- Release notes
- Before you begin
- Getting started
- Managing access
- Working with process apps
- Creating process apps
- Loading data
- Customizing process apps
- Data transformations
- TemplateOne app template
- Purchase to Pay app template
- Order to Cash app template
- Basic troubleshooting guide
Process Mining (Automation Suite)
Introduction
UiPath Process Mining is now available in UiPath Automation Suite, to be installed on premises in the customer local environment or Virtual Machines on Azure, Amazon Web Services or Google Cloud Platform.
Process Mining 2022.10 is available only via UiPath Automation Suite, which enables our customers to install the full UiPath Suite of products on premises.
The main benefits of the Automation Suite are as follows:
- All UiPath products in a centralized on-premises location
- Same interface and features as in the Software as a Service version
- Back up and Restore
- Monitoring and Alerting
- High Availability
Installation and configuration
For information on installing and configuring Process Mining on Automation Suite, refer to the Automation Suite Guide.
Configuring Microsoft SQL Server contains detailed information on configuring Microsoft SQL Server for Process Mining. To calculate the hardware requirements for the Process Mining SQL Server database for data storage for Process Mining process apps, see Hardware requirements. If you want to manually add Process Mining in the cluster.json configuration file, instead of using the interactive installer, see Manual: Advanced installation experience.
With Process Mining you can visualize processes using transactional data from back-end systems and applications like SAP. This data-driven intelligence helps eliminate process pain points, identify candidates for automation, and streamline business processes. Process Mining includes key functionality like role-based access control, ROI estimation, root-cause analysis, and the ability to submit ideas to Automation Hub. Process Mining analyzes event logs and metadata to see how business processes work and how they can be improved.
Below is an overview of the main features in Process Mining (Automation Suite).
App templates
With Process Mining service in Automation Suite, you can create new process apps based on process-specific app templates. An app template contains a predefined set of dashboards and KPIs for process analysis and can be used as the starting point for creating your process apps. If available, an app template can include a built-in connector for a specific combination of a process and source system.
Process Mining offers out-of-the box app templates for several processes and source systems that you can use as the starting point for creating your process apps. You can customize these app templates to your business needs and publish them with a set of dashboards and KPIs to enable business users to monitor and analyze the processes in detail.
Extracting and loading data
When you create a new process app, you must upload data before you can publish the process app. You can also upload data for a published process app. You can use a sample dataset, upload a dataset with .csv files, or load data using an extractor.
Data volume
The performance end-users will experience is directly related to the data volume. The number of rows inside the biggest tables determines the data volume. In general, only the number of rows determines the performance that end users experience. The number of columns is only a factor when the data is loaded from the database.
Processes with about 600.000 (600K) objects and up to about 100.000.000 (100M) events per process are ideal. With more objects and events, parsing the data and showing the visualization will take longer. Process Mining will continue to work. However, when large amounts of data are inserted, the reaction speed may drop.
It is recommended to check the data amount beforehand. If it exceeds the above numbers, it is advised to consider optimizing or limiting the dataset.
Dashboard editor
After creating a process app from an app template, you can edit the dashboards to customize the process app to your business needs. The Dashboard editor provides various options to create different views, and to organize, group, and filter data. See Working with the dashboard editor.
Data Manager
The Data Manager enables you to customize the data used in your process app. With Data Manager you can edit data fields and metrics to change the display names used in your app. You can also toggle fields to be visible or not.
See Data manager, Dashboards, and Charts.
Role-based Access Control
The Admin Console module enables you to manage access by assigning roles to users or groups. The permissions model allows you to integrate all your employees using Process Mining, based on your business requirements.
See Setting up the users.
Root cause analysis
With Root cause analysis, you can compare the influence of case properties on a certain behavior to find significant data influencers for specific process situations. A set of cases is defined based on the period filter. This selection is called Reference cases. Within this set of cases, you can select the behavior that you want to analyze. See Root cause analysis.
Comparing process paths
When in Compare mode, you can compare two sets of paths from your process. This enables you to visualize, compare, and analyze the performance of a process and its variations. See Compare.
Simulating automations
The Automation potential dashboard enables you to see potential savings for activities in your process. For example, if you determine an activity as a bottleneck in the process graph, you can calculate the impact of automating the activity. See Simulating automation potential.
Send automation ideas to Automation Hub
The integration with Automation Hub enables you to send automation ideas from Process Mining directly to Automation Hub. See Sending automation ideas to UiPath Automation Hub.
Managing access control for process apps
The Admin Console module enables you to manage access by assigning roles to users or groups. The permissions model allows you to integrate all your employees using Process Mining based on your business requirements.
- Introduction
- Installation and configuration
- Process Mining (Automation Suite)
- App templates
- Extracting and loading data
- Dashboard editor
- Data Manager
- Role-based Access Control
- Root cause analysis
- Comparing process paths
- Simulating automations
- Send automation ideas to Automation Hub
- Managing access control for process apps
