Patch artifact download links
Download links for patch artifacts required to apply patches to Automation Suite on EKS/AKS.
This page provides the download links for the artifacts required to apply a patch.
2023.10.12 patches​
This section provides the download links for the artifacts required for Automation Suite on EKS/AKS 2023.10.12 patches.
2023.10.12+patch1​
as-cmk.tar.gz​
To download as-cmk.tar.gz for Automation Suite 2023.10.12+patch1, run the following command:
wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2023.10.12+patch1/as-cmk-2023.10.12+patch1.tar.gz
as-images.txt​
To download as-images.txt for Automation Suite 2023.10.12+patch1, run the following command:
wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2023.10.12+patch1/air-images.txt
as-helm-charts.txt​
To download as-helm-charts.txt for Automation Suite 2023.10.12+patch1, run the following command:
wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.12+patch1/embedded-helm-charts.txt
mirror-registry.sh​
To download mirror-registry.sh for Automation Suite 2023.10.12+patch1, run the following command:
wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.12+patch1/mirror-registry.sh
hydrate-registry.sh​
To download hydrate-registry.sh for Automation Suite 2023.10.12+patch1, run the following command:
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.12+patch1/hydrate-registry.sh
versions.json​
To download versions.json for Automation Suite 2023.10.12+patch1, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2023.10.12+patch1/versions.json
2023.10.4 patches​
This section provides the download links for the artifacts required for Automation Suite on EKS/AKS 2023.10.4 patches.
2023.10.4+patch3​
as-cmk.tar.gz​
To download as-cmk.tar.gz for Automation Suite 2023.10.4+patch3, run the following command:
wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2023.10.4+patch3/as-cmk-2023.10.4+patch3.tar.gz
as-images.txt​
To download as-images.txt for Automation Suite 2023.10.4+patch3, run the following command:
wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2023.10.4+patch3/air-images.txt
as-helm-charts.txt​
To download as-helm-charts.txt for Automation Suite 2023.10.4+patch3, run the following command:
wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.4+patch3/embedded-helm-charts.txt
mirror-registry.sh​
To download mirror-registry.sh for Automation Suite 2023.10.4+patch3, run the following command:
wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.4+patch3/mirror-registry.sh
To download hydrate-registry.sh for Automation Suite 2023.10.4+patch3, run the following command:
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.4+patch3/hydrate-registry.sh
versions.json​
To download versions.json for Automation Suite 2023.10.4+patch3, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2023.10.4+patch3/versions.json
2023.10.2 patches​
This section provides the download links for the artifacts required for Automation Suite on EKS/AKS 2023.10.2 patches.
2023.10.2+patch4​
as-cmk.tar.gz​
To download as-cmk.tar.gz for Automation Suite 2023.10.2+patch4, run the following command:
wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2023.10.2+patch4/as-cmk-2023.10.2+patch4.tar.gz
as-images.txt​
To download as-images.txt for Automation Suite 2023.10.2+patch4, run the following command:
wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2023.10.2+patch4/air-images.txt
as-helm-charts.txt​
To download as-helm-charts.txt for Automation Suite 2023.10.2+patch4, run the following command:
wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.2+patch4/embedded-helm-charts.txt
mirror-registry.sh​
To download mirror-registry.sh for Automation Suite 2023.10.2+patch4, run the following command:
wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.2+patch4/mirror-registry.sh
To download hydrate-registry.sh for Automation Suite 2023.10.2+patch4, run the following command:
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.2+patch4/hydrate-registry.sh
versions.json​
To download versions.json for Automation Suite 2023.10.2+patch4, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2023.10.2+patch4/versions.json
2023.10.2+patch3​
as-cmk.tar.gz​
To download as-cmk.tar.gz for Automation Suite 2023.10.2+patch3, run the following command:
wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2023.10.2+patch3/as-cmk-2023.10.2+patch3.tar.gz
as-images.txt​
To download as-images.txt for Automation Suite 2023.10.2+patch3, run the following command:
wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2023.10.2+patch3/air-images.txt
as-helm-charts.txt​
To download as-helm-charts.txt for Automation Suite 2023.10.2+patch3, run the following command:
wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.2+patch3/embedded-helm-charts.txt
mirror-registry.sh​
To download mirror-registry.sh for Automation Suite 2023.10.2+patch3, run the following command:
wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.2+patch3/mirror-registry.sh
To download hydrate-registry.sh for Automation Suite 2023.10.2+patch3, run the following command:
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.2+patch3/hydrate-registry.sh
versions.json​
To download versions.json for Automation Suite 2023.10.2+patch3, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2023.10.2+patch3/versions.json
  • 2023.10.12 patches​
  • 2023.10.12+patch1​
  • 2023.10.4 patches​
  • 2023.10.4+patch3​
  • 2023.10.2 patches​
  • 2023.10.2+patch4​
  • 2023.10.2+patch3​
Connect
Stay updated
