- Overview
- Requirements
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Step 8: Migrating standalone Test Manager
- Monitoring and alerting
- Cluster administration
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Test Automation SQL connection string is ignored
- EKS backup failure due to Velero version
- Velero backup fails with FailedValidation error
- Accessing FQDN returns RBAC access denied error
Resolve the issue where uipathctl ignores the Test Automation SQL connection string in the cluster configuration for Automation Suite.
When you provide an SQL connection string under the orchestrator.testautomation section of the cluster configuration file, the uipathctl binary ignores the connection string and uses the one under the orchestrator section instead. As the following sample shows, the ignored connection string is the value of the sql_connection_str parameter:
"orchestrator": {
"testautomation": {
"enabled": true,
"sql_connection_str": "Server=tcp:new-sql-server-name,1433;Initial Catalog=new-db;Persist Security Info=False;User Id=test;Password='************';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;"
"orchestrator": {
"testautomation": {
"enabled": true,
Solution
To address the issue, take the following steps:
- Perform a Base64 encoding of the SQL connection string that you provided as the value of the
sql_connection_strparameter:echo -n "<sql_connection_str under orchestrator.testautomation in cluster config file>" | base64 -decho -n "<sql_connection_str under orchestrator.testautomation in cluster config file>" | base64 -d - Run the following command to edit the
orchestrator-secretssecret:kubectl edit secret orchestrator-secrets -n uipathkubectl edit secret orchestrator-secrets -n uipath - In the secret, update the value of the
sqlConnectionStringTAparameter with the Base64-encoded connection string value. - Check if you successfully updated the connection string value:
kubectl get secret orchestrator-secrets -n uipath -o jsonpath="{.data.sqlConnectionStringTA}" | base64 --decodekubectl get secret orchestrator-secrets -n uipath -o jsonpath="{.data.sqlConnectionStringTA}" | base64 --decode - In the ArgoCD app UI, navigate to Orchestrator > Details > Parameter > Values > Inside values > Update.
- Under the
connectionStringssection, update the value of theTestAutomationparameter with the plain-text value of the connection string, as shown in the following sample:connectionStrings: TestAutomation: <Plain-text value of sql_connection_str under orchestrator.testautomation in cluster config file>connectionStrings: TestAutomation: <Plain-text value of sql_connection_str under orchestrator.testautomation in cluster config file>
