Process Mining
Configuring CData Sync
备注:
The information in this page is based on CData Sync 2022 - 22.0.8342.0. If you use an other version of CData Sync, field names or functions may be different.
简介​
When DataBridgeAgent is used to extract data from the source system, the exported .tsv files are loaded into the Microsoft SQL Server database using CData Sync. This page describes how to use CData Sync to upload the data set generated by DataBridgeAgent to a process app in Process Mining Automation Suite.
通常,您应该按照使用 CData Sync 加载数据中所述的步骤设置使用 CData Sync 加载数据。
However, some specific settings are required when using DataBridgeAgent.
创建源连接​
从列表中选择“CSV”作为要与其创建连接的源系统,并确保按照“使用 CData Sync 加载数据 - 创建源连接”中的说明定义设置。
创建作业​
On the Tables tab add a custom query that mirrors the output of the connector you are using.
另请参阅:
  • 简介​
  • 创建源连接​
  • 创建作业​
此页面有帮助吗?
连接
需要帮助? 支持(opens in new window)
保持更新
