Als RPA-Sponsor starten
After successfully logging in, you, as an RPA Sponsor, can check out the list of the Ideas and Components submitted within your tenant.
You are encouraged to Share your own ideas or components that will boost the company’s RPA assimilation as well as keep an eye on the tenant evolution through the Dashboards module.
Within the Workspace module, you can have a detailed view over:
By accessing the Explore module you can:
Verbinden
Benötigen Sie Hilfe? Support
