- Overview
- Requirements
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Step 8: Migrating standalone Test Manager
- Monitoring and alerting
- Cluster administration
- Troubleshooting
- AI Center provisioning failure after upgrading to 2023.10 or later
- Insights volumes created in two different zones following migration
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Test Automation SQL connection string is ignored
- EKS backup failure due to Velero version
- Velero backup fails with FailedValidation error
- Accessing FQDN returns RBAC access denied error
Cause and fix for AI Center provisioning failures after upgrading to 2023.10 or later in Automation Suite on EKS/AKS.
When upgrading from 2023.4.3 to 2023.10 or later, you might run into issues when provisioning AI Center.
The system shows the following exception, and the tenant creation fails: "exception":"sun.security.pkcs11.wrapper.PKCS11Exception: CKR_KEY_SIZE_RANGE
Solution
To resolve this issue, you must perform a rollout restart of the ai-trainer deployment by running the following command:
kubectl -n uipath rollout restart deploy ai-trainer-deployment
