communications-mining
Communications Mining est désormais inclus dans UiPath IXP. Consultez l’introduction du manuel utilisateur pour plus de détails. Ce contenu a été traduit à l'aide d'une traduction automatique. La localisation du contenu nouvellement publié peut prendre 1 à 2 semaines avant d’être disponible.
Guide du développeur Communications Mining
Dernière mise à jour 12 mai 2025
Intégration EWS auto-hébergée
L'appli EWS est livrée sous forme d'image Docker. Les sections ci-dessous expliquent comment configurer et déployer l'appliance.
Configuration
Since the EWS appliance requires a JSON configuration file to be present at startup, this section explains the contents of the file. Refer to the Deployment section for instructions on how to make the config file available to the EWS appliance.
OAuth 2.0
If you are using the OAuth 2.0 authentication type, you can use Graph API or EWS API. Both allow you to authenticate with client secret or with client certificate.
Le flux d'octroi de jetons utilisé est le flux d'informations d'identification client.
Graph API with client secret
  "microsoft_api": "graph",
  "auth_oauth_authority": "https://login.microsoftonline.com/<tenant_id>/",
  "auth_oauth_client_id": "<client_id>",
  "auth_oauth_client_secret": "<client_secret>",
  "mailboxes": {
    "abc@example.com": {
      "bucket": {
        "owner": "project-name",
        "name": "bucket-name"
      "start_from": "bucket",
      "start_timestamp": "2020-01-01T00:00:00+00:00"
    "xyz@example.com": {
      "bucket": {
  "mailboxes": {
      "bucket": {
      "bucket": {
Graph API with client certificate
  "auth_oauth_client_credential_private_key": "<private_key>",
  "mailboxes": {
      "bucket": {
      "bucket": {
  "mailboxes": {
      "bucket": {
      "bucket": {
EWS API with client secret
  "ews_endpoint": "https://outlook.office365.com/EWS/Exchange.asmx",
  "auth_type": "oauth2",
  "access_type": "impersonation",
  "mailboxes": {
      "bucket": {
      "bucket": {
  "mailboxes": {
      "bucket": {
      "bucket": {
EWS API with client certificate
  "auth_oauth_client_credential_thumbprint": "<thumbprint>",
  "mailboxes": {
      "bucket": {
      "bucket": {
  "mailboxes": {
      "bucket": {
      "bucket": {
NTLM
If you are using NTLM authentication, it can only be used with EWS API.
  "host": "https://exchange-server.example.com",
  "port": 443,
  "auth_type": "ntlm",
  "auth_user": "ews-service-user@example.com",
  "access_type": "delegate",
  "mailboxes": {
      "bucket": {
      "bucket": {
  "port": 443,
  "mailboxes": {
      "bucket": {
      "bucket": {
First, replace the dummy values in host, port, and auth_user with their real values, and change access_type if required. For a description of these parameters and their allowed values, check the configuration reference.
Then, provide the service user password to the EWS appliance as a REINFER_EWS_AUTH_PASS environment variable. For more details, check the Deployment section.
The full list of environment variables that you can set to override values in the config is the following:
NomDESCRIPTION
REINFER_EWS_AUTH_USERUtilisateur du serveur Exchange
REINFER_EWS_AUTH_PASSMot de passe du serveur Exchange
REINFER_EWS_ACCESS_TYPEType d'accès : « délégué » ou « emprunt d'identité »
REINFER_EWS_HOSTHôte du serveur Exchange
REINFER_EWS_PORTPort du serveur Exchange
Configuration de la boîte aux lettres
Vous pouvez spécifier une ou plusieurs boîtes aux lettres dans votre configuration. Pour chaque boîte aux lettres, vous devez fournir l'adresse de la boîte aux lettres et spécifier les paramètres suivants :
NomDESCRIPTION
bucket.ownerProjet du compartiment dans lequel la boîte aux lettres doit être synchronisée.
bucket.nameNom du compartiment dans lequel la boîte aux lettres doit être synchronisée.
start_fromS'il faut démarrer à partir de la dernière heure synchronisée ("compartiment") ou ignorer la dernière heure synchronisée et toujours démarrer à partir de start_timestamp ("config"). Doit être défini sur "compartiment" pour un fonctionnement normal, mais "config" peut être utile dans certains cas lors du débogage.
start_timestampHorodatage à partir duquel démarrer la synchronisation des e-mails. Si ceci n’est pas défini, tous les e-mails seront synchronisés.
La configuration utilise les valeurs par défaut pour un certain nombre de paramètres tels que la fréquence d'interrogation ou la taille des lots. Pour personnaliser davantage votre configuration, reportez-vous à la référence de configuration.
Compartiments
The Exchange integration syncs raw email data into Communications Mining buckets. Same as other Communications Mining resources, a bucket is created in a project, which allows you to control access to the bucket.
Note: To read from a bucket, upload to a bucket, or manage buckets, you must have assigned the respective permissions in the project the bucket is in.
Déploiement
Vous pouvez déployer l'appli EWS avec Kubernetes ou avec Docker.
Le déploiement avec Kubernetes vous permet d'exécuter plusieurs instances de l'appli EWS, chaque instance gérant un sous-ensemble de boîtes aux lettres à synchroniser.
Avec Kubernetes
L'utilisation de Kubernetes est un moyen populaire d'exécuter et de gérer des applications conteneurisées. Cette section vous montre comment déployer l'appli EWS à l'aide de Kubernetes. Il suppose que vous avez une familiarité de base avec Kubernetes et que kubectl est installé. Veuillez consulter cette documentation si vous avez besoin d’aide pour démarrer avec Kubernetes.
Pour déployer sur Kubernetes, vous devez créer un fichier YAML décrivant votre application. Pour commencer, copiez l'exemple ci-dessous.
apiVersion: apps/v1
kind: StatefulSet
metadata:
  labels:
    app: reinfer-ews-appliance
spec:
  podManagementPolicy: Parallel
  replicas: 1
  selector:
    matchLabels:
  serviceName: reinfer-ews-appliance
  template:
    metadata:
      labels:
    spec:
      containers:
        - args:
            - "reinfer-ews"
            - "--bind"
            - "0.0.0.0:8000"
            - "--reinfer-api-endpoint"
            - "https://<mydomain>.reinfer.io/api/"
            - "--shard-name"
            - "$(POD_NAME)"
            # This value should match `spec.replicas` above
            - "--total-shards"
            - "1"
          env:
            - name: REINFER_EWS_CONFIG
              value: "/mnt/config/example_ews_config"
            - name: REINFER_API_TOKEN
              valueFrom:
                secretKeyRef:
                  key: reinfer-api-token
            - name: REINFER_EWS_AUTH_PASS
              valueFrom:
                secretKeyRef:
                  key: ews-auth-pass
            - name: POD_NAME
              valueFrom:
                fieldRef:
                  fieldPath: metadata.name
          image: "your.private.registry.com/reinfer/ews-appliance:TAG"
          resources:
            requests:
              cpu: 0.05
              memory: 128Mi
          volumeMounts:
            - mountPath: /mnt/config
      volumes:
        - configMap:
            items:
              - key: example_ews_config
                path: example_ews_config
kind: StatefulSet
metadata:
  labels:
spec:
  replicas: 1
  selector:
    matchLabels:
  template:
    metadata:
      labels:
    spec:
      containers:
        - args:
            - "reinfer-ews"
            - "--bind"
            - "0.0.0.0:8000"
            - "--shard-name"
            - "$(POD_NAME)"
            - "--total-shards"
            - "1"
          env:
              valueFrom:
                secretKeyRef:
              valueFrom:
                secretKeyRef:
                  key: ews-auth-pass
            - name: POD_NAME
              valueFrom:
                fieldRef:
          resources:
            requests:
              cpu: 0.05
              memory: 128Mi
          volumeMounts:
      volumes:
        - configMap:
            items:
Avant de pouvoir déployer l'appli à l'aide de ce fichier YAML, vous devez effectuer quelques étapes supplémentaires.
Tout d'abord, remplacez <mydomain>.reinfer.io par votre point de terminaison d'API de locataire.
Deuxièmement, comme nous voulons éviter de stocker les informations d'identification sous forme de texte clair dans notre fichier YAML, les variables d'environnement REINFER_TOKEN et REINFER_EWS_AUTH_PASS sont renseignées à partir des clés secrètes Kubernetes. Créez les clés secrètes comme suit :
kubectl create secret generic reinfer-credentials \
  --from-literal=reinfer-api-token=<REINFER_TOKEN> \
  --from-literal=ews-auth-pass=<MSEXCHANGE_PASSWORD>kubectl create secret generic reinfer-credentials \
Enfin, puisque nous souhaitons charger la configuration de l'appareil à partir d'un fichier local, nous devons monter ce fichier dans le pod. Pour ce faire , stockez les données dans une ConfigMap Kubernetes et montez la ConfigMap en tant que volume. Créez la ConfigMap comme suit :
kubectl create configmap ews-config \
  --from-file=example_ews_config=your-ews-config.jsonkubectl create configmap ews-config \
Remarque :
Comme alternative au stockage local du fichier de configuration, vous pouvez le télécharger sur Communications Mining et laisser l'appli EWS le récupérer via l'API Communications Mining. Ceci est décrit ici. Si les fichiers de configuration locaux et distants sont spécifiés, l'appareil utilisera le fichier de configuration local.
Vous pouvez maintenant créer votre ensemble d'états et vérifier que tout est en cours d'exécution :
kubectl apply -f reinfer-ews.yaml
kubectl get stskubectl apply -f reinfer-ews.yaml
kubectl get sts
Avec Docker
Vous pouvez également exécuter l'appli EWS dans Docker. La commande ci-dessous démarrera l'appli avec les mêmes paramètres que ceux utilisés dans la section Kubernetes .
EWS_CONFIG_DIR=
REINFER_API_TOKEN=
TAG=
sudo docker run \
  -v $EWS_CONFIG_DIR:/mnt/config \
  --env REINFER_EWS_CONFIG=/mnt/config/your_ews_config.json \
  --env REINFER_API_TOKEN=$REINFER_API_TOKEN \
  eu.gcr.io/reinfer-gcr/ews:$TAG \
  --reinfer-api-endpoint https://<mydomain>.reinfer.io/api/ \
  &> ews_$(date -Iseconds).logEWS_CONFIG_DIR=
REINFER_API_TOKEN=
TAG=
sudo docker run \
  • Remplacez <mydomain>.reinfer.io par votre point de terminaison d'API de locataire.
  • Remplacez your_ews_config.json par le nom de votre fichier JSON de configuration EWS.
L'appareil exécutera une synchronisation continue des e-mails dans la plate-forme Communications Mining. S'il est arrêté et redémarré, il récupère à partir du dernier état de synchronisation du compartiment stocké.
Avec Docker (stockage local)
L'appli EWS peut enregistrer les e-mails extraits localement au lieu de les transmettre à la plate-forme Communications Mining.
EWS_LOCAL_DIR=
CONFIG_OWNER=
CONFIG_KEY=
TAG=
sudo docker run \
  -v $EWS_LOCAL_DIR:/mnt/ews \
  --local-files-prefix /mnt/ews \
  --remote-config-owner $CONFIG_OWNER --remote-config-key $CONFIG_KEY \
  &> ews_$(date -Iseconds).logEWS_LOCAL_DIR=
CONFIG_OWNER=
CONFIG_KEY=
TAG=
sudo docker run \
  • L'appareil s'attend à trouver la configuration dans $EWS_LOCAL_DIR/config/$CONFIG_OWNER/$CONFIG_KEY.json. Vous pouvez également fournir le chemin d'accès à la configuration en définissant la variable d'environnement $REINFER_EWS_CONFIG comme indiqué dans l'exemple précédent.
  • L'appareil enregistrera l'état de synchronisation dans $EWS_LOCAL_DIR/state. S'il est arrêté et redémarré, il reprendra à partir du dernier état de synchronisation enregistré.
  • L'appareil enregistrera les données dans $EWS_LOCAL_DIR/data.
Avec Docker (Stockage Blob Azure)
L'appareil EWS peut enregistrer les e-mails extraits dans le Stockage Blob Azure au lieu de les transmettre à la plate-forme Communications Mining.
EWS_CONFIG_DIR=
AZ_STORAGE_ACCOUNT_NAME=
AZ_CONTAINER_NAME=
TAG=
sudo docker run \
  --private-file-prefix az://$AZ_STORAGE_ACCOUNT_NAME/$AZ_CONTAINER_NAME \
AZ_CONTAINER_NAME=
TAG=
sudo docker run \
  • Vous devez fournir le chemin d'accès à la configuration en définissant la variable d'environnement $REINFER_EWS_CONFIG .
  • L'appareil s'authentifie auprès de Stockage Blob Azure à l'aide de l'une des méthodes DefaultAzureCredential. Veuillez utiliser une méthode qui vous convient. Quelle que soit la méthode que vous utilisez, accordez le rôle « Contributeur de données blob de stockage » (Storage Blob Data Contributor) à l'appareil.
  • L'appareil enregistrera l'état de synchronisation dans az://$AZ_STORAGE_ACCOUNT_NAME/$AZ_CONTAINER_NAME/state. S'il est arrêté et redémarré, il reprendra à partir du dernier état de synchronisation enregistré.
  • L'appareil enregistrera les données dans az://$AZ_STORAGE_ACCOUNT_NAME/$AZ_CONTAINER_NAME/data.
Configuration du magasin dans Communications Mining
Au lieu de fournir un fichier de configuration local à l'appliance comme vous le faisiez si vous aviez suivi le guide de déploiement de l'appliance EWS, vous pouvez à la place gérer le fichier de configuration dans Communications Mining. Notez que si les fichiers de configuration locaux et distants sont spécifiés, l'appareil utilisera par défaut le fichier de configuration local.
Tout d'abord, téléchargez votre fichier de configuration JSON dans Communications Mining :
curl -H "Authorization: Bearer $REINFER_TOKEN" \
  -H "Content-Type: multipart/form-data" \
  -F 'file=@your-ews-config.json' \
  -XPUT https://<mydomain>.reinfer.io/api/v1/appliance-configs/<project-name>/<config-name>curl -H "Authorization: Bearer $REINFER_TOKEN" \
Pour voir la configuration actuelle :
  -XGET https://<mydomain>.reinfer.io/api/v1/appliance-configs/<project-name>/<config-name>curl -H "Authorization: Bearer $REINFER_TOKEN" \
Ensuite, dans le fichier YAML kubernetes, définissez le paramètre --remote-config-owner sur le nom du projet et le paramètre --remote-config-key sur le nom de la configuration.
Référence (Reference)
Paramètres d’application
Consultez le tableau ci-dessous pour obtenir une liste des paramètres d’application disponibles. Vous pouvez en savoir plus sur l'exécution de l'appli EWS ici.
ParamètreDESCRIPTION
--reinfer-api-endpointPoint de terminaison pour se connecter à l'API Reinfer. mutuellement exclusif avec --local-files-prefix.
--local-files-prefixChemin d'accès pour stocker les e-mails synchronisés et l'état de synchronisation du compartiment. Listé mutuellement exclusif avec --reinfer-api-endpoint et REINFER_API_TOKEN.
--remote-config-ownerProjet qui possède le fichier de configuration de l'appli EWS distante.
--remote-config-keyNom du fichier de configuration de l'appli EWS distante.
--debug-levelNiveau de débogage. 0 = Pas de débogage, 1 = Débogage du service, 2 = Débogage complet. Par défaut : 1.
--shard-nameNom de la partition, c'est-à-dire ews-N pour extraire le numéro de la partition. Lors de l'exécution dans Kubernetes, vous pouvez le définir sur le nom du pod.
--total-shardsLe nombre total d'instances dans le cluster d'appareils. Lors de l'exécution dans Kubernetes, doit être défini sur la même valeur que le nombre d'instances dans l'ensemble d'états.
--restart-on-unrecoverable-errorsSi cette option est activée, les défaillances irrécupérables entraîneront le redémarrage de l’ensemble du service sans planter.
Paramètres de configuration
Consultez le tableau ci-dessous pour découvrir une liste des paramètres de configuration disponibles. Vous pouvez en savoir plus sur l'écriture du fichier de configuration de l'appli EWS ici.
NomDESCRIPTION
hostHôte du serveur Exchange. Peut être remplacée par la variable d'environnement REINFER_EWS_HOST .
portPort du serveur Exchange. Par défaut : 80. Peut être remplacée par la variable d'environnement REINFER_EWS_PORT .
auth_typeSeul « ntlm » autorisé.
auth_userUtilisateur du serveur Exchange. Peut être remplacée par la variable d'environnement REINFER_EWS_AUTH_USER .
auth_passwordMot de passe du serveur Exchange. Peut être remplacée par la variable d'environnement REINFER_EWS_AUTH_PASS .
access_typeType d'accès : "délégué" ou "emprunt d'identité". Par défaut : "delegate". Peut être remplacée par la variable d'environnement REINFER_EWS_ACCESS_TYPE .
ews_ssl_verifySi défini sur « false », ne vérifie pas les certificats. Par défaut : "true".
poll_frequencyLe temps d’attente entre les lots, en secondes. Par défaut : 15.
poll_message_sleepLa durée d'attente entre les e-mails individuels d'un lot, en secondes. Par défaut : 0,1.
max_concurrent_uploadsNombre de téléchargements simultanés vers Communications Mining, entre 0 et 32. Par défaut : 8.
emails_per_folderNombre maximum d'e-mails à récupérer dans chaque dossier par lot, entre 1 et 100 000. Par défaut : 2 520. Ce paramètre permet à l'appli de faire des progrès sur tous les dossiers de manière égale au cas où il y aurait un dossier très volumineux.
reinfer_batch_sizeNombre d'e-mails à récupérer par lot, entre 1 et 1 000. Par défaut : 80.
mailboxesListe des boîtes aux lettres à récupérer. Voir ici pour une explication sur la configuration des boîtes aux lettres.
audit_emailSi vous avez configuré l'appareil avec une configuration à distance, Communications Mining enverra un e-mail à cette adresse chaque fois que la configuration sera mise à jour. Par défaut : Aucun.
ews_ssl_ciphersRendre l'appli EWS utiliser des chiffrements spécifiques. Les chiffrements doivent être une chaîne au format de liste de chiffrement OpenSSL. Par défaut : Aucun.
Forum de la communauté UiPath
Confiance et sécurité
