  • Automation Suite on Linux Release Notes
    • 2023.10.0
    • 2023.10.1
      • 2023.10.2+patch2
      • 2023.10.2+patch3
      • 2023.10.2+patch4
      • 2023.10.2+patch5
    • 2023.10.5
    • 2023.10.6
    • 2023.10.8
    • 2023.10.9
    • 2023.10.10
    • 2023.10.11
  • Automation Suite on EKS/AKS Release Notes
Automation Suite release notes
Last updated Oct 13, 2025
2023.10.2+patch5
Release date: September 1, 2025
About this patch
This release applies a patch to Automation Suite 2023.10.2. The patch addresses some issues in Document Understanding. For more details, see the individual product release notes referenced in the Product versions section.
Important: This fix will also be included in all future releases starting with Automation Suite 2023.10.11. We recommend that you wait for Automation Suite 2023.10.11 to get this fix.
After applying the patch, you must update the following applications in ArgoCD to enable server-side generation of unique IDs:
  • For documentunderstanding, set du-digitizer.useServiceGeneratedUniqueIds to true.
  • For aistorage, set useServiceGeneratedUniqueIds to true.
How to apply the patch
To apply this patch, follow the instructions in Applying a patch.
Deprecation timeline
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details
Product versions
The following table outlines the release status, version, and release notes for all UiPath products deployed under Automation Suite 2023.10.2+patch5.
Legend:
available - This Automation Suite version bundles a new version of the product. New release notes are available.
not available - This Automation Suite version bundles a previously released version of the product. No new release notes are available.
ProductProduct versionRelease statusRelease notes
Action CenterN/A
not available
N/A
AI CenterN/A
not available
N/A
AI Computer VisionN/A
not available
N/A
AppsN/A
not available
N/A
Automation HubN/A
not available
N/A
Automation OpsN/A
not available
N/A
Data ServiceN/A
not available
N/A
Document Understanding2023.10.2-patch5
available
Document Understanding release notes
InsightsN/A
not available
N/A
OrchestratorN/A
not available
N/A
Process MiningN/A
not available
N/A
Test ManagerN/A
not available
N/A
Internal third-party component versions
This Automation Suite release bundles the following internal components:
ComponentVersion
RKE21.26.11
ArgoCD2.7.7
logging-operator4.1.0
logging-operator-logging4.1.0
gatekeeper3.12.0
rook-ceph1.9.4
prometheus-pushgateway2.1.6
cert-manager1.12.3
rancher-istio102.2.0-up1.17.2
rancher-logging102.0.1-up3.17.10
rancher-logging-crd102.0.1-up3.17.10
rancher-monitoring-crd102.0.1-up40.1.2
rancher-gatekeeper-crd102.1.0-up3.12.0
rancher-gatekeeper100.2.0-up3.8.1
rancher-monitoring102.0.1-up40.1.2
longhorn1.4.3
longhorn-crd1.1.100
reloader0.0.129
csi-driver-smb1.10.0
velero3.1.6
redis-operator7.2.4-7
redis-cluster7.2.4-64
  • About this patch
  • How to apply the patch
  • Deprecation timeline
  • Bundling details
  • Product versions
  • Internal third-party component versions
