communications-mining
Communications Mining est désormais inclus dans UiPath IXP. Consultez l’introduction du manuel utilisateur pour plus de détails. Ce contenu a été traduit à l'aide d'une traduction automatique. La localisation du contenu nouvellement publié peut prendre 1 à 2 semaines avant d’être disponible.
Communications Mining Developer Guide
Dernière mise à jour 14 juil. 2025
Update a stream
Update a stream
docs image
/api/v1/datasets/<project>/<dataset_name>/streams/api/v1/datasets/<project>/<dataset_name>/streams
Permissions required: Modify streams, View labels.
  • Bash
    curl -X PUT 'https://<my_api_endpoint>/api/v1/datasets/project1/collateral/streams' \
        -H "Authorization: Bearer $REINFER_TOKEN" \
        -H "Content-Type: application/json" \
        -d '{
      "stream": {
        "comment_filter": {
          "user_properties": {
            "number:Spend": {
              "maximum": 100000,
              "minimum": 100
            "number:Transactions": {
              "one_of": [
                1
            "string:Country": {
              "one_of": [
                "uk",
                "de"
        "description": "Used by ACME RPA to create tickets for disputes.",
        "model": {
          "label_thresholds": [
              "name": [
                "Some Label"
              "threshold": 0.37
              "name": [
                "Another Label"
              "threshold": 0.46
              "name": [
                "Parent Label",
                "Child Label"
              "threshold": 0.41
          "version": 8
        "name": "dispute",
        "title": "Collateral Disputes"
    }'curl -X PUT 'https://<my_api_endpoint>/api/v1/datasets/project1/collateral/streams' \
        -d '{
      "stream": {
        "comment_filter": {
            "number:Spend": {
              "maximum": 100000,
              "minimum": 100
              "one_of": [
                1
            "string:Country": {
              "one_of": [
                "uk",
                "de"
        "model": {
              "name": [
                "Some Label"
              "threshold": 0.37
              "name": [
                "Another Label"
              "threshold": 0.46
              "name": [
                "Parent Label",
                "Child Label"
              "threshold": 0.41
          "version": 8
        "name": "dispute",
  • Node
    const request = require("request");
    request.put(
        url: "https://<my_api_endpoint>/api/v1/datasets/project1/collateral/streams",
        headers: {
          Authorization: "Bearer " + process.env.REINFER_TOKEN,
        json: true,
        body: {
          stream: {
            comment_filter: {
              user_properties: {
                "number:Spend": { maximum: 100000, minimum: 100 },
                "number:Transactions": { one_of: [1] },
                "string:Country": { one_of: ["uk", "de"] },
            description: "Used by ACME RPA to create tickets for disputes.",
            model: {
              label_thresholds: [
                { name: ["Some Label"], threshold: 0.37 },
                { name: ["Another Label"], threshold: 0.46 },
                { name: ["Parent Label", "Child Label"], threshold: 0.41 },
              version: 8,
            title: "Collateral Disputes",
      function (error, response, json) {
        // digest response
        console.log(JSON.stringify(json, null, 2));
    );const request = require("request");
    request.put(
        headers: {
        json: true,
        body: {
          stream: {
            comment_filter: {
              user_properties: {
            model: {
              label_thresholds: [
              version: 8,
        // digest response
  • Python
    import json
    import os
    import requests
    response = requests.put(
        headers={"Authorization": "Bearer " + os.environ["REINFER_TOKEN"]},
        json={
            "stream": {
                "name": "dispute",
                "title": "Collateral Disputes",
                "model": {
                    "version": 8,
                        {"name": ["Some Label"], "threshold": 0.37},
                        {"name": ["Another Label"], "threshold": 0.46},
                            "name": ["Parent Label", "Child Label"],
                            "threshold": 0.41,
                "comment_filter": {
                        "string:Country": {"one_of": ["uk", "de"]},
                        "number:Spend": {"minimum": 100, "maximum": 100000},
                        "number:Transactions": {"one_of": [1]},
    print(json.dumps(response.json(), indent=2, sort_keys=True))import json
    import os
    import requests
        json={
            "stream": {
                "name": "dispute",
                "model": {
                    "version": 8,
                            "threshold": 0.41,
                "comment_filter": {
  • Response
      "status": "ok",
      "stream": {
        "context": "0",
        "created_at": "2019-08-03T12:30:00.123456Z",
        "dataset_id": "abcdef0123456789",
        "id": "0123456789abcdef",
        "model": {
          "version": 8
        "name": "dispute",
        "updated_at": "2019-08-03T12:30:00.123456Z"
      "status": "ok",
      "stream": {
        "context": "0",
        "model": {
          "version": 8
        "name": "dispute",
  • Update a stream
Forum de la communauté UiPath
Confiance et sécurité
