequisite checks
- uipathctl cluster
- uipathctl cluster migration
- uipathctl cluster upgrade
- uipathctl config
- uipathctl config alerts
- uipathctl config argocd
- uipathctl health
- uipathctl health bundle
- uipathctl health check
- uipathctl health diagnose
- uipathctl health test
- uipathctl manifest
- uipathctl manifest apply
- uipathctl manifest diff
- uipathctl manifest get
- uipathctl manifest render
- uipathctl prereq
- uipathctl prereq create
- uipathctl prereq run
- uipathctl resource
- uipathctl resource report
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- uipathctl version
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Monitoring and alerting
- Cluster administration
- Troubleshooting
Automation Suite on EKS/AKS Installation Guide
Last updated Apr 19, 2024
Load the configuration found at PATH, and apply it to the cluster.
The command performs a diff between the current state of the cluster and the desired state, and applies the changes to the cluster.
When the
--override
flag is present, the list overrides the selection found in the input file. The flag is mutually exclusive with the --only
flag. When the exclude_components
key is present in the input file, the components found in the list are excluded from the installed components. This has the
highest priority over all the other flags and it is not mutually exclusive with any of them.
uipathctl manifest apply PATH [flags]
# Apply the configuration found in input.json, using the versions found in versions.json
uipathctl manifest apply input.json --versions versions.json
# Apply the configuration and specify the kubeconfig file to use
uipathctl manifest apply input.json --kubeconfig cluster.kubeconfig --versions versions.json
# Simulate the apply command and print on stdout the result of the operation
uipathctl manifest apply --dry-run input.json
# Apply the configuration but skip the components installed directly by helm
uipathctl manifest apply --skip-helm input.json --versions versions.json
# Apply the configuration overriding the initial list of components
uipathctl manifest apply --override automation_hub,orchestrator --versions versions.json
--continue-on-error if true, continue applying the manifest even if an error occurs
--dependencies-only if true, only dependencies will be applied
--dry-run if true, just print the result of the command, without applying it
--fail-on-version if true, fail if the version of the component is not found in the versions file
-h, --help help for apply
--no-wait if true, return immediately after the ArgoCD applications are created
--only strings optional exclusive list of components to apply
--override strings optional list to override the components enabled in input.json file
--skip-dependencies if true, dependencies will be skipped
--skip-helm if true, skip components installed directly by helm
