- Overview
- Requirements
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Step 8: Migrating standalone Test Manager
- Monitoring and alerting
- Cluster administration
- Accessing the Models
- Enabling or disabling Chinese, Japanese, Korean OCR
- Enabling or disabling Extended Languages OCR
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Test Automation SQL connection string is ignored
- EKS backup failure due to Velero version
- Velero backup fails with FailedValidation error
- Accessing FQDN returns RBAC access denied error
Enable or disable Chinese, Japanese, and Korean OCR support for Document Understanding in an offline Automation Suite deployment on EKS/AKS.
If you want to use the OCR for Chinese, Japanese, Korean endpoint in an offline environment, you need to install the offline bundle and once the bundle is installed, you have to enable the OCR. For more information on how to install offline bundles, check the ML packages offline installation page from the Document Understanding User Guide.
- When OCR for Chinese, Japanese, Korean is used in Document Understanding, make sure that you configured the activity with the public endpoint of the OCR, and the Document Understanding API Key.
- OCR for Chinese, Japanese, Korean is only supported in Document Understanding deployed in Automation Suite. This is not supported in Document Understanding deployed in AI Center connected to an external Orchestrator.
There are two ways in which you can enable the Chinese, Japanese, Korean OCR:
Using ArgoCD.
Using the
cluster_config.jsonfile.Note:You can only enable the Chinese, Japanese, Korean OCR using
cluster_config.jsonstarting with Automation Suite version 2023.4.11.
Using ArgoCD
- Open ArgoCD.
- Open the Document Understanding framework.
- Select the Parameters tab.
- Navigate to
du-cjk-ocr.enabled. - Select Edit and set the value to
TRUE. - Select Save.
The endpoint for OCR for Chinese, Japanese, Korean in an Automation Suite installation is constructed as {Cluster_FQDN}/du_/cjk-ocr/.
Using the cluster_config.json file
This procedure is only available starting with Automation Suite version 2023.4.11. For version older than 2023.4.11, you can only enable the Chinese, Japanese, Korean OCR using ArgoCD.
After installing or upgrading Automation Suite, configure the
input.jsonfile. -
Add the string for Chinese, Japanese, Korean OCR in the
input.jsonfile. -
If the
documentunderstandingobject is not yet configured, you can use the following code to add it:"documentunderstanding": { "enabled": true, "cjkOcr": { "enabled": true, } },"documentunderstanding": { "enabled": true, "cjkOcr": { "enabled": true, } },Note:If the
documentunderstandingobject is already configured, copy only thecjkOcrproperty without changing any other properties. -
Execute the Automation Suite installer again using the following command:
uipathctl manifest apply input.json --versions versions.jsonuipathctl manifest apply input.json --versions versions.json -
Go to the ArgoCD panel, in the Document Understanding section and check if the Chinese, Japanese, Korean OCR is displayed.
