- Overview
- Requirements
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Step 8: Migrating standalone Test Manager
- Step 1: Removing old cache keys
- Step 2: Updating AD integration and authentication
- Step 3: Validating the Insights migration
- Monitoring and alerting
- Cluster administration
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Test Automation SQL connection string is ignored
- EKS backup failure due to Velero version
- Velero backup fails with FailedValidation error
- Accessing FQDN returns RBAC access denied error
Remove old Redis cache keys for Orchestrator and Identity as part of a migration to Automation Suite.
To clean up the Redis keys for Orchestrator and Identity, take the following steps:
- For Orchestrator, navigate to the cloud-based Redis console and run the following command:
FLUSHDBFLUSHDB - For Identity, navigate to the cloud-based Redis console and run the following command:
SELECT 1 FLUSHDBSELECT 1 FLUSHDB
