Automation Suite release notes
  • Automation Suite on Linux Release Notes
    • 2023.10.0
    • 2023.10.1
    • 2023.10.5
    • 2023.10.6
    • 2023.10.8
    • 2023.10.9
    • 2023.10.10
    • 2023.10.11
  • Automation Suite on EKS/AKS Release Notes
2023.10.10
2023.10.10 release notes for Automation Suite on EKS/AKS.
Release date: June 26, 2025
What's new​
This Automation Suite version brings various small bug fixes and improvements.
Bug fixes​
  • Log forwarding did not work in proxy setups because the proxy environment variables were not set in the logging pods. We have fixed the issue.
  • Licensing SQL connection errors occurred when the Data Source property specified both a named instance and a port. We have fixed the issue.
  • When Process Mining was enabled with the new Airflow image, which uses PostgreSQL, the Airflow installation failed in AWS (EKS) environments with S3 or Ceph storage types. We have fixed the issue.
Known issues​
FIPS 140-2 support limitations​
Erratum - added January 22, 2026: Insights is not supported on Automation Suite deployments that run on FIPS 140-2-enabled machines. To remain compliant with FIPS 140-2 requirements, you must disable Insights.
For details, refer to Security and compliance.
Deprecation timeline​
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details​
Product versions​
To find out what has changed on each Automation Suite product, visit the following links.
If the product is greyed out, this new Automation Suite version does not bring any changes to it.
DISCOVERBUILDMANAGEENGAGE
Automation Hub 2023.10.10Automation Ops 2023.10.10AI Center 2023.10.10Action Center 2023.10.10
Task Mining 2023.10.10AI Computer Vision 2023.10.10Insights 2023.10.10Apps 2023.10.10
Process Mining 2023.10.10Document Understanding 2023.10.10Orchestrator 2023.10.11
Test Manager 2023.10.10
Data Service 2023.10.10
Internal third-party component versions​
For the Kubernetes versions that each Automation Suite version supports, see Kubernetes compatibility.
This Automation Suite release bundles the following internal components:
ComponentVersion
Istio1.25.2
ArgoCD3.0.0
Prometheus3.3.0
Grafana11.6.1
Fluentd & Fluent-bitlogging-operator: 5.3.0
fluent/fluent-bit:4.0.1
Gatekeeper3.19.1
Cert-Manager1.17.2
Velero9.1.0
Migration tool version​
The migration tool version you need depends on the standalone products you plan to migrate and the targeted Automation Suite version. For more details, see Migration compatibility matrix.
For instructions on migrating a standalone product to the current version of Automation Suite, see Full migration.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
