Automation Suite release notes
  • Automation Suite on Linux Release Notes
    • 2023.10.0
    • 2023.10.1
    • 2023.10.5
    • 2023.10.6
    • 2023.10.8
    • 2023.10.9
    • 2023.10.10
    • 2023.10.11
  • Automation Suite on EKS/AKS Release Notes
2023.10.8
2023.10.8 release notes for Automation Suite on EKS/AKS.
Release date: March 17, 2025
Removed dependency for single tenant migration​
To simplify the migration process, you are no longer required to install.NET Core Desktop Runtime for 64-bit (x64) systems on your machine to run the Automation Cloud Migration Tool for a single tenant.
Release date: February 13, 2025
What's new​
This Automation Suite version brings various small bug fixes and improvements.
Bug fixes​
  • An issue was preventing Fluentd from sending logs to remote locations due to a lack of memory buffer. We have fixed the issue.
  • An issue prevented the inclusion of Insights dashboards in backups. We have fixed the issue.
Known issues​
FIPS 140-2 support limitations​
Erratum - added January 22, 2026: Insights is not supported on Automation Suite deployments that run on FIPS 140-2-enabled machines. To remain compliant with FIPS 140-2 requirements, you must disable Insights.
For details, refer to Security and compliance.
Log streaming does not work in proxy setups​
Erratum - added June 26, 2025: Log forwarding does not work in proxy setups because the proxy environment variables were not set in the logging pods. To address the issue, refer to the Troubleshooting section.
We fixed the issue in Automation Suite 2023.10.10.
Licensing SQL connection error​
Erratum - added June 26, 2025: Licensing SQL connection errors occur when the Data Source property specified both a named instance and a port.
Microsoft SQL Server 2016 exception​
Erratum - added April 15, 2025: An issue related to AI Center causes Microsoft SQL Server 2016 to throw the following exception: exception":"com.microsoft.sqlserver.jdbc.SQLServerException: 'OPTIMIZE_FOR_SEQUENTIAL_KEY' is not a recognized CREATE INDEX.
We fixed the issue in Automation Suite 2023.10.9.
Deprecation timeline​
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details​
Product versions​
To find out what has changed on each Automation Suite product, visit the following links.
If the product is greyed out, this new Automation Suite version does not bring any changes to it.
DISCOVERBUILDMANAGEENGAGE
Automation Hub 2023.10.8Automation Ops 2023.10.7AI Center 2023.10.8Action Center 2023.10.8
Task Mining 2023.10.8AI Computer Vision 2023.10.8Insights 2023.10.8Apps 2023.10.8
Process Mining 2023.10.8Document Understanding 2023.10.8Orchestrator 2023.10.9
Test Manager 2023.10.8
Data Service 2023.10.8
Internal third-party component versions​
For the Kubernetes versions that each Automation Suite version supports, see Kubernetes compatibility.
This Automation Suite release bundles the following internal components:
ComponentVersion
Istio1.23.0
ArgoCD2.13.3
Prometheus3.1.0
Grafana11.3.1
Fluentd & Fluent-bitlogging-operator: 5.0.1
logging-operator-logging: 5.0.1
Gatekeeper3.18.2
Cert-Manager1.16.2
Velero8.0.0
Migration tool version​
The migration tool version you need depends on the standalone products you plan to migrate and the targeted Automation Suite version. For more details, see Migration compatibility matrix.
For instructions on migrating a standalone product to the current version of Automation Suite, see Full migration.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
