Automation Suite release notes
  • Automation Suite on Linux Release Notes
    • 2023.10.0
    • 2023.10.1
    • 2023.10.5
    • 2023.10.6
    • 2023.10.8
    • 2023.10.9
    • 2023.10.10
    • 2023.10.11
  • Automation Suite on EKS/AKS Release Notes
2023.10.4+patch3
2023.10.4 Patch 3 release notes for Automation Suite on EKS/AKS.
Release date: October 13, 2025
About this patch​
This release applies a patch to Automation Suite 2023.10.4. The patch addresses some issues in Automation Hub. For more details, see the individual product release notes referenced in the Product versions section.
Important:
This fix will also be included in all future releases starting with Automation Suite 2023.10.12. We recommend that you wait for Automation Suite 2023.10.12 to get this fix.
How to apply the patch​
To apply this patch, follow the instructions in Applying a patch.
Deprecation timeline​
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details​
Product versions​
The following table outlines the release status, version, and release notes for all UiPath products deployed under Automation Suite 2023.10.4+patch3.
Legend:
✅ New: This Automation Suite version includes a new product version. New release notes are available.
◆ Bundled: This flavor includes a previously released product version. No new release notes are available.
ProductVersionRelease notes
Action Center◆ Bundled: N/AN/A
AI Center◆ Bundled: N/AN/A
AI Computer Vision◆ Bundled: N/AN/A
Apps◆ Bundled: N/AN/A
Automation Hub✅ New: 2023.10.4-patch3Automation Hub release notes
Automation Ops◆ Bundled: N/AN/A
Data Service◆ Bundled: N/AN/A
Document Understanding◆ Bundled: N/AN/A
Insights◆ Bundled: N/AN/A
Orchestrator◆ Bundled: N/AN/A
Process Mining◆ Bundled: N/AN/A
Task Mining◆ Bundled: N/AN/A
Test Manager◆ Bundled: N/AN/A
Internal third-party component versions​
For the Kubernetes versions that each Automation Suite version supports, see Kubernetes compatibility.
This Automation Suite release bundles the following internal components:
ComponentVersion
Istio1.21.2
ArgoCD2.10.9
Prometheus2.51.2
Grafana10.4.2
Fluentd & Fluent-bitlogging-operator: 4.6.0
logging-operator-logging: 4.6.0
Gatekeeper3.16.0
Cert-Manager1.14.5
Velero6.2.0
  • About this patch​
  • How to apply the patch​
  • Deprecation timeline​
  • Bundling details​
  • Product versions​
  • Internal third-party component versions​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
