Automation Suite release notes
  • Automation Suite on Linux Release Notes
    • 2023.10.0
    • 2023.10.1
    • 2023.10.5
    • 2023.10.6
    • 2023.10.8
    • 2023.10.9
    • 2023.10.10
    • 2023.10.11
  • Automation Suite on EKS/AKS Release Notes
2023.10.12
2023.10.12 release notes for Automation Suite on Linux.
Release date: March 25, 2026
Support for new RHEL version​
We have expanded our OS support to include RHEL 9.7. For details on the supported RHEL versions, refer to RHEL compatibility matrix.
Release date: November 6, 2025
This release brings security updates to address CVE-2025-55315.
Known issues​
FIPS 140-2 support limitations​
Erratum - added January 22, 2026: Insights is not supported on Automation Suite deployments that run on FIPS 140-2-enabled machines. To remain compliant with FIPS 140-2 requirements, you must disable Insights.
For details, refer to Security and compliance.
Deprecation timeline​
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details​
Product versions​
The following table outlines the release status, version, and release notes for all UiPath products deployed under Automation Suite 2023.10.12.
Legend:
✅ New: This Automation Suite version includes a new product version. New release notes are available.
◆ Bundled: This flavor includes a previously released product version. No new release notes are available.
ProductVersionRelease notes
Action Center✅ New: 2023.10.12Action Center release notes
AI Center✅ New: 2023.10.12AI Center release notes
AI Computer Vision◆ Bundled: N/AN/A
Apps◆ Bundled: N/AN/A
Automation Hub◆ Bundled: N/AN/A
Automation Ops◆ Bundled: N/AN/A
Data Service✅ New: 2023.10.12Data Service release notes
Document Understanding✅ New: 2023.10.12Document Understanding release notes
Insights✅ New: 2023.10.12Insights release notes
Orchestrator✅ New: 2023.10.13Orchestrator release notes
Process Mining✅ New: 2023.10.12Process Mining release notes
Task Mining✅ New: 2023.10.12Task Mining release notes
Test Manager✅ New: 2023.10.12Test Manager release notes
Internal third-party component versions​
This Automation Suite release bundles the following internal components:
ComponentVersion
RKE21.33.2+rke2r1
ArgoCDv3.0.11
Grafana12.0.2
ceph19.2.3
rook-ceph1.17.6
prometheus-pushgatewayv3.4.1
cert-managerv1.18.2
rancher-istio105.4.0-up1.23.2
rancher-monitoring-crd106.1.2-up69.8.2-rancher.7
rancher-gatekeeper104.0.1-up3.13.0
rancher-monitoring106.1.2-up69.8.2-rancher.7
longhorn1.9.1
longhorn-crd1.1.100
reloaderv2.2.0
kube-logging/logging-operator6.0.1
kube-logging/config-reloader6.0.1
velero1.16.1
csi-driver-smbv1.18.0
redis-operatorv7.22.0-15
redis-clusterv7.22.0-216.focal
oauth2-proxyv7.11.0
Connect
Stay updated
