document-understanding
Dernière mise à jour 6 avr. 2026
Utiliser l'infrastructure
As a Studio workflow, you could use the Document Understanding™ Process: Studio Template.
Utiliser l'Extracteur de formulaires (Form Extractor) l'Extracteur de formulaires intelligents (Intelligent Form Extractor) et le Classifieur de mots clés intelligents (Intelligent Keyword Classifier)
Select the workflow in the framework, and replace the endpoint per instruction here and add the Document UnderstandingTM license key.
  • Endpoint: the public URL from Access to the models
  • ApiKey: copy it from Automation Suite (Admin > Licenses > Robot & Services > Document Understanding)
    Capture d'écran du Classificateur de mots clés intelligent dans le workflow.
Run the workflow. The robot will process the documents one by one. When the Validation Station pops up, select OK to test if the workflow is running properly.
Utiliser l'extracteur d'apprentissage automatique personnalisé
Select the workflow in the framework and replace the endpoint with the public ML Skill endpoint from the deployed ML package following the instruction here and add the Document Understanding license key.
  • Endpoint: the public ML Skill endpoint from Deploy an out-of-the-box ML Package
    Capture d'écran du champ Clé API de l'activité Extracteur d'apprentissage automatique de factures.
