- Automation Suite on Linux Release Notes
- Automation Suite on EKS/AKS Release Notes
Automation Suite release notes
2023.10.1
Release date: December 19, 2023
Out-of-support RHEL versions
Red Hat no longer supports RHEL 8.3, 8.4, 8.5, and 8.7. As a result, we have removed them from the list of compatible RHEL versions. We currently support RHEL 8.6 and 8.8, but we recommend using the latter.
If you move from an older Automation Suite version, make sure you use a supported RHEL version before starting the upgrade.
For more details, see the Automation Suite hardware and software requirements.
Registry hydration improvements
We have improved the time it takes to hydrate the registry and cut it down from four hours to approximately two hours. In addition to this, you no longer need to use the --bundle-type flag when running the hydrate-registry.sh script when configuring your OCI-compliant registry.
Bug fixes
- Erratum - Added June 25, 2024: We have fixed a logging configuration issue that was causing the host machine storage to fill up due to Redis logs accumulating in
/var/lib/rancher. - Erratum - added May 20, 2024: Previously, on single-node deployments with in-cluster storage, upgrades from version 2022.4.1 or older would fail at the fabric stage. A
rook-cephmigration issue was causing the failure. The behavior no longer occurs. - Previously, when installing the required RPM packages, if the
cluster_config.jsonfile was missing, an error was thrown. Now, if the file does not exist when running./validateUiPathASReadiness.sh install-packages, we assume that you perform an online installation, and no error prompts you. - We have fixed an issue causing trigger zombie processes to start after performing a 2023.10.0 offline installation.
Known issues
FIPS 140-2 support limitations
Erratum - added January 22, 2026: Insights is not supported on Automation Suite deployments that run on FIPS 140-2-enabled machines. To remain compliant with FIPS 140-2 requirements, you must disable Insights.
For details, refer to Security and compliance.
Upgrade failure due to overridden Insights PVC sizes
Erratum - added December 18, 2024: An issue causes upgrades to fail when the existing Insights PVC sizes are inadvertently overridden. To address this problem, you must manually change the PVC sizes in ArgoCD UI. For details, see the Troubleshooting section.
This issue is fixed in Automation Suite 2023.10.7.
Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
Erratum - added December 18, 2024: Following an Automation Suite upgrade from version 2023.4 or older, reinstalling or upgrading Insights results in data loss due to an issue with Insights storage class changes. To address the problem, see Troubleshooting.
We fixed the issue in Automation Suite 2023.10.7.
Node maintenance issue in non-HA Redis
Erratum - added December 18, 2024: An issue causes the redis-cluster-0 pod to get stuck in the terminating state when you perform a node drain in non-HA Redis scenarios. To address the problem, you must force delete the pod using the following command:
kubectl -n redis-system delete pod redis-cluster-0 --force
Unnecessary Redis DNS resolution validations during Active/Passive checks
Erratum - added December 18, 2024: An issue causes unnecessary Redis DNS resolution validations for redis.<primary-fqdn> and redis-db.<primary-fqdn> during Active/Passive prerequisite checks. This issue is fixed in Automation Suite 2023.10.7.
Insights annotation issue blocks installer
Erratum - added December 18, 2024: An Insights annotation issue blocks the Automation Suite installer. We fixed the issue in Automation Suite 2023.10.7.
Unintended RKE2 service upgrade on additional nodes
Erratum - added November 26, 2024: We have identified an issue where exclude= rke2-* is not added to the /etc/yum.conf file on nodes other than the first server. In specific environments, particularly online ones, an attempt to upgrade all components can cause an unintentional upgrade of the RKE2 service on nodes other than the first server.
To fix this issue, you must manually add exclude=rke2-* to the /etc/yum.conf file on all the nodes of your Automation Suite cluster.
AI Center skills sync failure during side-by-side upgrade
Erratum - added December 18, 2024: A syntax issue causes the failure of the aicenter skill sync and aicenter skill status commands during a side-by-side upgrade.
To fix this issue, you must manually edit the syntax. For details, see the Troubleshooting section.
Test Automation SQL connection string is ignored
Erratum - added October 17, 2024: When you provide an SQL connection string under the orchestrator.testautomation section of the cluster_config.json file, the uipathctl binary ignores the connection string and uses the one under the orchestrator section instead. To address the problem, see the Troubleshooting section.
Installation fails while populating node labels
Erratum - added October 17, 2024: When deploying Automation Suite on AWS machines where only IMDSv2 is enabled, installation fails while populating node labels. To address the issue, see the Important note in Optional: Enabling resilience to zonal failures in a multi-node HA-ready production cluster.
Cannot upgrade due to failed jobs in system-upgrade namespace
Erratum - added October 17, 2024: Upgrading Automation Suite fails due to the presence of failed jobs in the system-upgrade namespace. If the upgrade command fails at any stage (infra, fabric, or service upgrade), take the following steps before retrying the upgrade:
List the existing jobs in the
system-upgradenamespace:kubectl get jobs -n system-upgradekubectl get jobs -n system-upgrade -
Delete the failed jobs:
kubectl -n system-upgrade delete jobs <failed_jobs>kubectl -n system-upgrade delete jobs <failed_jobs>
When running the command, replace the <failed_jobs> placeholder with the names of the failed jobs, separated by spaces.
We fixed the issue in Automation Suite 2023.10.6.
Pods cannot communicate with FQDN in a proxy environment
Erratum - added October 17, 2024: In a proxy environment, if the proxy server uses the same port as the TCP port of any other service in the Istio service mesh, such as port 8080, pods cannot communicate with the FQDN. The issue causes the following error:
System.Net.Http.HttpRequestException: The proxy tunnel request to proxy 'http://<proxyFQDN>:8080/' failed with status code '404'.
To fix the issue, see the Troubleshooting section.
Weak ciphers in TLS 1.2
Erratum - added August 29, 2024: We have identified certain vulnerabilities associated with the usage of weak ciphers in TLS 1.2. For details on how to mitigate the issue, see How to address weak ciphers in TLS 1.2.
Support bundle log collection failure
Erratum - added August 14, 2024: An issue affects the support bundle generation when using an external OCI registry in an offline environment. Under these conditions, the generated support bundle lacks historical logs and cannot upload to any selected external object storage. To fix this issue, see the Troubleshooting section.
Upgrades fail due to Longhorn being uninstalled
Erratum - added August 14, 2024: Upgrading from Automation Suite 2023.10.x fails due to the Longhorn storage classes still being present. To solve the problem, you must clean up the Longhorn storage classes manually, by running the following command:
for sc in $(kubectl get sc -o json | jq -r '.items[] | select(.provisioner=="driver.longhorn.io") | .metadata.name'); do
kubectl delete sc "${sc}"
done
done
We fixed the issue in Automation Suite 2023.10.5.
Unnecessary ListBucket API prerequisite check fails for external objectstore
Erratum - added August 14, 2024: For AI Center and Task Mining, the ListBucket API prerequisite check fails when using an external objectstore. However, AI Center and Task Mining do not use the ListBucket API permission. We removed the unnecessary check in Automation Suite 2023.10.5.
Cannot enable SSO for ArgoCD
Erratum - added August 14, 2024: You cannot enable SSO for ArgoCD due to an issue with the Dex image versions. We fixed the issue in Automation Suite 2023.10.5.
snapshot-controller-crds pod in CrashLoopBackOff state after upgrade
Erratum - added August 14, 2024: An issue causes the snapshot-controller-crds pod to remain in the CrashLoopBackOff state after upgrade. This occurs due to a conflict between the newly installed snapshot-controller and the existing one during the RKE2 upgrade. To fix the issue, see the Troubleshooting section.
Migration from in-cluster objectstore to external objectstore fails
Erratum - added August, 2024: Migrating from an in-cluster objectstore to an external objectstore fails due to a configuration issue. Therefore, you must not attempt a migration from the Ceph in-cluster objectstore to an external objectstore in this version of Automation Suite. We fixed the issue in Automation Suite 2023.10.2, where you can safely migrate from Ceph to an external objectstore.
Components fail when using external object storage with proxy environment
Erratum - added July 24, 2024: Using an external storage with a proxy environment causes Orchestrator, the Automation Suite Support Bundle Tool, Prometheus, Thanos, Fluentd, etc. to fail. We fixed the issue in Automation Suite 2023.10.3.
Issue with saving custom configurations in email settings
Erratum - added July 3, 2024: When configuring the email settings, you cannot save any custom configurations due to an issue with form validation. The Save button incorrectly appears grayed out, despite filling in all the required fields correctly. As a workaround, you can make a PUT request to the /identity_/api/setting endpoint.
Use the appropriate access token and make sure the request body contains the necessary details. Also make sure that Email.Smtp.UseDefaultCredentials is set to True, like in the following example:
"Settings": [
"Key": "Email.Smtp.Host",
"Value": "SendGrid"
"Key": "Email.Smtp.Port",
"Value": "587"
"Key": "Email.Smtp.UserName",
"Value": ""
"Key": "Email.Smtp.Domain",
"Value": ""
"Key": "Email.Smtp.FromEmail",
"Value": "no-reply@uipath.com"
"Key": "Email.Smtp.FromDisplayName",
"Value": "UiPath Platform"
"Key": "Email.Smtp.EnableSsl",
"Value": "true"
"Key": "Email.Smtp.UseDefaultCredentials",
"Value": "true"
"Key": "Email.Smtp.Password",
"Value": ""
"Key": "Email.Smtp.ConnectionTimeout",
"Value": "180000"
"PartitionGlobalId": ""
"Settings": [
"Value": "SendGrid"
"Value": "587"
"Value": ""
"Value": ""
"Value": "true"
"Value": "true"
"Value": ""
"Value": "180000"
Network policies in Airflow may cause improper functioning of DNS
Erratum - added June 3, 2024: Ocassionally the network policies for Airflow prevent the DNS from working correctly. To prevent the issue, run the following command.
sudo networkPolicyTool.sh --createNetworkPolicy ./Configs/networkPolicyTool/airflow.yaml --add
To install Network Policy Tool, follow the instructions in this troubleshooting article: Network Policy Tool. This issue is fixed in Automation Suite 2023.10.3.
Issues related to CephMgrIsAbsent alerts
Erratum - added April 19, 2024: False positive CephMgrIsAbsent alerts are displayed even though there are no storage issues. This issue is fixed in Automation Suite 2023.10.3.
Error message while uninstalling rook-ceph post migrating to a S3 object-store
Erratum - added April 19, 2024: When uninstalling rook-ceph, an error message related to missing external object storage configuration is displayed. This issue occurs even though the migration is succesful. This behavior is fixed in Automation Suite 2023.10.3.
Issues affecting Ceph metrics and alerts
Erratum - added April 19, 2024: In certain situations, Ceph metrics and alerts are missing from the monitoring dashboards. To fix the issue, see the Troubleshooting section.
Collation differences between SQL server and SQL database not supported
Erratum - added February 28, 2024: Stored procedures do not support collation differences between the SQL server and SQL database. To avoid any potential problems, you must ensure that the collation settings of both SQL server and SQL database are identical.
Upgrade fails due to MongoDB to SQL Server migration
Erratum - added February 28, 2024: We have identified an issue impacting the side-by-side and the in-place upgrade of Automation Suite 2022.10 or earlier to Automation Suite 2023.10.0 or later. Due to a faulty migration from MongoDB to SQL Server, the upgrade operation fails if you have Apps enabled and use Kerberos authentication for the SQL Server database.
Erratum - added April 15, 2025: The recommended solution is to upgrade to Automation Suite 2023.10.9.
Installation failure when adding new products to existing Automation Suite
Erratum - added February 28, 2024: Whenever trying to add a new product to an existing Automation Suite installation, the installer wrongly asks you to provide a temporary registry, causing a failure in the installation process.
To solve the problem, use the following workaround:
Make sure the temporary registry is up.
Change the readinessProbe setting of the docker registry StatefulSet by running the following command:
kubectl patch statefulset docker-registry -n docker-registry --type json -p '[{"op": "replace", "path": "/spec/template/spec/containers/0/readinessProbe", "value": {"httpGet":{"scheme":"HTTPS", "path": "/", "port": 5000}}}]'kubectl patch statefulset docker-registry -n docker-registry --type json -p '[{"op": "replace", "path": "/spec/template/spec/containers/0/readinessProbe", "value": {"httpGet":{"scheme":"HTTPS", "path": "/", "port": 5000}}}]'
Kerberos keytab rotation does not trigger token regeneration
Erratum - added September 24, 2025: An issue causes Kerberos keytab rotation to not immediately regenerate authentication tokens, which may lead to temporary connectivity disruptions between services and the database.
To address the issue, you must manually trigger the Kerberos ticket renewal cronjob by running the following command:
kubectl delete job tgt-rotate-manual -n uipath --ignore-not-found ; kubectl create job tgt-rotate-manual --from=cronjob/kerberos-tgt-update -n uipath
We fixed the issue in Automation Suite 2023.10.11.
Orchestrator does not start when using user-assigned managed identity
Erratum - added September 24, 2025: An issue prevents the storage.useClientID parameter from being set when you select a user-assigned managed identity for object storage. As a result, Orchestrator cannot start in environments where access is restricted to user-assigned managed identities.
To address the issue, you must manually set the parameter in ArgoCD, as follows:
- In the ArgoCD Orchestrator application, go to Details > Parameters.
- In the values text box, set
storage.isExternal : trueand save.
Thanos compactor stops on corrupted blocks
Erratum - added September 24, 2025: An issue causes the Thanos compactor to stop compacting metrics when it encounters corrupted blocks in the object store. This prevents compaction and leads to increased storage usage.
To address the issue, refer to the Troubleshooting section.
Agent node addition failure in offline environments
Erratum - added June 26, 2025: An issue causes the addition process of agent nodes in offline environments to fail. Agent node additions require the temporary registry to be running. To address the issue, you must re-enable the temporary registry to successfully join the agent node.
We fixed the issue in Automation Suite 2023.10.10.
Installation fails due to CA certificates with large policy OIDs
Erratum - added June 26, 2025: An issue causes the Automation Suite installation to fail when using Certificate Authority (CA) certificates that include a CertificatePolicies section with policy OID values exceeding 4 bytes. This issue prevents Automation Suite from recognizing these CA certificates, interrupting the installation process.
To address the issue, you must either ensure that the policy OID values within the CertificatePolicies section do not exceed 4 bytes, or avoid using CA generators that add the CertificatePolicies section to the certificates.
Licensing SQL connection error
Erratum - added June 26, 2025: Licensing SQL connection errors occur when the Data Source property specified both a named instance and a port.
Grafana dashboard error
Erratum - added June 10, 2025: In multi-node (HA) setups, Grafana runs with two replicas, but there is no common data source between the replicas, causing issues in user session management. Errors like Dashboard not found and Invalid dashboard UID in the request appear in the Grafana dashboard.
As a workaround, since Grafana is not a critical application, you can reduce the replica count to one by performing the following steps:
Modify the helm parameter for the
fabric-installerapplication. This automatically triggers the sync operation forfabric-installerapplication.kubectl patch application fabric-installer -n argocd --type='json' -p='[{"op": "add", "path": "/spec/source/helm/parameters/-", "value": {"name": "global.rancherMonitoring.grafana.replicas", "value": "1"}}]'kubectl patch application fabric-installer -n argocd --type='json' -p='[{"op": "add", "path": "/spec/source/helm/parameters/-", "value": {"name": "global.rancherMonitoring.grafana.replicas", "value": "1"}}]' -
Sync the
rancher-monitoringapplication from ArgoCD UI.
We have fixed this issue in Automation Suite 2023.10.7.
uipathctl health check command
Erratum - added May 21, 2025: For offline Automation Suite installations using the external docker registry, the uipathctl health check command does not work due to a known issue. This issue has been fixed in Automation Suite 2023.10.6.
As a workaround, you can download the uipathctl binary from Automation Suite 2023.10.6 and use it to run the uipathctl health check command.
Kubernetes upgrade failure
Erratum - added April 15, 2025: An issue causes the Kubernetes upgrade to fail due to a missing certificate-injector-webhook in deployment.apps. To address the issue, you must run the following command:
kubectl delete configmap -n uipath-infra certificate-injector-webhook-configmap --ignore-not-found
We fixed the issue in Automation Suite 2023.10.9.
Document Understanding deployment issue post-upgrade
Erratum - added April 15, 2025: An issue prevents you from importing files into your DM session in AI Center after upgrading to Automation Suite 2023.10.x. This issue occurs due to the du-digitizer-worker deployment from the old Automation Suite version not being fully cleaned up after the upgrade. Starting with Automation Suite 2023.10.0, the deployment was renamed to du-digitizer-worker-deployment.
To address the issue, you must navigate to the ArgoCD UI and from the documentunderstanding application, manually delete the old du-digitizer-worker deployment. After deletion, re-sync the documentunderstanding application.
We fixed the issue in Automation Suite 2023.10.8.
Incomplete Docker registry cleanup process
Erratum - added April 15, 2025: An issue prevents the registry cleanup command from effectively clearing the unused Docker images from all registry pods. To address the issue, refer to the Troubleshooting section.
Kube-proxy health check not working
Erratum - added April 15, 2025: The node-monitor component, which monitors the node for issues such as checking kube-proxy health or if ip_forward is enabled, and cordons the node if issues arise, is not working for specific nodes such as GPU, task-mining, or as-robot. We have fixed this issue in Automation Suite 2023.10.9.
Kerberos tickets do not automatically renew
Erratum - added April 15, 2025: Kerberos tickets fail to automatically renew after cluster restoration, requiring manual sync of the Windows Auth app.
This issue is fixed in Automation Suite 2023.10.9.
AI Center storage migration failure
Erratum - added February 13, 2025: An issue prevents uipathctl from correctly setting executeMigration to true during the migration process from Ceph in-cluster storage to external object storage in AI Center.
To fix this issue, you must manually set executeMigration to true in ArgoCD for AI Center and then proceed with a resync, ensuring to prune. This issue is fixed in Automation Suite 2023.10.8.
Email alerts configuration failure post upgrade
Erratum - added February 13, 2025: An issue affects the functionality of email alerts configuration and the setup of multiple receivers after upgrading from Automation Suite 2022.10. To address this issue, see Troubleshooting.
Upgrade failure due to default organization initialization
Erratum - added June 26, 2025: An issue causes the upgrade to fail when upgrading from Automation Suite 2022.10 or older to versions 2023.10.0 through 2023.10.2. The issue occurs due to an unknown socket error in the platform-services-initialize-default-organization-job, which prevents the default organization from initializing.
Deprecation timeline
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details
Product versions
To find out what has changed on each Automation Suite product, visit the following links.
If the product is greyed out, this new Automation Suite version does not bring any changes to it.
Internal third-party component versions
This Automation Suite release bundles the following internal components:
| Component | Version |
| RKE2 | 1.26.5 |
| ArgoCD | 2.7.7 |
| logging-operator | 4.1.0 |
| logging-operator-logging | 4.1.0 |
| gatekeeper | 3.12.0 |
| rook-ceph | 1.9.4 |
| prometheus-pushgateway | 2.1.6 |
| cert-manager | 1.12.3 |
| rancher-istio | 102.2.0-up1.17.2 |
| rancher-logging | 102.0.1-up3.17.10 |
| rancher-logging-crd | 102.0.1-up3.17.10 |
| rancher-monitoring-crd | 102.0.1-up40.1.2 |
| rancher-gatekeeper-crd | 102.1.0-up3.12.0 |
| rancher-gatekeeper | 100.2.0-up3.8.1 |
| rancher-monitoring | 102.0.1-up40.1.2 |
| longhorn | 1.4.3 |
| longhorn-crd | 1.1.100 |
| reloader | 0.0.129 |
| csi-driver-smb | 1.8.0 |
| velero | 3.1.6 |
| redis-operator | 7.2.4-7 |
| redis-cluster | 7.2.4-64 |
Migration tool version
The migration tool version you need depends on the standalone products you plan to migrate and the targeted Automation Suite version. For more details, see Migration compatibility matrix.
For instructions on migrating a standalone product to the current version of Automation Suite, see Full migration.
- Out-of-support RHEL versions
- Registry hydration improvements
- Bug fixes
- Known issues
- FIPS 140-2 support limitations
- Upgrade failure due to overridden Insights PVC sizes
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Node maintenance issue in non-HA Redis
- Unnecessary Redis DNS resolution validations during Active/Passive checks
- Insights annotation issue blocks installer
- Unintended RKE2 service upgrade on additional nodes
- AI Center skills sync failure during side-by-side upgrade
- Test Automation SQL connection string is ignored
- Installation fails while populating node labels
- Cannot upgrade due to failed jobs in system-upgrade namespace
- Weak ciphers in TLS 1.2
- Upgrades fail due to Longhorn being uninstalled
- Unnecessary ListBucket API prerequisite check fails for external objectstore
- Cannot enable SSO for ArgoCD
- Migration from in-cluster objectstore to external objectstore fails
- Components fail when using external object storage with proxy environment
- Issue with saving custom configurations in email settings
- Network policies in Airflow may cause improper functioning of DNS
- Issues related to CephMgrIsAbsent alerts
- Error message while uninstalling rook-ceph post migrating to a S3 object-store
- Issues affecting Ceph metrics and alerts
- Collation differences between SQL server and SQL database not supported
- Upgrade fails due to MongoDB to SQL Server migration
- Installation failure when adding new products to existing Automation Suite
- Kerberos keytab rotation does not trigger token regeneration
- Orchestrator does not start when using user-assigned managed identity
- Thanos compactor stops on corrupted blocks
- Agent node addition failure in offline environments
- Installation fails due to CA certificates with large policy OIDs
- Licensing SQL connection error
- Grafana dashboard error
- uipathctl health check command
- Kubernetes upgrade failure
- Document Understanding deployment issue post-upgrade
- Incomplete Docker registry cleanup process
- Kube-proxy health check not working
- Kerberos tickets do not automatically renew
- AI Center storage migration failure
- Email alerts configuration failure post upgrade
- Upgrade failure due to default organization initialization
- Deprecation timeline
- Bundling details
- Product versions
- Internal third-party component versions
- Migration tool version
