- Overview
- Requirements
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Step 8: Migrating standalone Test Manager
- Monitoring and alerting
- Cluster administration
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Test Automation SQL connection string is ignored
- EKS backup failure due to Velero version
- Velero backup fails with FailedValidation error
- Accessing FQDN returns RBAC access denied error
You can modify various Orchestrator parameters using uipathctl. This enables the following configuration scenarios:
To do that, edit the input.json file, add or edit the settings under the orchestrator section, then run the following command:
./uipathctl manifest apply input.json --versions versions.json --kubeconfig kubeconfig.yaml --only orchestrator
For details on input.json, refer to Configuring input.json.
For details, on the Orchestrator-specific configuration, refer to Orchestrator configuration.
