Pods in the uipath namespace stuck when enabling custom node taints
Pods in the uipath namespace are not running when custom node taints are enabled. The pods cannot talk to the adminctl webhook that injects pod tolerations in an EKS env.
Solution
To fix the issue, create a network policy to allow traffic into the admctl webhook from the cluster CIDR or 0.0.0.0/0.
kind: NetworkPolicy
apiVersion: networking.k8s.io/v1
metadata:
  namespace: uipath
spec:
  podSelector:
    matchLabels:
      app: admctl-webhook
  ingress:
        - ipBlock:
            cidr: <cluster-pod-cdr> or "0.0.0.0/0"
kind: NetworkPolicy
metadata:
  namespace: uipath
spec:
  podSelector:
    matchLabels:
      app: admctl-webhook
  ingress:
        - ipBlock:
  • Description
  • Solution
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
