- Getting started
- Data security and compliance
- Organizations
- Authentication and security
- Allowing or restricting basic authentication
- Microsoft Entra ID integration for Automation Cloud and Automation Cloud Public Sector
- Microsoft Entra ID integration for Automation Cloud Dedicated
- Local users password complexity requirements
- Licensing
- About licensing
- Unified Pricing: Licensing plan framework
- Flex: Licensing plan framework
- Activating your Enterprise license
- Upgrading and downgrading licenses
- License migration
- Requesting a service trial
- Assigning licenses to tenants
- Assigning user licenses
- Deallocating user licenses
- Monitoring license allocation
- License overallocation
- Licensing notifications
- User license management
- Tenants and services
- Accounts and roles
- AI Trust Layer
- External applications
- Notifications
- Logging
- Data Export
- Testing in your organization
- Troubleshooting
- Migrating to Automation Cloud
Set up Microsoft Entra ID integration for Automation Cloud and Automation Cloud Public Sector to enable SSO and automated user provisioning.
This procedure applies only for Automation Cloud and Automation Cloud Public Sector
Getting started
Benefits
Integrating Microsoft Entra ID integration with UiPath offers the following benefits:
- Single sign-on (SSO): Allow users to access an organization with their Microsoft Entra ID credentials.
- Simplified user management: Manage access using existing Microsoft Entra ID users and groups.
- Enhanced security: Apply Microsoft Entra ID features such as multifactor authentication, conditional access, and privileged identity management.
- Seamless transition: Migrate from local accounts without disruption, as long as email addresses match.
Limitations and considerations
Keep the following limitations in mind when using Microsoft Entra ID integration:
UiPath supports integration only with the Microsoft Entra ID service in the Microsoft Azure commercial cloud. The Microsoft Azure Government cloud version of Microsoft Entra ID is not supported.
When an integration uses delegated access only as its access scope, Microsoft Entra ID requires the user to be present during directory evaluation. Because unattended automations and personal access tokens run without a user present, the following limitations apply:
- Microsoft Entra ID directory users cannot inherit group-based permissions when running unattended automations or when using personal access tokens.
- If access to the organization is restricted through Microsoft Entra ID groups, unattended robots cannot access the organization on behalf of users.
To work around these limitations without granting app-only permissions, you can enable Use cached user tokens for group membership checks in your Microsoft Entra ID configuration. The availability of this feature depends on the cloud platform that you are using. For details, refer to the Feature availability page, specifically the Use cached user tokens for group membership checks row.
User account management: You can only manage directory users and groups in Microsoft Entra ID. These accounts appear in your organization only when you search for them or assign permissions.
Application custom keys: Microsoft Entra ID integration uses the OIDC protocol but does not support application custom keys passed through the
appidquery parameter, as described in Microsoft's access tokens documentation. -
You must not name your local UiPath groups the same as Microsoft Entra ID directory groups. Doing so can lead to conflicts in permission evaluation and group-based access assignment.
Before you begin
Before you configure Microsoft Entra ID integration, ensure that you have the following:
- An organization with an Enterprise license, in either the Standard or Enterprise tier.
- An organization that meets one of the following licensing requirements:
- Unified Pricing: Requires an Enterprise or Standard plan
- Flex: Requires an Enterprise plan, either the Standard or Enterprise tier
- Administrator permissions in the organization.
- Coordination with a Microsoft Entra ID administrator who has one of the following roles:
- Cloud Application Administrator
- Application Administrator
- Any role that can grant administrator consent to Microsoft Entra ID applications
- A Microsoft Entra ID account that uses the same email address as your UiPath administrator account (for testing)
- A supported version of UiPath Studio and Assistant, as specified in the product lifecycle documentation.
Step 1: Preparing your organization for account linking
When you enable the Microsoft Entra ID integration, UiPath automatically links accounts that have matching email addresses. The first time a user signs in with Microsoft Entra ID, UiPath creates a directory user account and assigns it the same permissions as the matching local account.
Before you enable the Microsoft Entra ID integration, remove any inactive users from the organization. This helps prevent permission escalation if those email addresses are reassigned to different users in your organization.
Step 2: Configuring the Microsoft Entra ID integration
Feature availability depends on the cloud platform that you use. For details, refer to the Feature availability page.
This Microsoft Entra ID integration supports both delegated access and app-only access models, using a combination of the OAuth 2.0 authorization code grant flow and OAuth 2.0 client credentials flow.
Configuring the Microsoft Entra integration allows UiPath to do the following:
- Sign in users with Microsoft Entra ID credentials.
- Read user profiles and group memberships from your Microsoft Entra ID directory.
- Apply access controls based on Microsoft Entra ID group assignments.
To integrate with Microsoft Entra ID, you must set up a Microsoft Entra ID application that represents your organization in your Microsoft Entra ID tenant.
Configuration methods
To integrate with Microsoft Entra ID, you must configure the Microsoft Entra ID application that represents your organization in your Microsoft Entra ID tenant.
You can choose one of the following configuration methods:
- (Recommended) Automated setup: Use the UiPath-managed Microsoft Entra ID application (multi-tenant model) for the following benefits:
- No secrets or certificates to manage.
- Quick and reliable setup.
- UiPath maintains the Microsoft Entra ID application for you.
- Manual setup with a custom Microsoft Entra ID application registration: Use your own Microsoft Entra ID application and manage its configuration manually, with the following considerations:
- You must create and manage application credentials.
- Credentials expire and require periodic updates.
- If credentials are not updated before they expire, users are blocked from signing in.
You can choose one of the following access scopes:
- Delegated and app-only access (Recommended): Allows UiPath services to evaluate group membership both when the user is present and in offline scenarios, such as unattended automations and service-to-service (S2S) scenarios.
- Delegated access: Restricts group evaluation to interactive sessions. Permissions can only be validated when the user is actively signed in.
About the UiPath-managed Microsoft Entra ID application
UiPath uses a pre-registered, multi-tenant Microsoft Entra ID application. This removes the need to create and maintain your own application registration and credentials. The details of this application are:
- Name: UiPath Entra ID Integration
- Client ID:
4ca9aa42-b0ea-4ceb-b2b1-17fa40827280 - Application scopes:
- Entra ID:
email,openid,profile,GroupMember.Read.All,User.Read,User.ReadBasic.All,User.Read.All(optional). - CMK Entra ID integration:
email,openid,profile, andoffline access.
- Entra ID:
- Redirect URI:
https://cloud.uipath.com/portal/grant-consenthttps://govcloud.uipath.us/portal/grant-consent
- Consent URLs (for admin approval): If you see a Needs admin approval message, a Microsoft Entra ID administrator can grant tenant-wide consent by navigating to one of the following URLs:
- Delegated and app-only access (multi-tenant):
https://login.microsoftonline.com/organizations/v2.0/adminconsent?client_id=4ca9aa42-b0ea-4ceb-b2b1-17fa40827280&redirect_uri=https%3A%2F%2Fcloud.uipath.com%2Fportal_%2Fgrant-consent&state=1234&scope=https://graph.microsoft.com/.default - Delegated and app-only access (single-tenant):
https://login.microsoftonline.com/{TENANT_ID}/v2.0/adminconsent?client_id={APPLICATION_ID}&redirect_uri=https%3A%2F%2Fcloud.uipath.com%2Fportal_%2Fgrant-consent&state=1234&scope=https://graph.microsoft.com/.default - Delegated access (multi-tenant):
https://login.microsoftonline.com/common/oauth2/v2.0/authorize?scope=email+GroupMember.Read.All+openid+profile+User.Read+User.ReadBasic.All&prompt=select_account&response_type=code&redirect_uri=https%3A%2F%2Fcloud.uipath.com%2Fportal_%2Fgrant-consent&client_id=4ca9aa42-b0ea-4ceb-b2b1-17fa40827280&state=1234 - Delegated access (single-tenant):
https://login.microsoftonline.com/{TENANT_ID}/oauth2/v2.0/authorize?scope=email+GroupMember.Read.All+openid+profile+User.Read+User.ReadBasic.All&prompt=select_account&response_type=code&redirect_uri=https%3A%2F%2Fcloud.uipath.com%2Fportal_%2Ftestconnection&state=1234&client_id={APPLICATION_ID}
Note:For single-tenant configurations, replace
{TENANT_ID}with your Directory (tenant) ID and{APPLICATION_ID}with your Application (client) ID. - Delegated and app-only access (multi-tenant):
When you select the Delegated access scope, Microsoft Entra ID requires the user to be present during directory evaluation. As a result, group membership cannot be resolved when no user is signed in, such as during unattended automations and service-to-service (S2S) scenarios.
To support these scenarios without granting app-only permissions, select Use cached user tokens for group membership checks in unattended automations. With this option enabled, UiPath reuses the user's most recent Microsoft Entra ID access and refresh tokens to evaluate group membership in unattended automations and S2S scenarios where the user is not actively signed in. The result is coverage comparable to the Delegated and app-only access scope, without requiring app-only permissions.
This option appears only when the Delegated access scope is selected. It is not needed for the Delegated and app-only access scope, where group membership resolution in unattended and S2S scenarios is already handled by application permissions.
Default behavior
The default state of this option depends on whether the directory connection is new or existing:
- New directory connections: Selected by default. Clear the checkbox to opt out.
- Existing directory connections: Cleared by default. Open the configuration page and select the checkbox to opt in.
Token expiration
UiPath uses the cached access token until it expires, then uses the cached refresh token to obtain a new one. If both the access token and the refresh token have expired, UiPath can no longer query Microsoft Entra ID on the user's behalf, and group membership results for that user may be incomplete. To restore complete results, the user must sign in again by selecting Continue with Enterprise SSO on the main login page or by navigating to the organization-specific URL. The next sign-in refreshes the cached tokens, and subsequent group membership checks return complete results.
Conditional Access policy considerations
The cached user tokens feature does not bypass Microsoft Entra ID Conditional Access. It only allows UiPath to reuse tokens that the user has already obtained through interactive sign-in. If a Conditional Access policy prevents the cached token from being refreshed, group membership results for that user may be incomplete until the user signs in again using Continue with Enterprise SSO and satisfies all applicable Conditional Access policies.
The policy categories most likely to affect cached tokens are:
- Sign-in frequency: If a policy requires users to re-authenticate at short intervals, the cached refresh token is rejected once that interval is exceeded.
- Multifactor authentication at token refresh: Refresh requests are non-interactive and cannot prompt the user for MFA. Policies that require MFA on every token refresh fail in this flow.
- Risk-based policies and Continuous Access Evaluation (CAE): These can revoke active tokens at any time based on changes in user, device, or session risk.
To minimize interference without weakening your security posture:
- For users who run unattended automations, balance sign-in frequency requirements with the operational impact of frequent re-authentication.
- Apply MFA requirements at interactive sign-in, not at token refresh.
- Monitor the Clear Cached Entra ID User Token audit event. Frequent occurrences for the same user typically indicate that a Conditional Access policy is preventing token refresh. See Audit events.
Audit events
UiPath emits two audit events related to cached user tokens. Use them to track when group membership results may be incomplete and when access is restored:
| Event | When it is emitted |
| Cache Entra ID User Token | A Microsoft Entra ID token is cached for a user who did not previously have one. This typically happens when the user signs in using Continue with Enterprise SSO after a previously cached token was cleared. The event confirms that subsequent group membership checks for the user will return complete results. |
| Clear Cached Entra ID User Token | A user's cached Microsoft Entra ID token is removed because Microsoft Entra ID rejected the token refresh and the cached token can no longer be used. This typically happens when both tokens have expired, the refresh token has been revoked, or a Conditional Access policy prevents the refresh. After this event, group membership results for the user may be incomplete until the user signs in again using Continue with Enterprise SSO. |
Automated setup with UiPath-managed Microsoft Entra ID application (Recommended)
To configure Microsoft ID integration using the UiPath-managed application, consent must be granted by a Microsoft Entra ID administrator before completing setup in your organization.
Use this method if you want to simplify configuration and avoid managing secrets or certificates. UiPath recommends this approach for most organizations.
1. Grant Microsoft Entra ID consent
Have a Microsoft Entra ID administrator grant consent by navigating to one of the following URLs and signing in. During sign-in, the administrator must select Consent on behalf of your organization, and then select Accept.
Use the URL that corresponds to the access scope you plan to configure in your organization:
If your Microsoft Entra ID tenant allows consent requests, an organization administrator can use these URLs to trigger a consent request. In this case, a Microsoft Entra ID administrator must approve the request before the configuration can continue.
- Multi-tenant:
https://login.microsoftonline.com/organizations/v2.0/adminconsent?client_id=4ca9aa42-b0ea-4ceb-b2b1-17fa40827280&redirect_uri=https%3A%2F%2Fcloud.uipath.com%2Fportal_%2Fgrant-consent&state=1234&scope=https://graph.microsoft.com/.default - Single-tenant:
- Multi-tenant:
- Delegated access only:
- Multi-tenant:
https://login.microsoftonline.com/common/oauth2/v2.0/authorize?scope=email+GroupMember.Read.All+openid+profile+User.Read+User.ReadBasic.All&prompt=select_account&response_type=code&redirect_uri=https%3A%2F%2Fcloud.uipath.com%2Fportal_%2Fgrant-consent&client_id=4ca9aa42-b0ea-4ceb-b2b1-17fa40827280&state=1234 - Single-tenant:
- Multi-tenant:
For single-tenant configurations, replace {TENANT_ID} with your Directory (tenant) ID and {APPLICATION_ID} with your Application (client) ID.
After consent is granted for Delegated and app-only access, the Microsoft Entra ID administrator must share the following value with the organization administrator: Directory (tenant) ID. This value is required to complete the configuration.
2. Configure the integration in your organization
As an organization administrator, complete the setup as follows:
- In your organization, go to Admin > Security > Authentication Settings > Directory integration and single sign-on (SSO).
- Select Microsoft Entra ID.
- Choose UiPath managed multi-tenant application (Recommended).
- Select the access scope for which consent was granted:
- Delegated and app-only access (Recommended): Provides full group evaluation, including unattended automations and service-to-service (S2S) scenarios.
- Delegated access: Limits evaluations to sessions where the user is present.
Note:Delegated and app-only access is available only for Automation Cloud. For more details on feature availability, refer to Feature availability
- If you selected Delegated access, the Use cached user tokens for group membership checks in unattended automations option appears. Select it to extend group membership evaluation to unattended automations and S2S scenarios using cached Microsoft Entra ID tokens. With this option enabled, Delegated access provides coverage comparable to Delegated and app-only access without requiring app-only permissions. For more information, see Use cached user tokens for group membership checks.
- If you selected Delegated and app-only access, enter the Directory (tenant) ID provided by your Microsoft Entra ID administrator.
- Check I understand & accept that existing users and Microsoft Entra ID users with matching email addresses will have their accounts linked.
- Select Save to activate the integration.
A successful activation indicates that the integration is configured correctly. If activation fails, verify that consent was granted properly and try again.
If you use Automation Hub and want to populate the City, Job Title, and Department fields from Microsoft Entra ID, request additional permissions. Ask your Microsoft Entra ID administrator to grant admin consent using an elevated admin consent URL that includes the required scopes.
Manual setup with custom Microsoft Entra ID application registration
If you prefer to configure your own Microsoft Entra ID application instead of using the UiPath managed multi-tenant application, take the following steps. This option requires managing your own credentials and maintaining them over time.
Credentials created through manual setup will expire periodically. You must renew them before expiration to avoid service disruptions. To reduce this operational overhead, consider using the automated setup with UiPath managed Entra ID application.
Configuring Microsoft Entra ID
As a Microsoft Entra ID administrator, you can configure the application using either a PowerShell script or the Microsoft Entra admin center.
Option A: Using the PowerShell scripts
If you want to automate the setup process with minimal manual configuration, take the following steps:
- Download the Microsoft Entra ID configuration scripts.
- Run
configAzureADconnection.ps1to automatically set up your Entra tenant. - Run
testAzureADappRegistration.ps1to verify the setup.
Option B: Using the Microsoft Entra admin center
If you prefer to manually configure the application registration through the user interface, take the following steps:
Create the app registration:
- Go to Microsoft Entra admin center > App registrations > New registration.
- Set a preferred name.
- Choose Accounts in this organizational directory only.
- Set the Redirect URI for your platform:
https://cloud.uipath.com/identity_/signin-oidchttps://govcloud.uipath.us/identity_/signin-oidc
Configure authentication:
- Navigate to Authentication.
- Add the following redirect URI for your platform:
https://cloud.uipath.com/portal_/testconnectionhttps://govcloud.uipath.us/portal_/testconnection
- Under Implicit grant and hybrid flows, select ID tokens. This integration leverages the Microsoft hybrid flow.
- Save your changes.
Add token claims:
- Go to Token configuration > Add optional claim.
- Select ID as the token type.
- Choose the following claims:
family_name,given_name, andupn.
These claims are used to update user information upon sign-in.
Set API permissions:
- Go to API permissions > Add permission.
- Select Microsoft Graph.
- Under What type of permissions does your application require? Select the permission types based on the UiPath access scope you wish to configure. Before selecting permissions, consider the following:
While you can configure only Delegated access, we recommend using a combined Delegated and Application access.
The tables below list the required permissions for each access scope you want to configure. Some permissions appear in both lists, but they must be added separately because their permission types differ.
Note:To use properties such as
City,Job Title, andDepartmentin Automation Hub, theUser.Read.Allpermission is required.-
For Automation Cloud: Regardless of the access scope you want to configure, you must add the following permissions from the Delegated permissions menu:
Microsoft Entra ID permission Permission type Purpose email,openid,profile,offline_access, andUser.ReadDelegated Allows users to sign in with Microsoft Entra ID and enables Automation Cloud to retrieve claims in the authorization request. User.ReadBasic.AllorUser.Read.AllDelegated Allows Automation Cloud to search for users in Microsoft Entra ID, assign permissions, and keep user attributes updated. GroupMember.Read.AllDelegated Allows Automation Cloud to evaluate group membership and enforce directory group-based access controls.
If you want to configure the Delegated and app-only access scope, you must also add the following permissions from the Application permissions menu:
Microsoft Entra ID permission Permission type Purpose User.ReadBasic.AllorUser.Read.AllApplication Allows Automation Cloud to search for users in Microsoft Entra ID, assign permissions, and keep user attributes updated in unattended automations. GroupMember.Read.AllApplication Allows Automation Cloud to evaluate group membership and enforce directory group-based access controls in unattended automations. -
For Automation Cloud Public Sector, use the following permissions:
- OpenID permissions:
email,openid,offline_access,profile. - User permissions:
User.Read,User.ReadBasic.All, orUser.Read.All. - Group permissions:
GroupMember.Read.All.
- Select Grant admin consent for (your organization). This step allows the application to access data for all users without requiring individual consent prompts. For more information, refer to Microsoft documentation.
Create credentials: You can use either a client secret or a certificate:
- To create a client secret:
- Go to Certificates & secrets.
- Select New client secret, then save the secret value.
- To create a certificate:
- Open a new tab and go to Azure Key Vault.
- Create a certificate:
- Subject:
CN=uipath.com - Content type:
PEM - Maximum size: Less than 10 KB
- Subject:
- Download the certificate in
.pemformat. The downloaded file contains two sections: aBEGIN PRIVATE KEY/END PRIVATE KEYsection containing the private key, and aBEGIN CERTIFICATE/END CERTIFICATEsection containing the public certificate. - Open the
.pemfile in a text editor and copy only the section between BEGIN CERTIFICATE and END CERTIFICATE, including those header and footer lines. - Create a new
.pemfile that contains only the certificate section copied in the previous step. - In the Microsoft Entra admin center, go to Certificates & secrets, and upload the certificate-only
.pemfile created in step 5. Microsoft Entra ID requires only the public certificate for this upload — do not upload the complete.pemfile that includes the private key. - Keep the original
.pemfile downloaded in step 3. The Automation Cloud configuration requires the complete PEM content, including both theBEGIN PRIVATE KEY/END PRIVATE KEYandBEGIN CERTIFICATE/END CERTIFICATEsections. Do not use the certificate-only file created in step 5 for this purpose.
Warning:Using the certificate-only file (from step 5) when configuring Automation Cloud causes authentication failures. The connection test fails with no error message indicating a certificate format issue. Use the original
.pemfile downloaded from Azure Key Vault, which contains both the private key and the certificate.Note:Most credential types eventually expire. To prevent user sign-in issues, update the configuration before credentials expire. To avoid this overhead, use the automated setup with the UiPath-managed Microsoft Entra ID application.
Collect the following integration details and share them with your organization administrator:
- Application (client) ID
- Directory (tenant) ID
- Client secret or certificate
Activating the integration in your organization
As an organization administrator, use the values provided by the Microsoft Entra ID administrator to complete the setup in your organization by taking the following steps:
- Go to Admin > Security > Authentication Settings > Directory integration and single sign-on (SSO).
- Choose Custom application registration ID and secret.
- Select your desired access scope:
- Delegated and app-only access (Recommended): Provides full group evaluation, including for unattended automations and service-to-service (S2S) scenarios.
- Enter the following values provided by your Entra ID administrator:
- Client secret or certificate:
- If using a client secret: paste the secret value.
- If using a certificate: paste the complete content of the original
.pemfile downloaded from Azure Key Vault. The file must include both theBEGIN PRIVATE KEY/END PRIVATE KEYandBEGIN CERTIFICATE/END CERTIFICATEsections. Do not use the certificate-only file that was uploaded to the Microsoft Entra admin center.
- Select Test Connection, then sign in with your Microsoft Entra ID account.
- A successful sign-in indicates that the integration has been configured correctly.
- If the sign-in fails, ask your Microsoft Entra ID administrator to verify the configuration and try again.
Step 3: Using and verifying the integration
After you activate the Microsoft Entra ID integration, verify that it works by signing in with a directory user account and confirming access to Microsoft Entra ID users and groups. To do that, take the following steps:
Sign out of your local account.
Sign in with your directory user account using one of the following methods:
- Navigate to your organization-specific URL for your platform:
https://cloud.uipath.com/{organizationName}/https://govcloud.uipath.us/{organizationName}/
- Or go to the main login page and select Continue with Enterprise SSO.
Note:To confirm that you signed in with a directory account, go to the home page at:
https://cloud.uipath.com/{organizationName}/portal_/homehttps://govcloud.uipath.us/{organizationName}/portal_/home
If you do not see a warning about being signed in with a local user account, you are successfully signed in with a directory user account.
Navigate to Accounts & local groups and attempt to add directory users or groups from Microsoft Entra ID to a local group. Microsoft Entra ID users and groups have distinct icons to differentiate them from local accounts.
Note:Microsoft Entra ID users and groups are not listed by default on the User accounts or Local groups pages. You can find them only by using the search function.
Step 4: Completing the transition
Step 4.1: Configuring group permissions
To allow directory users to inherit permissions based on their group membership, add the relevant Microsoft Entra ID groups to local groups in your organization.
For example, add your UiPath Admins Entra ID group to the Administrators group in your organization.
We recommend removing individual user permissions and relying on directory group membership to simplify permission management as your organization scales.
Step 4.2: Migrating existing users
To ensure users inherit permissions assigned through Microsoft Entra ID group membership in your organization, Studio, and Assistant, take the following steps:
For your organization:
Ask users to sign out and sign in using their directory accounts in one of the following ways:
- Or select Continue with Enterprise SSO on the main login page.
For Studio and Assistant:
- Open UiPath Assistant.
- Navigate to Preferences > Orchestrator Connection.
- Sign out of the current session.
- Set the connection type to Service URL.
- Enter the organization URL for your platform:
- Sign in using your Microsoft Entra ID account.
Step 4.3: Phasing out local accounts
Make sure all users have signed in with their Microsoft Entra ID account at least once before you remove their local accounts. Account linking only occurs at the first directory sign-in. If a local account is deleted before the user signs in with their directory account, a new directory identity is created instead — the user loses access to their previous work, including projects and solutions. This cannot be reversed.
We recommend removing local user accounts to ensure consistency and simplify the user experience.
Users who continue signing in with local accounts instead of their directory accounts face the following limitations:
- They do not inherit directory group permissions.
- They cannot search for or assign users or groups from the Microsoft Entra ID directory.
The following table summarizes the expected behavior for linked local and directory accounts:
| Capability | Linked local user account | Linked directory user account |
| Inherit permissions assigned directly to the user | YES | YES |
| Inherit permissions assigned to directory groups | NO | YES |
| Search for and assign directory users and groups permissions or resources in your organization | NO | YES |
If you use the manual setup for Microsoft Entra ID integration, you must maintain at least one local user account with admin privileges to manage the integration.
Advanced configuration
Restricting access to specific users
By default, all users in your Microsoft Entra ID tenant can access your Automation Cloud organization. To restrict access to specific users or groups, take the following steps:
- In the Microsoft Entra admin center, go to the application you created for the integration in Step 2: Configuring the Microsoft Entra ID integration.
- Go to Enterprise applications > Properties.
- Set User assignment required? to Yes.
- In Users and groups, assign the users or groups who should have access.
All users and groups from your tenant remain searchable in Automation Cloud, but only those assigned to the application can sign in. For more details, refer to the Microsoft documentation on user assignment.
Implementing network restrictions
Use Microsoft Entra ID Conditional Access policies to restrict access based on the following criteria:
- Network location (for example, corporate network only)
- Device compliance
- Risk level
For details on how to configure these policies, see the Microsoft documentation on Conditional Access.
Managing privileged access
For Microsoft Entra ID groups used to manage UiPath admin access, implement the following access management practices:
- Enable Privileged Identity Management (PIM) in Microsoft Entra ID.
- Configure just-in-time access and approval workflows.
- Set up regular access reviews to validate membership and permissions.
For configuration guidance, refer to the Microsoft documentation on Privileged Identity Management.
FAQs
What changes for my users after the integration?
After the integration, users can sign in with their Microsoft Entra ID accounts and retain their existing permissions. If local user accounts are still active, both sign-in methods remain available.
To sign in with a directory account, users can do one of the following:
- Go to the organization-specific URL for your platform:
- On the main login page, select Continue with Enterprise SSO.
Why can I not search for users or groups after configuring the integration?
If you signed in using a local user account instead of your directory account, you will not be able to search for users or groups in your organization.
To understand the differences between local and directory accounts, refer to Phasing out local accounts.
To resolve the issue, ensure that you are signed in with your Microsoft Entra ID account.
Do I need to reassign permissions?
No, you do not need to reassigning permissions. When accounts are linked, your organization automatically applies existing permissions to the corresponding Microsoft Entra ID account. Directory user accounts receive permissions from both direct assignments and directory group memberships.
What Microsoft Entra ID attributes are mapped to UiPath directory user accounts, and when are they updated?
UiPath maps only a limited set of Microsoft Entra ID attributes to directory user accounts. The following table summarizes the available attributes.
All user attributes are updated during sign-in and when users are searched or assigned access to resources in your UiPath organization.
| UiPath organization attributes | Microsoft Entra ID attributes | Purpose |
| Username | user.userPrincipalName | Unique identifier. This property is required when a user is created, and it cannot be cleared during updates. |
| Display name | user.displayName | The user’s full name, typically a combination of first and last name. This property is required when a user is created, and it cannot be cleared during updates. |
| First name | user.givenName | The user’s first name. |
| Last name | user.surName | The user’s last name. |
user.Mail | The user’s email address This property is required when a user is created, and it cannot be cleared during updates. | |
| Job title1 | user.JobTitle | The user's job title. |
| Department1 | user.Department | The user’s department. |
| City1 | user.City | The user’s city. |
| Company name1 | user.CompanyName | The user’s company name. |
1Automation Hub is the only service that leverages the City, Job Title, Department, and Company name values from Microsoft Entra ID. If you require these attributes, you must request for a higher privileged permission, as documented in Configuring the Microsoft Entra ID integration.
For descriptions of Microsoft Entra ID attributes, refer to the Microsoft documentation.
How quickly do Microsoft Entra ID group membership changes apply?
Changes to Microsoft Entra ID group membership take effect at the next sign-in or within one hour for users who are already signed in.
Can I revert to local accounts after integration?
Yes, you can revert to local accounts after integrating with Microsoft Entra ID. An organization administrator must complete the following steps:
- Re-invite the local user accounts.
- Migrate all directory group–based permissions to direct assignments on the corresponding local accounts.
- Ask users to sign out and then sign in with their local user account.
Can I migrate from Microsoft Entra ID integration to SAML integration?
Yes, you can migrate from Microsoft Entra ID integration to SAML integration. An organization administrator must ensure that both identity systems use the same email address for each user. The administrator must also migrate all permissions assigned through Microsoft Entra ID groups to SAML provisioning rules.
Why does the integration use the Microsoft Entra ID's hybrid OAuth 2.0 authorization code grant flow?
UiPath uses the hybrid flow to obtain the ID token from the authorization endpoint and to reduce authentication latency, as described in Microsoft Entra ID documentation.
- Getting started
- Benefits
- Limitations and considerations
- Before you begin
- Step 1: Preparing your organization for account linking
- Step 2: Configuring the Microsoft Entra ID integration
- Configuration methods
- About the UiPath-managed Microsoft Entra ID application
- Use cached user tokens for group membership checks
- Automated setup with UiPath-managed Microsoft Entra ID application (Recommended)
- Manual setup with custom Microsoft Entra ID application registration
- Step 3: Using and verifying the integration
- Step 4: Completing the transition
- Step 4.1: Configuring group permissions
- Step 4.2: Migrating existing users
- Step 4.3: Phasing out local accounts
- Advanced configuration
- Restricting access to specific users
- Implementing network restrictions
- Managing privileged access
- FAQs
- What changes for my users after the integration?
- Why can I not search for users or groups after configuring the integration?
- Do I need to reassign permissions?
- What Microsoft Entra ID attributes are mapped to UiPath directory user accounts, and when are they updated?
- How quickly do Microsoft Entra ID group membership changes apply?
- Can I revert to local accounts after integration?
- Can I migrate from Microsoft Entra ID integration to SAML integration?
- Why does the integration use the Microsoft Entra ID's hybrid OAuth 2.0 authorization code grant flow?
