automation-cloud
Automation Cloud admin guide
AI features and model routing
Some UiPath services use AI-powered capabilities delivered through third-party large language models (LLMs), including the GPT family (via Azure OpenAI Service), Gemini models (via Google Vertex AI), and Claude models (via Amazon Bedrock).
These models are hosted in specific regions. When an LLM endpoint is not available in the same region as your UiPath organization or tenant, data is temporarily routed to a region with an available model endpoint.
UiPath does not control the geographic availability of third-party LLMs. However, once a third-party provider makes a new model region available, UiPath investigates and works toward supporting that region for its AI-powered features, while continuing to define only the routing behavior.
How data is processed
When you use an AI feature, the data path depends on three separate regions:
Region typesDescriptionWho controls it
Organization regionThe region where your UiPath organization is provisioned. The organization region is considered for services enabled at the organizational level, that inherit the organization region (for example, Apps, Automation Ops, and Studio Web).You choose the organization region when you create the organization. An organization region is not visible in the UI.
Tenant regionThe region where a tenant-level service (for example, Orchestrator, Test Manager, or Agents) is hosted and processes data.You choose the tenant region when you create the tenant. A tenant’s region is visible in the UI, from the tenant dropdown.
LLM processing regionThe region where the third-party model actually runs.Determined by the third-party LLM provider, which defines where an LLM endpoint is available. If an endpoint is not available in the organization or tenant region, UiPath may temporarily route the request to another supported region. When a new LLM region becomes available, UiPath evaluates and works toward supporting it, while continuing to define only the routing behavior.
These regions can differ. While your UiPath data remains in your selected organization or tenant region, data used when working with AI features may be temporarily routed to another region for model processing if no local LLM endpoint exists.
AI features residency
Check the following definitions to understand the residency scopes used when working with UiPath’s AI features:
  • Organization region: The geographic region you select when creating your UiPath organization. This determines where your organization data is stored, including the data for services that inherit the organization region. Such services are marked as Organization-level in the Global cloud regions table.
  • Tenant region: The region where a tenant is hosted and where its services (for example, Orchestrator, Test Manager, or Agents) operate. Services that inherit the tenant region are marked as Tenant-level in the Global cloud regions table.
  • Service region: The region where a specific service within an organization or tenant runs. In most cases, all services in a tenant follow the tenant region, but some follow the organization region. The data residency of a service is marked in the Global cloud regions table as either inheriting the organization region or tenant region, along with its availability across cloud regions.
  • LLM model endpoint region: The region where the third-party large language model (LLM) executes data processing. The availability of LLM regions is determined by the third-party provider (for example, Azure OpenAI, Google Gemini, or Anthropic Claude). UiPath defines routing rules only when a model is unavailable in the selected tenant or organization region.
  • Global deployment (LLM): A deployment type in which the model is not tied to any specific geographic endpoint. Requests are processed in a vendor-selected region based on availability, and there is no guaranteed LLM processing region. When strict data residency requirements are enforced, globally deployed models are not available.
AI residency example
The following example shows how data is handled across regions when using UiPath services that include AI features. It highlights the different residency scopes involved, and explains how data is processed.
Scenario Description
Organization region European Union (EU) N/A
Tenant region EU N/A
Services used
  • Organization-level: Studio Web design-time experience (uses AI features powered by Azure OpenAI models)
  • Tenant-level: Test Manager (uses AI features with Anthropic Claude as the selected model)
N/A
Model availability
  • Organization-level: Azure OpenAI model endpoint available in EU for Studio Web.
  • Tenant-level: Anthropic Claude model endpoint available in EU for Test Manager.
N/A
LLM processing region The LLM processing region is the same as the organization and tenant region: EU. All data is hosted and processed in the same region. N/A
Note:
If the organization or tenant is located in a region where a third-party provider does not offer an LLM endpoint, the request is routed to a region where an endpoint is available. Once the model response is returned, all further data processing continues within the organization’s or tenant’s region.
Models consumed by Autopilot
Some UiPath services use AI models that are consumed through Autopilot, alongside other proprietary AI capabilities specific to those services. Because Autopilot capabilities are shared across multiple UiPath services, we document Autopilot-consumed models by Autopilot type to clearly indicate how models are used, reused, and routed.
Categorizing models by Autopilot type helps you understand which Autopilot capability consumes a given model and how the same model may be reused across multiple services.
The following Autopilot types are used when documenting model consumption:
  • Autopilot Chat: Represents the conversational interface that enables natural-language interaction with UiPath products. Models in this category power chat-based assistance, explanations, and guidance within supported services. Currently, Autopilot Chat is surfaced in the following services: Maestro, Orchestrator, Studio, Studio Web, and Test Manager.
  • Autopilot for Developers: Represents capabilities that help generate and refine automations or agents using prompt-based generation. Models in this category support developer-focused scenarios such as creating workflows, improving logic, and accelerating automation development. Currently, Autopilot for Developers is surfaced in the following services: Apps, Maestro, ScreenPlay, Studio, and Studio Web,
  • Autopilot for Testers: Represents capabilities that accelerate the testing lifecycle using prompt-based generation. Models in this category support generating, refactoring, and analyzing test cases. With a single natural-language prompt, you can create or modify manual, low-code, or coded test cases directly within Studio, Studio Web, or Test Manager.
Model routings by service
Each UiPath service that uses AI models defines its own routing rules. These rules apply only when an LLM endpoint is not available in the organization or tenant region, and not when a request to an available endpoint fails. If a call to an available endpoint fails, retry the action.
When routing is triggered, UiPath temporarily changes the LLM processing region to another region where the model is available. Only the model processing takes place in the routing region. After the model returns its response, all remaining data processing continues in the organization or tenant region.
The following tables list the routing behavior for each service when an LLM endpoint is not regionally available.
Legend
  • AU - Australia
  • CA - Canada
  • CH - Switzerland
  • EU - European Union
  • IN - India
  • JA - Japan
  • SI - Singapore
  • SK - South Korea
  • UAE - United Arab Emirates
  • UK - United Kingdom
  • US - United States
Agents (playground design time experience)
ModelAUCACHEUINJASISKUAEUKUS
anthropic.claude-3-5-sonnet-20240620-v1:0Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0N/ARouted to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0
anthropic.claude-3-5-sonnet-20241022-v2:0Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0N/ARouted to US, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0
anthropic.claude-3-7-sonnet-20250219-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0N/ARouted to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0
anthropic.claude-haiku-4-5-20251001-v1:0Routed to USRouted to USRouted to EUStays in the regionRouted to EURouted to USRouted to USRouted to EURouted to EURouted to EUStays in the region
anthropic.claude-opus-4-7Routed to USRouted to USRouted to EUStays in the regionRouted to USStays in the regionRouted to USRouted to EURouted to EURouted to USStays in the region
anthropic.claude-sonnet-4-20250514-v1:0Routed to USRouted to USRouted to EUStays in the regionRouted to EURouted to USRouted to USN/ARouted to EURouted to EUStays in the region
anthropic.claude-sonnet-4-5-20250929-v1:0Stays in the regionRouted to USRouted to EUStays in the regionRouted to EUStays in the regionRouted to USRouted to EURouted to EURouted to EUStays in the region
anthropic.claude-sonnet-4-6Stays in the regionRouted to USRouted to EUStays in the regionRouted to EUStays in the regionRouted to USRouted to EURouted to EURouted to EUStays in the region
claude-opus-4-5@20251101Routed to USRouted to USRouted to EUStays in the regionRouted to EURouted to USStays in the regionRouted to EURouted to EURouted to EUStays in the region
gemini-2.5-flashN/AN/AN/AStays in the regionN/AN/AN/AStays in the regionN/AN/AStays in the region
gemini-2.5-proN/AN/AN/AStays in the regionN/AN/AN/AN/AN/AN/AStays in the region
gemini-3-flash-previewRouted to USRouted to USRouted to USRouted to USRouted to USRouted to USRouted to USN/ARouted to USRouted to USStays in the region
gemini-3-pro-previewRouted to GLOBAL, as gemini-3.1-pro-previewRouted to GLOBAL, as gemini-3.1-pro-previewRouted to GLOBAL, as gemini-3.1-pro-previewRouted to GLOBAL, as gemini-3.1-pro-previewRouted to GLOBAL, as gemini-3.1-pro-previewRouted to GLOBAL, as gemini-3.1-pro-previewRouted to GLOBAL, as gemini-3.1-pro-previewN/ARouted to GLOBAL, as gemini-3.1-pro-previewRouted to GLOBAL, as gemini-3.1-pro-previewRouted to GLOBAL, as gemini-3.1-pro-preview
gemini-3.1-pro-previewRouted to GLOBALRouted to GLOBALRouted to GLOBALRouted to GLOBALRouted to GLOBALRouted to GLOBALRouted to GLOBALN/ARouted to GLOBALRouted to GLOBALRouted to GLOBAL
gpt-4.1-2025-04-14Routed to USRouted to USRouted to EUStays in the regionRouted to EURouted to USRouted to USRouted to EURouted to EURouted to EUStays in the region
gpt-4.1-mini-2025-04-14Routed to USRouted to USRouted to EUStays in the regionRouted to EURouted to USRouted to USRouted to EURouted to EURouted to EUStays in the region
gpt-4o-2024-05-13Routed to USRouted to USRouted to EUStays in the regionRouted to EUStays in the region, as gpt-4o-2024-08-06Routed to USN/ARouted to EURouted to EUStays in the region
gpt-4o-2024-08-06Routed to USRouted to USRouted to EUStays in the regionRouted to EUStays in the regionRouted to USN/ARouted to EURouted to EUStays in the region
gpt-4o-2024-11-20Stays in the regionStays in the regionStays in the regionStays in the regionStays in the regionStays in the regionRouted to USRouted to EURouted to EUStays in the regionStays in the region
gpt-4o-2024-11-20-community-agentsRouted to EURouted to EURouted to EUStays in the regionRouted to EURouted to EURouted to EURouted to EURouted to EURouted to EURouted to EU
gpt-4o-mini-2024-07-18Routed to USRouted to USRouted to EUStays in the regionRouted to EURouted to USRouted to USN/ARouted to EURouted to EUStays in the region
gpt-5-2025-08-07Routed to USRouted to USRouted to EUStays in the regionRouted to EURouted to USRouted to USN/ARouted to EURouted to EUStays in the region
gpt-5-mini-2025-08-07Routed to USRouted to USRouted to EUStays in the regionRouted to EURouted to USRouted to USN/ARouted to EURouted to EUStays in the region
gpt-5.1-2025-11-13Routed to USRouted to USRouted to EUStays in the regionRouted to EURouted to USRouted to USN/ARouted to EURouted to EUStays in the region
gpt-5.2-2025-12-11Routed to USRouted to USRouted to USRouted to USRouted to USRouted to USRouted to USRouted to USRouted to USRouted to USStays in the region
gpt-5.4Routed to USRouted to USN/AStays in the regionRouted to EURouted to USRouted to USN/AN/ARouted to EUStays in the region
gpt-5.4-2026-03-05-community-agentsRouted to EURouted to EUN/AStays in the regionRouted to EURouted to EURouted to EUN/AN/ARouted to EURouted to EU
gpt-5.4-mini-2026-03-17Routed to USRouted to USRouted to EUStays in the regionRouted to EURouted to USRouted to USRouted to EURouted to EURouted to EUStays in the region
gpt-5.5-2026-04-23Routed to USRouted to USRouted to EUStays in the regionRouted to USRouted to USRouted to USRouted to EURouted to EURouted to USStays in the region
text-embedding-3-largeStays in the regionStays in the regionStays in the regionStays in the regionStays in the regionStays in the regionRouted to USStays in the regionStays in the regionStays in the regionStays in the region
Agents (runtime and debug experience)
anthropic.claude-3-5-sonnet-20240620-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0N/ARouted to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0
anthropic.claude-haiku-4-5-20251001-v1:0Routed to USRouted to USRouted to EUStays in the regionRouted to EURouted to USRouted to USN/ARouted to EURouted to EUStays in the region
anthropic.claude-sonnet-4-5-20250929-v1:0Routed to USRouted to USRouted to EUStays in the regionRouted to EUStays in the regionRouted to USRouted to EURouted to EURouted to EUStays in the region
anthropic.claude-sonnet-4-6Stays in the regionRouted to USRouted to EUStays in the regionRouted to EUStays in the regionRouted to USN/ARouted to EURouted to EUStays in the region
gpt-4.1-mini-2025-04-14Routed to USRouted to USRouted to EUStays in the regionRouted to EURouted to USRouted to USN/ARouted to EURouted to EUStays in the region
gpt-4o-mini-2024-07-18Routed to USRouted to USRouted to EUStays in the regionRouted to EURouted to USRouted to USRouted to EURouted to EURouted to EUStays in the region
gpt-5-2025-08-07Routed to USRouted to USRouted to EUStays in the regionRouted to EURouted to USRouted to USRouted to EURouted to EURouted to EUStays in the region
gpt-5.4-mini-2026-03-17Routed to USRouted to USRouted to EUStays in the regionRouted to EURouted to USRouted to USN/ARouted to EURouted to EUStays in the region
Apps
gemini-2.0-flash-001N/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/A
gemini-2.5-flashRouted to EURouted to USRouted to EUStays in the regionRouted to EURouted to EURouted to EUStays in the regionRouted to EURouted to EUStays in the region
gpt-4o-2024-11-20Stays in the regionStays in the regionStays in the regionStays in the regionStays in the regionStays in the regionRouted to EURouted to EURouted to EUStays in the regionStays in the region
gpt-4o-mini-2024-07-18Stays in the region, as gpt-35-turbo-0125Stays in the region, as gpt-35-turbo-0125Routed to EUStays in the regionStays in the region, as gpt-35-turbo-0125Stays in the region, as gpt-4o-2024-08-06Routed to EUN/ARouted to EUStays in the region, as gpt-35-turbo-0125Stays in the region
Autopilot Chat
anthropic.claude-haiku-4-5-20251001-v1:0Routed to EURouted to EURouted to EUStays in the regionRouted to EURouted to EURouted to EURouted to EURouted to EURouted to EUStays in the region
anthropic.claude-opus-4-5-20251101-v1:0Routed to EURouted to EUN/AStays in the regionRouted to EURouted to EURouted to EUN/AN/ARouted to EUStays in the region
anthropic.claude-opus-4-6-v1Routed to EURouted to EURouted to EUStays in the regionRouted to EURouted to EURouted to EURouted to EURouted to EURouted to EUStays in the region
anthropic.claude-opus-4-7Routed to JARouted to JAN/AStays in the regionRouted to JAStays in the regionRouted to JAN/AN/ARouted to EUStays in the region
anthropic.claude-sonnet-4-5-20250929-v1:0Routed to JARouted to JAN/AStays in the regionRouted to JAStays in the regionRouted to JAN/AN/ARouted to EUStays in the region
anthropic.claude-sonnet-4-6Routed to JARouted to JARouted to EUStays in the regionRouted to JAStays in the regionRouted to JARouted to EURouted to EURouted to EUStays in the region
fw-kimi-k2.6Routed to USRouted to USN/ARouted to USRouted to USRouted to USRouted to USN/AN/ARouted to USStays in the region
gemini-2.0-flash-001Routed to JA, as gemini-2.5-flashRouted to US, as gemini-2.5-flashN/AStays in the region, as gemini-2.5-flashRouted to JA, as gemini-2.5-flashStays in the region, as gemini-2.5-flashRouted to JA, as gemini-2.5-flashN/AN/ARouted to EU, as gemini-2.5-flashStays in the region, as gemini-2.5-flash
gemini-2.5-flashRouted to JARouted to USRouted to EUStays in the regionRouted to JAStays in the regionRouted to JAStays in the regionRouted to EURouted to EUStays in the region
gemini-2.5-proRouted to JARouted to USRouted to EUStays in the regionRouted to JAStays in the regionRouted to JARouted to EURouted to EURouted to EUStays in the region
gemini-3-flash-previewRouted to USRouted to USN/ARouted to USRouted to USRouted to USRouted to USN/AN/ARouted to USStays in the region
gemini-3-pro-previewRouted to GLOBAL, as gemini-3.1-pro-previewRouted to GLOBAL, as gemini-3.1-pro-previewN/ARouted to GLOBAL, as gemini-3.1-pro-previewRouted to GLOBAL, as gemini-3.1-pro-previewRouted to GLOBAL, as gemini-3.1-pro-previewRouted to GLOBAL, as gemini-3.1-pro-previewN/AN/ARouted to GLOBAL, as gemini-3.1-pro-previewRouted to GLOBAL, as gemini-3.1-pro-preview
gemini-3.1-flash-image-previewRouted to GLOBALRouted to GLOBALN/ARouted to GLOBALRouted to GLOBALRouted to GLOBALRouted to GLOBALN/AN/ARouted to GLOBALRouted to GLOBAL
gemini-3.1-flash-lite-previewRouted to GLOBALRouted to GLOBALN/ARouted to GLOBALRouted to GLOBALRouted to GLOBALRouted to GLOBALN/AN/ARouted to GLOBALRouted to GLOBAL
gemini-3.1-pro-previewRouted to GLOBALRouted to GLOBALN/ARouted to GLOBALRouted to GLOBALRouted to GLOBALRouted to GLOBALN/AN/ARouted to GLOBALRouted to GLOBAL
gpt-4.1-2025-04-14Routed to EURouted to EUN/AStays in the regionRouted to EURouted to EURouted to EUN/AN/ARouted to EURouted to EU
gpt-4.1-mini-2025-04-14Routed to EURouted to EUN/AStays in the regionRouted to EURouted to EURouted to EUN/AN/ARouted to EUStays in the region
gpt-4o-2024-08-06Routed to JARouted to USN/AStays in the regionRouted to JAStays in the regionRouted to JAN/AN/ARouted to EUStays in the region
gpt-4o-mini-2024-07-18Routed to JA, as gpt-4o-2024-08-06Routed to USN/AStays in the regionRouted to JA, as gpt-4o-2024-08-06Stays in the region, as gpt-4o-2024-08-06Routed to JA, as gpt-4o-2024-08-06N/AN/ARouted to EURouted to EU
gpt-5-2025-08-07Routed to EURouted to EUN/ARouted to USRouted to EURouted to EURouted to EUN/AN/ARouted to USStays in the region
gpt-5-mini-2025-08-07Routed to EURouted to EUN/ARouted to USRouted to EURouted to EURouted to EUN/AN/ARouted to USStays in the region
gpt-5-nano-2025-08-07Routed to EURouted to EUN/ARouted to USRouted to EURouted to EURouted to EUN/AN/ARouted to USStays in the region
gpt-5.2-2025-12-11Routed to USRouted to USN/ARouted to USRouted to USRouted to USRouted to USN/AN/ARouted to USStays in the region
gpt-5.4-2026-03-05Routed to USRouted to USN/ARouted to USRouted to USRouted to USRouted to USN/AN/ARouted to USStays in the region
gpt-5.4-mini-2026-03-17Routed to USRouted to USN/ARouted to USRouted to USRouted to USRouted to USN/AN/ARouted to USStays in the region
anthropic.claude-3-7-sonnet-20250219-v1:0Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0N/ARouted to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0
gemini-2.5-flashRouted to EURouted to USRouted to EUStays in the regionRouted to EUStays in the regionRouted to EUStays in the regionRouted to EURouted to EUStays in the region
gemini-2.5-flash-liteRouted to USRouted to USRouted to EUStays in the regionRouted to EUStays in the region, as gemini-2.5-flashRouted to EURouted to EURouted to EURouted to EUStays in the region
gemini-2.5-proRouted to EURouted to USRouted to EUStays in the regionRouted to EUStays in the regionRouted to EURouted to EURouted to EURouted to EUStays in the region
gemini-embedding-001Routed to USRouted to USRouted to EUStays in the regionRouted to USRouted to USRouted to USRouted to EURouted to EURouted to EUStays in the region
gpt-4.1-2025-04-14Routed to USRouted to USN/AStays in the regionRouted to EURouted to USRouted to EUN/AN/ARouted to EUStays in the region
gpt-4.1-mini-2025-04-14Routed to USRouted to USN/AStays in the regionRouted to EURouted to USRouted to EUN/AN/ARouted to EUStays in the region
gpt-4o-2024-08-06Routed to JARouted to USRouted to EUStays in the regionRouted to JAStays in the regionRouted to JARouted to EURouted to EURouted to EUStays in the region
gpt-4o-mini-2024-07-18Routed to JA, as gpt-4o-2024-08-06Routed to USRouted to EUStays in the regionRouted to JA, as gpt-4o-2024-08-06Stays in the region, as gpt-4o-2024-08-06Routed to JA, as gpt-4o-2024-08-06N/ARouted to EURouted to EUStays in the region
gpt-5-2025-08-07Routed to USRouted to USN/AStays in the regionRouted to EURouted to USRouted to EUN/AN/ARouted to EUStays in the region
gpt-5-mini-2025-08-07Routed to USRouted to USN/AStays in the regionRouted to EURouted to USRouted to EUN/AN/ARouted to EUStays in the region
gpt-5-nano-2025-08-07Routed to USRouted to USN/AStays in the regionRouted to EURouted to USRouted to EUN/AN/ARouted to EUStays in the region
Autopilot for Everyone
anthropic.claude-3-5-sonnet-20240620-v1:0Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0N/ARouted to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0
anthropic.claude-3-5-sonnet-20241022-v2:0Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0N/ARouted to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0
anthropic.claude-3-7-sonnet-20250219-v1:0Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0N/ARouted to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0
anthropic.claude-3-haiku-20240307-v1:0Stays in the regionRouted to USRouted to EUStays in the regionRouted to USN/ARouted to USRouted to EURouted to EURouted to EUStays in the region
anthropic.claude-sonnet-4-20250514-v1:0N/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/A
anthropic.claude-sonnet-4-5-20250929-v1:0Stays in the regionRouted to USRouted to EUStays in the regionRouted to USStays in the regionRouted to USRouted to EURouted to EURouted to EUStays in the region
gemini-2.0-flash-001N/ARouted to US, as gemini-2.5-flashN/AStays in the region, as gemini-2.5-flashRouted to US, as gemini-2.5-flashN/ARouted to US, as gemini-2.5-flashN/AN/ARouted to EU, as gemini-2.5-flashStays in the region, as gemini-2.5-flash
gemini-2.5-flashStays in the regionRouted to USRouted to EUStays in the regionRouted to USStays in the regionRouted to USStays in the regionRouted to EURouted to EUStays in the region
gemini-2.5-flash-liteN/ARouted to USN/AStays in the regionRouted to USN/ARouted to USN/AN/ARouted to EUStays in the region
gpt-4.1-mini-2025-04-14Stays in the regionRouted to USRouted to EUStays in the regionRouted to EUStays in the regionRouted to EURouted to EURouted to EURouted to EUStays in the region
gpt-4o-2024-05-13Routed to EURouted to EURouted to EUStays in the regionRouted to EUStays in the region, as gpt-4o-2024-08-06Routed to EUN/ARouted to EURouted to EUStays in the region
gpt-4o-2024-08-06Routed to EURouted to EURouted to EUStays in the regionRouted to EUStays in the regionRouted to EURouted to EURouted to EURouted to EUStays in the region
gpt-4o-mini-2024-07-18Stays in the region, as gpt-4.1-mini-2025-04-14Routed to US, as gpt-4.1-mini-2025-04-14Routed to EU, as gpt-4.1-mini-2025-04-14Stays in the region, as gpt-4.1-mini-2025-04-14Routed to EU, as gpt-4.1-mini-2025-04-14Stays in the region, as gpt-4.1-mini-2025-04-14Routed to EU, as gpt-4.1-mini-2025-04-14Routed to EU, as gpt-4.1-mini-2025-04-14Routed to EU, as gpt-4.1-mini-2025-04-14Routed to EU, as gpt-4.1-mini-2025-04-14Stays in the region, as gpt-4.1-mini-2025-04-14
text-embedding-ada-002Stays in the regionStays in the regionStays in the regionStays in the regionStays in the regionStays in the regionRouted to EURouted to EUStays in the regionStays in the regionStays in the region
anthropic.claude-3-5-sonnet-20240620-v1:0N/AN/ARouted to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0N/AN/AN/AN/AN/ARouted to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0N/AN/A
anthropic.claude-3-7-sonnet-20250219-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0N/ARouted to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0
anthropic.claude-sonnet-4-5-20250929-v1:0Stays in the regionRouted to USRouted to EUStays in the regionRouted to EUStays in the regionRouted to EURouted to EURouted to EURouted to EUStays in the region
gemini-2.5-flashRouted to USRouted to USRouted to EUStays in the regionRouted to EUStays in the regionRouted to EUStays in the regionRouted to EURouted to EUStays in the region
gemini-2.5-proRouted to USRouted to USRouted to EUStays in the regionRouted to EURouted to USRouted to EURouted to EURouted to EURouted to EUStays in the region
gpt-4o-2024-08-06N/AN/ARouted to EUStays in the regionN/AN/AN/AN/ARouted to EUN/AN/A
gpt-4o-2024-11-20Stays in the regionStays in the regionStays in the regionStays in the regionStays in the regionStays in the regionRouted to JARouted to EURouted to EUStays in the regionStays in the region
gpt-5.1-2025-11-13Routed to USRouted to USRouted to EUStays in the regionRouted to EURouted to USRouted to EURouted to EURouted to EURouted to EUStays in the region
gpt-5.4N/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/A
gpt-5.4-2026-03-05Routed to USRouted to USRouted to EUStays in the regionRouted to EURouted to USRouted to EURouted to EURouted to EURouted to EUStays in the region
Coded agents
anthropic.claude-3-5-sonnet-20240620-v1:0N/AN/ARouted to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0N/AN/AN/AN/ARouted to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0N/AN/A
anthropic.claude-3-7-sonnet-20250219-v1:0N/AN/ARouted to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0N/AN/AN/AN/ARouted to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0N/AN/A
anthropic.claude-haiku-4-5-20251001-v1:0Routed to USRouted to USN/AStays in the regionRouted to EURouted to USRouted to USN/AN/ARouted to EUStays in the region
anthropic.claude-opus-4-7N/AN/AN/AStays in the regionN/AN/AN/AN/AN/AN/AStays in the region
anthropic.claude-sonnet-4-20250514-v1:0Routed to USRouted to USN/AStays in the regionRouted to EURouted to USRouted to USN/AN/ARouted to EUStays in the region
anthropic.claude-sonnet-4-5-20250929-v1:0Stays in the regionRouted to USN/AStays in the regionRouted to EUStays in the regionRouted to USRouted to EUN/ARouted to EUStays in the region
claude-opus-4-5@20251101Routed to USRouted to USN/AStays in the regionRouted to EURouted to USStays in the regionRouted to EUN/ARouted to EUStays in the region
gemini-2.5-flashRouted to EURouted to EUN/AStays in the regionRouted to EURouted to EURouted to EUStays in the regionN/ARouted to EUStays in the region
gemini-2.5-proRouted to EURouted to EUN/AStays in the regionRouted to EURouted to EURouted to EUN/AN/ARouted to EUStays in the region
gpt-4N/AN/AStays in the region, as gpt-4o-2024-11-20N/AN/AN/AN/ARouted to EU, as gpt-4o-2024-11-20Routed to EU, as gpt-4o-2024-11-20N/AN/A
gpt-4.1-mini-2025-04-14Routed to USRouted to USN/AStays in the regionStays in the regionStays in the regionRouted to USN/AN/ARouted to EUStays in the region
gpt-4o-2024-05-13Routed to USRouted to USN/AStays in the regionRouted to EUStays in the region, as gpt-4o-2024-08-06Routed to USN/AN/ARouted to EUStays in the region
gpt-4o-2024-08-06Routed to USRouted to USRouted to EUStays in the regionRouted to EUStays in the regionRouted to USRouted to EURouted to EURouted to EUStays in the region
gpt-4o-2024-11-20-community-agentsRouted to EURouted to EUN/AStays in the regionRouted to EURouted to EURouted to EURouted to EUN/ARouted to EURouted to EU
gpt-5-mini-2025-08-07Routed to USRouted to USRouted to EUStays in the regionRouted to EURouted to USRouted to USRouted to EURouted to EURouted to EUStays in the region
gpt-5.1-2025-11-13Routed to USRouted to USN/AStays in the regionRouted to EURouted to USRouted to USN/AN/ARouted to EUStays in the region
gpt-5.2-2025-12-11Routed to USRouted to USN/AStays in the regionRouted to USRouted to USRouted to USRouted to USN/ARouted to USStays in the region
gpt-5.4-2026-03-05N/AN/AN/AStays in the regionN/AN/AN/AN/AN/AN/AStays in the region
gpt-5.5-2026-04-23N/AN/AN/AStays in the regionN/AN/AN/AN/AN/AN/AStays in the region
text-embedding-3-largeStays in the regionStays in the regionN/AStays in the regionStays in the regionStays in the regionRouted to USStays in the regionN/AStays in the regionStays in the region
Context Grounding
anthropic.claude-3-7-sonnet-20250219-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0N/ARouted to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0
anthropic.claude-3-haiku-20240307-v1:0Stays in the regionStays in the regionRouted to EUStays in the regionStays in the regionRouted to USRouted to USN/ARouted to EUStays in the regionStays in the region
gemini-1.5-flash-001N/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/A
gemini-1.5-pro-001N/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/A
gemini-2.5-flashRouted to USRouted to USRouted to EUStays in the regionRouted to EURouted to USRouted to EUStays in the regionRouted to EURouted to EUStays in the region
gemini-2.5-flash-liteRouted to USRouted to USRouted to EUStays in the regionRouted to EURouted to USRouted to EURouted to EURouted to EURouted to EUStays in the region
gemini-2.5-proN/AN/ARouted to EUStays in the regionN/AN/AN/ARouted to EURouted to EUN/AStays in the region
gemini-proN/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/A
gpt-35-turbo-1106Stays in the region, as gpt-35-turbo-0125Stays in the region, as gpt-35-turbo-0125Routed to EU, as gpt-4o-mini-2024-07-18Stays in the region, as gpt-4o-mini-2024-07-18Stays in the region, as gpt-35-turbo-0125Stays in the region, as gpt-4o-2024-08-06Routed to EU, as gpt-4o-mini-2024-07-18N/ARouted to EU, as gpt-4o-mini-2024-07-18Stays in the region, as gpt-35-turbo-0125Stays in the region, as gpt-4o-mini-2024-07-18
gpt-4.1-2025-04-14N/AN/ARouted to EUStays in the regionN/AN/AN/AN/ARouted to EUN/AStays in the region
gpt-4.1-mini-2025-04-14N/AN/ARouted to EUStays in the regionN/AN/AN/AN/ARouted to EUN/AStays in the region
gpt-4o-2024-08-06Routed to EURouted to EURouted to EUStays in the regionRouted to EUStays in the regionRouted to EUN/ARouted to EURouted to EUStays in the region
gpt-4o-2024-11-20Stays in the regionStays in the regionStays in the regionStays in the regionStays in the regionStays in the regionRouted to EUN/ARouted to EUStays in the regionStays in the region
gpt-5-2025-08-07N/AN/ARouted to EUStays in the regionN/AN/AN/AN/ARouted to EUN/AStays in the region
text-embedding-3-largeStays in the regionStays in the regionStays in the regionStays in the regionStays in the regionStays in the regionRouted to EUStays in the regionStays in the regionStays in the regionStays in the region
Document Understanding
gemini-2.5-flashRouted to USRouted to USRouted to EUStays in the regionRouted to USRouted to USRouted to USStays in the regionRouted to EURouted to USStays in the region
gpt-4-32kStays in the region, as gpt-4o-2024-11-20Stays in the region, as gpt-4o-2024-11-20Stays in the region, as gpt-4o-2024-11-20Stays in the region, as gpt-4o-2024-11-20Stays in the region, as gpt-4o-2024-11-20Stays in the region, as gpt-4o-2024-11-20Routed to EU, as gpt-4o-2024-11-20N/ARouted to EU, as gpt-4o-2024-11-20Stays in the region, as gpt-4o-2024-11-20Stays in the region, as gpt-4o-2024-11-20
gpt-5.1-2025-11-13N/AN/AN/AStays in the regionN/AN/AN/AN/AN/AN/AStays in the region
GenAI Activities
anthropic.claude-3-5-sonnet-20241022-v2:0Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0N/ARouted to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0
anthropic.claude-3-7-sonnet-20250219-v1:0Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0N/ARouted to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0
anthropic.claude-3-haiku-20240307-v1:0Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0N/ARouted to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0
anthropic.claude-haiku-4-5-20251001-v1:0Routed to USRouted to USN/AStays in the regionRouted to USRouted to USRouted to USRouted to EUN/ARouted to USStays in the region
anthropic.claude-opus-4-20250514-v1:0N/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/A
anthropic.claude-opus-4-5-20251101-v1:0N/AN/AN/AStays in the regionN/ARouted to USN/AN/AN/AN/AStays in the region
anthropic.claude-sonnet-4-20250514-v1:0Routed to USRouted to USRouted to EUStays in the regionRouted to USRouted to USRouted to USN/ARouted to EURouted to USStays in the region
anthropic.claude-sonnet-4-5-20250929-v1:0Stays in the regionRouted to USRouted to EUStays in the regionRouted to USStays in the regionRouted to USRouted to EURouted to EURouted to USStays in the region
anthropic.claude-sonnet-4-6Stays in the regionRouted to USN/AStays in the regionRouted to EUStays in the regionRouted to EUN/AN/ARouted to EUStays in the region
gemini-1.0-proStays in the region, as gemini-2.5-flashRouted to EU, as gemini-2.5-flashRouted to EU, as gemini-2.5-flashStays in the region, as gemini-2.5-flashRouted to EU, as gemini-2.5-flashRouted to EU, as gemini-2.5-flashRouted to EU, as gemini-2.5-flashN/ARouted to EU, as gemini-2.5-flashRouted to EU, as gemini-2.5-flashStays in the region, as gemini-2.5-flash
gemini-1.0-pro-001Stays in the region, as gemini-2.5-flashRouted to EU, as gemini-2.5-flashRouted to EU, as gemini-2.5-flashStays in the region, as gemini-2.5-flashRouted to EU, as gemini-2.5-flashRouted to EU, as gemini-2.5-flashRouted to EU, as gemini-2.5-flashN/ARouted to EU, as gemini-2.5-flashRouted to EU, as gemini-2.5-flashStays in the region, as gemini-2.5-flash
gemini-1.5-flash-001Stays in the regionRouted to EU, as gemini-2.5-flashRouted to EU, as gemini-2.5-flashStays in the region, as gemini-2.5-flashRouted to EU, as gemini-2.5-flashRouted to EU, as gemini-2.5-flashRouted to EU, as gemini-2.5-flashN/ARouted to EU, as gemini-2.5-flashRouted to EU, as gemini-2.5-flashStays in the region, as gemini-2.5-flash
gemini-1.5-pro-001Stays in the regionRouted to EU, as gemini-2.5-flashRouted to EU, as gemini-2.5-flashStays in the region, as gemini-2.5-flashRouted to EU, as gemini-2.5-flashRouted to EU, as gemini-2.5-flashRouted to EU, as gemini-2.5-flashN/ARouted to EU, as gemini-2.5-flashRouted to EU, as gemini-2.5-flashStays in the region, as gemini-2.5-flash
gemini-2.0-flash-001Stays in the region, as gemini-2.5-flashRouted to EU, as gemini-2.5-flashRouted to EU, as gemini-2.5-flashStays in the region, as gemini-2.5-flashRouted to EU, as gemini-2.5-flashRouted to EU, as gemini-2.5-flashRouted to EU, as gemini-2.5-flashRouted to EU, as gemini-2.5-flashRouted to EU, as gemini-2.5-flashRouted to EU, as gemini-2.5-flashStays in the region, as gemini-2.5-flash
gemini-2.5-flashStays in the regionStays in the regionRouted to EUStays in the regionRouted to EUStays in the regionRouted to EUStays in the regionRouted to EUStays in the regionStays in the region
gemini-2.5-proRouted to EURouted to EURouted to EUStays in the regionRouted to EUStays in the regionRouted to EURouted to EURouted to EURouted to EUStays in the region
gemini-proStays in the region, as gemini-2.5-flashRouted to EU, as gemini-2.5-flashRouted to EU, as gemini-2.5-flashStays in the region, as gemini-2.5-flashRouted to EU, as gemini-2.5-flashRouted to EU, as gemini-2.5-flashRouted to EU, as gemini-2.5-flashN/ARouted to EU, as gemini-2.5-flashRouted to EU, as gemini-2.5-flashStays in the region, as gemini-2.5-flash
gpt-35-turboStays in the region, as gpt-35-turbo-0125Stays in the region, as gpt-35-turbo-0125Routed to EU, as gpt-5.1-2025-11-13Stays in the region, as gpt-4o-mini-2024-07-18Stays in the region, as gpt-35-turbo-0125Stays in the region, as gpt-4o-2024-08-06Routed to EU, as gpt-4o-mini-2024-07-18N/ARouted to EU, as gpt-5.1-2025-11-13Stays in the region, as gpt-35-turbo-0125Stays in the region, as gpt-4o-mini-2024-07-18
gpt-35-turbo-0125Routed to CAStays in the regionRouted to EU, as gpt-5.1-2025-11-13Stays in the region, as gpt-4o-mini-2024-07-18Stays in the regionStays in the region, as gpt-4o-2024-08-06Routed to EU, as gpt-4o-mini-2024-07-18N/ARouted to EU, as gpt-5.1-2025-11-13Stays in the regionStays in the region, as gpt-4o-mini-2024-07-18
gpt-35-turbo-1106Stays in the region, as gpt-35-turbo-0125Stays in the region, as gpt-35-turbo-0125Routed to EU, as gpt-5.1-2025-11-13Stays in the region, as gpt-4o-mini-2024-07-18Stays in the region, as gpt-35-turbo-0125Stays in the region, as gpt-4o-2024-08-06Routed to EU, as gpt-4o-mini-2024-07-18N/ARouted to EU, as gpt-5.1-2025-11-13Stays in the region, as gpt-35-turbo-0125Stays in the region, as gpt-4o-mini-2024-07-18
gpt-35-turbo-16kN/AN/AN/AStays in the region, as gpt-5-mini-2025-08-07N/AN/AN/AN/AN/AN/AN/A
gpt-4Routed to EU, as gpt-5.1-2025-11-13Stays in the region, as gpt-4o-2024-11-20Stays in the region, as gpt-5.1-2025-11-13Stays in the region, as gpt-4o-2024-11-20Stays in the region, as gpt-4o-2024-11-20Stays in the region, as gpt-4o-2024-11-20Routed to EU, as gpt-4o-2024-11-20N/ARouted to EU, as gpt-5.1-2025-11-13Stays in the region, as gpt-4o-2024-11-20Stays in the region, as gpt-4o-2024-11-20
gpt-4-1106-PreviewRouted to EU, as gpt-5.1-2025-11-13Stays in the region, as gpt-4o-2024-11-20Stays in the region, as gpt-5.1-2025-11-13Stays in the region, as gpt-4o-2024-11-20Stays in the region, as gpt-4o-2024-11-20Stays in the region, as gpt-4o-2024-11-20Routed to EU, as gpt-4o-2024-11-20N/ARouted to EU, as gpt-5.1-2025-11-13Stays in the region, as gpt-4o-2024-11-20Stays in the region, as gpt-4o-2024-11-20
gpt-4-32kRouted to EU, as gpt-5.1-2025-11-13Stays in the region, as gpt-4o-2024-11-20Stays in the region, as gpt-5.1-2025-11-13Stays in the region, as gpt-4o-2024-11-20Stays in the region, as gpt-4o-2024-11-20Stays in the region, as gpt-4o-2024-11-20Routed to EU, as gpt-4o-2024-11-20N/ARouted to EU, as gpt-5.1-2025-11-13Stays in the region, as gpt-4o-2024-11-20Stays in the region, as gpt-4o-2024-11-20
gpt-4.1-nano-2025-04-14N/AN/ARouted to EUStays in the regionN/AN/AN/AN/ARouted to EUN/AStays in the region
gpt-4o-2024-05-13Routed to EU, as gpt-5.1-2025-11-13Routed to EURouted to EU, as gpt-5.1-2025-11-13Stays in the regionRouted to EUStays in the region, as gpt-4o-2024-08-06Routed to EUN/ARouted to EU, as gpt-5.1-2025-11-13Routed to EUStays in the region
gpt-4o-2024-08-06Routed to EU, as gpt-5.1-2025-11-13Routed to EURouted to EU, as gpt-5.1-2025-11-13Stays in the regionRouted to EUStays in the regionRouted to EURouted to EURouted to EU, as gpt-5.1-2025-11-13Routed to EUStays in the region
gpt-4o-2024-11-20Routed to EU, as gpt-5.1-2025-11-13Stays in the regionStays in the region, as gpt-5.1-2025-11-13Stays in the regionStays in the regionStays in the regionRouted to EURouted to EURouted to EU, as gpt-5.1-2025-11-13Stays in the regionStays in the region
gpt-4o-mini-2024-07-18Stays in the region, as gpt-35-turbo-0125Stays in the region, as gpt-35-turbo-0125Routed to EU, as gpt-5.1-2025-11-13Stays in the regionStays in the region, as gpt-35-turbo-0125Stays in the region, as gpt-4o-2024-08-06Routed to EUN/ARouted to EU, as gpt-5.1-2025-11-13Stays in the region, as gpt-35-turbo-0125Stays in the region
gpt-5-nano-2025-08-07N/AN/ARouted to EUStays in the regionN/AN/AN/AN/ARouted to EUN/AStays in the region
gpt-5.1-2025-11-13Routed to USRouted to USRouted to EUStays in the regionRouted to EURouted to USRouted to USRouted to EURouted to EURouted to EUStays in the region
gpt-5.2-2025-12-11Routed to USRouted to USN/ARouted to USRouted to USRouted to USRouted to USRouted to USN/ARouted to USStays in the region
gpt-5.4N/AN/AN/AStays in the regionN/AN/AN/AN/AN/AN/AStays in the region
gpt-5.4-2026-03-05Routed to USRouted to USN/AStays in the regionRouted to USRouted to USRouted to USRouted to EUN/ARouted to USStays in the region
gpt-5.4-mini-2026-03-17N/AN/AN/AStays in the regionN/AN/AN/AN/AN/ARouted to USStays in the region
gpt-5.5-2026-04-23N/AN/AN/AStays in the regionN/AN/ARouted to USN/AN/ARouted to USStays in the region
Healing Agent
IXP
Note:
IXP - Unstructured and complex documents and IXP - Communications Mining use the same routing.
gemini-2.5-flashStays in the regionStays in the regionRouted to EUStays in the regionRouted to EUStays in the regionRouted to EUStays in the regionRouted to EURouted to EUStays in the region
gemini-2.5-proRouted to USRouted to USRouted to EUStays in the regionRouted to EUStays in the regionRouted to EURouted to EURouted to EURouted to EUStays in the region
gemini-3.1-pro1N/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/A
gpt-35-turboStays in the region, as gpt-4o-2024-11-20Stays in the region, as gpt-4o-2024-11-20Routed to EU, as gpt-4o-mini-2024-07-18Stays in the region, as gpt-4o-mini-2024-07-18Routed to EU, as gpt-4o-2024-11-20Stays in the region, as gpt-4o-2024-08-06Routed to EU, as gpt-4o-2024-11-20N/ARouted to EU, as gpt-4o-mini-2024-07-18Routed to EU, as gpt-4o-2024-11-20Stays in the region, as gpt-4o-mini-2024-07-18
gpt-4-1106-PreviewStays in the region, as gpt-4o-2024-11-20Stays in the region, as gpt-4o-2024-11-20Stays in the region, as gpt-4o-2024-11-20Stays in the region, as gpt-4o-2024-11-20Routed to EU, as gpt-4o-2024-11-20Stays in the region, as gpt-4o-2024-11-20Routed to EU, as gpt-4o-2024-11-20N/ARouted to EU, as gpt-4o-2024-11-20Routed to EU, as gpt-4o-2024-11-20Stays in the region, as gpt-4o-2024-11-20
gpt-4.1-2025-04-14N/AN/AN/AStays in the regionN/AN/AN/AN/AN/AN/AStays in the region
gpt-4o-2024-05-13Stays in the region, as gpt-4o-2024-11-20Stays in the region, as gpt-4o-2024-11-20Routed to EUStays in the regionRouted to EUStays in the region, as gpt-4o-2024-08-06Routed to EUN/ARouted to EURouted to EUStays in the region
gpt-4o-2024-08-06Stays in the region, as gpt-4o-2024-11-20Stays in the region, as gpt-4o-2024-11-20Routed to EUStays in the regionRouted to EUStays in the regionRouted to EURouted to EURouted to EURouted to EUStays in the region
gpt-4o-2024-11-20Stays in the regionStays in the regionStays in the regionStays in the regionRouted to EUStays in the regionRouted to EURouted to EURouted to EURouted to EUStays in the region
gpt-4o-mini-2024-07-18Stays in the region, as gpt-4o-2024-11-20Stays in the region, as gpt-4o-2024-11-20Routed to EUStays in the regionRouted to EUStays in the region, as gpt-4o-2024-08-06Routed to EUN/ARouted to EURouted to EUStays in the region
gpt-5-2025-08-07N/AN/AN/AStays in the regionN/AN/AN/AN/AN/AN/AStays in the region
gpt-5-mini-2025-08-07N/AN/AN/AStays in the regionN/AN/AN/AN/AN/AN/AStays in the region
gpt-5-nano-2025-08-07N/AN/AN/AStays in the regionN/AN/AN/AN/AN/AN/AStays in the region
gpt-5.11N/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/A
gpt-5.4-2026-03-051N/AN/AN/AN/AN/AN/AN/AN/AN/AN/AN/A
Process Mining
gpt-4.1-mini-2025-04-14Stays in the regionRouted to EUN/AStays in the regionStays in the regionStays in the regionRouted to EURouted to EUN/ARouted to EUStays in the region
ScreenPlay
anthropic.claude-haiku-4-5-20251001-v1:0Routed to USRouted to USN/AStays in the regionRouted to USRouted to USRouted to USRouted to EUN/ARouted to EUStays in the region
anthropic.claude-sonnet-4-20250514-v1:0Routed to USRouted to USN/AStays in the regionRouted to USRouted to USRouted to USN/AN/ARouted to USStays in the region
anthropic.claude-sonnet-4-5-20250929-v1:0Routed to USRouted to USN/AStays in the regionRouted to USRouted to USRouted to USRouted to EUN/ARouted to EUStays in the region
computer-use-preview-2025-03-11Routed to EURouted to EURouted to EUStays in the regionRouted to EURouted to EURouted to EUN/ARouted to EURouted to EURouted to EU
gemini-2.0-flash-001Routed to US, as gemini-2.5-flashRouted to US, as gemini-2.5-flashN/AStays in the region, as gemini-2.5-flashRouted to EU, as gemini-2.5-flashRouted to US, as gemini-2.5-flashRouted to EU, as gemini-2.5-flashN/AN/ARouted to EU, as gemini-2.5-flashStays in the region, as gemini-2.5-flash
gpt-4.1-2025-04-14Routed to USRouted to USRouted to EUStays in the regionRouted to EURouted to USRouted to EURouted to EURouted to EURouted to EUStays in the region
gpt-4.1-mini-2025-04-14Routed to USRouted to USRouted to EUStays in the regionRouted to EURouted to USRouted to EURouted to EURouted to EURouted to EUStays in the region
gpt-4o-mini-2024-07-18Stays in the region, as gpt-35-turbo-0125Stays in the region, as gpt-35-turbo-0125Routed to EUStays in the regionStays in the region, as gpt-35-turbo-0125Routed to USRouted to EUN/ARouted to EUStays in the region, as gpt-35-turbo-0125Stays in the region
gpt-5-2025-08-07Routed to USRouted to USN/AStays in the regionRouted to EURouted to USRouted to EURouted to EUN/ARouted to EUStays in the region
gpt-5-mini-2025-08-07Routed to USRouted to USN/AStays in the regionRouted to EURouted to USRouted to EURouted to EUN/ARouted to EUStays in the region
gpt-5.4-2026-03-05Routed to USRouted to USN/AStays in the regionRouted to EURouted to USRouted to EUN/AN/ARouted to EUStays in the region
gpt-5.4-mini-2026-03-17Routed to USRouted to USN/AStays in the regionRouted to EURouted to USRouted to EUN/AN/ARouted to EUStays in the region
gpt-5.5-2026-04-23Routed to USRouted to USN/AStays in the regionRouted to EURouted to USRouted to EUN/AN/ARouted to EUStays in the region
Studio Web
text-embedding-ada-002Stays in the regionStays in the regionStays in the regionStays in the regionStays in the regionStays in the regionRouted to EUN/AStays in the regionStays in the regionStays in the region
Task Mining
gpt-4o-2024-05-13Routed to EURouted to EURouted to EUStays in the regionRouted to EUStays in the region, as gpt-4o-2024-08-06Routed to EURouted to EURouted to EURouted to EUStays in the region
1 Available in UiPath as a public preview.
For general information on Data residency, refer to Data residency.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
