  • Automation Suite on Linux Release Notes
    • 2023.10.0
    • 2023.10.1
      • 2023.10.3+patch1
      • 2023.10.3+patch2
      • 2023.10.3+patch3
    • 2023.10.5
    • 2023.10.6
    • 2023.10.8
    • 2023.10.9
    • 2023.10.10
    • 2023.10.11
  • Automation Suite on EKS/AKS Release Notes
Automation Suite release notes
2023.10.3+patch1
Release date: June 6, 2024
About this patch
Erratum - added August 8, 2024: The bug fix related to document validation tasks in Action Center was not included in the Automation Suite 2023.10.4 release. We recommend that you wait for Automation Suite 2023.10.5 to get this fix.
This release applies a patch to Automation Suite 2023.10.3. The patch addresses an issue preventing some document validation tasks from being displayed accurately in Action Center. For more details, see the individual product release notes referenced in the Product versions section.
How to apply the patch
To apply this patch, follow the instructions in Applying a patch.
Deprecation timeline
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details
Product versions
To find out what has changed on each Automation Suite product, visit the following links.
If the product is greyed out, this new Automation Suite version does not bring any changes to it.
DISCOVERBUILDMANAGEENGAGE
Automation Hub 2023.10.3Automation Ops 2023.10.3AI Center 2023.10.3Action Center 2023.10.3-patch1
Task Mining 2023.10.3AI Computer Vision 2023.10.2Insights 2023.10.3Apps 2023.10.3
Process Mining 2023.10.3Document Understanding 2023.10.3Orchestrator 2023.10.4-patch1
Test Manager 2023.10.3
Data Service 2023.10.3
Internal third-party component versions
This Automation Suite release bundles the following internal components:
ComponentVersion
RKE21.26.11
ArgoCD2.7.7
logging-operator4.1.0
logging-operator-logging4.1.0
gatekeeper3.12.0
rook-ceph1.9.4
prometheus-pushgateway2.1.6
cert-manager1.12.3
rancher-istio102.2.0-up1.17.2
rancher-logging102.0.1-up3.17.10
rancher-logging-crd102.0.1-up3.17.10
rancher-monitoring-crd102.0.1-up40.1.2
rancher-gatekeeper-crd102.1.0-up3.12.0
rancher-gatekeeper100.2.0-up3.8.1
rancher-monitoring102.0.1-up40.1.2
longhorn1.4.3
longhorn-crd1.1.100
reloader0.0.129
csi-driver-smb1.10.0
velero3.1.6
redis-operator7.4.2-54
redis-cluster7.4.2-2
  • About this patch
  • How to apply the patch
  • Deprecation timeline
  • Bundling details
  • Product versions
  • Internal third-party component versions
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
