Automation Suite release notes
  • Automation Suite on Linux Release Notes
    • 2023.10.0
    • 2023.10.1
    • 2023.10.5
    • 2023.10.6
    • 2023.10.8
    • 2023.10.9
    • 2023.10.10
    • 2023.10.11
  • Automation Suite on EKS/AKS Release Notes
2023.10.9
2023.10.9 release notes for Automation Suite on EKS/AKS.
Release date: April 15, 2025
Removed Dapr dependency for Process Mining​
Starting with Automation Suite 2023.10.9, Process Mining will no longer have a dependency on Dapr.
Task-Mining, however, will still continue to have a dependency on Dapr.
If you are installing Automation Suite where Process Mining is enabled and Task Mining is not enabled, then the Dapr application will not be installed.
In case of an Automation Suite upgrade where Process Mining is enabled and Task Mining is not enabled, then the Dapr application will be automatically uninstalled.
Enhanced telemetry​
Enhanced Automation Suite with a high-level summarized usage telemetry feature, provided guidance on viewing the generated XML file, and added telemetry sharing with UiPath Support via the Customer Portal.
Istio HSTS enabled by default​
To enhance security, Istio HSTS is now enabled by default.
Bug fixes​
  • Erratum - added April 15, 2025: An issue related to AI Center caused Microsoft SQL Server 2016 to throw the following exception: exception":"com.microsoft.sqlserver.jdbc.SQLServerException: 'OPTIMIZE_FOR_SEQUENTIAL_KEY' is not a recognized CREATE INDEX. We have fixed the issue.
Known issues​
FIPS 140-2 support limitations​
Erratum - added January 22, 2026: Insights is not supported on Automation Suite deployments that run on FIPS 140-2-enabled machines. To remain compliant with FIPS 140-2 requirements, you must disable Insights.
For details, refer to Security and compliance.
Log streaming does not work in proxy setups​
Erratum - added June 26, 2025: Log forwarding does not work in proxy setups because the proxy environment variables were not set in the logging pods. To address the issue, refer to the Troubleshooting section.
We fixed the issue in Automation Suite 2023.10.10.
Licensing SQL connection error​
Erratum - added June 26, 2025: Licensing SQL connection errors occur when the Data Source property specified both a named instance and a port.
Process Mining Airflow image installation fail​
Erratum - added June 26, 2025: When Process Mining is enabled with the new Airflow image, which uses PostgreSQL, the Airflow installation fails in AWS (EKS) environments with S3 or Ceph storage types.
Deprecation timeline​
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details​
Product versions​
To find out what has changed on each Automation Suite product, visit the following links.
If the product is greyed out, this new Automation Suite version does not bring any changes to it.
DISCOVERBUILDMANAGEENGAGE
Automation Hub 2023.10.9Automation Ops 2023.10.9AI Center 2023.10.9Action Center 2023.10.9
Task Mining 2023.10.9AI Computer Vision 2023.10.9Insights 2023.10.9Apps 2023.10.9
Process Mining 2023.10.9Document Understanding 2023.10.9Orchestrator 2023.10.10
Test Manager 2023.10.9
Data Service 2023.10.9
Internal third-party component versions​
For the Kubernetes versions that each Automation Suite version supports, see Kubernetes compatibility.
This Automation Suite release bundles the following internal components:
ComponentVersion
Istio1.25.0
ArgoCD2.14.4
Prometheus3.2.1
Grafana11.5.2
Fluentd & Fluent-bitlogging-operator: 5.2.0
logging-operator-logging: 5.2.0
Gatekeeper3.18.2
Cert-Manager1.17.1
Velero8.5.0
Migration tool version​
The migration tool version you need depends on the standalone products you plan to migrate and the targeted Automation Suite version. For more details, see Migration compatibility matrix.
For instructions on migrating a standalone product to the current version of Automation Suite, see Full migration.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
