- Overview
- Requirements
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Step 8: Migrating standalone Test Manager
- Monitoring and alerting
- Cluster administration
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Test Automation SQL connection string is ignored
- EKS backup failure due to Velero version
- Velero backup fails with FailedValidation error
- Accessing FQDN returns RBAC access denied error
- Provisioning Automation Suite Robots fails
- Health check of Automation Suite Robots fails
Known issue and resolution for Automation Suite Robots health check failures after installing Automation Suite on AKS.
After installing Automation Suite on AKS, when you check the health status of the Automation Suite robots pod, it returns an unhealthy status: "[POD_UNHEALTHY] Pod asrobots-migrations-cvzfn in namespace uipath is in Failed status".
Potential issue
On rare occassions, database migrations for Orchestrator and Automation Suite robots may run at the same time. In this case, migrating the database of Automation Suite robots fails. In Argo CD, you can see two migration pods: one with a healthy status, one with an unhealthy status.
Solution
The database migration for Automation Suite robots is automatically retried, and renders successful. However, Argo CD does not update the status. You can ignore the unhealthy status.
