Automation Suite release notes
  • Automation Suite on Linux Release Notes
    • 2023.10.0
    • 2023.10.1
      • 2023.10.2+patch2
      • 2023.10.2+patch3
      • 2023.10.2+patch4
      • 2023.10.2+patch5
    • 2023.10.5
    • 2023.10.6
    • 2023.10.8
    • 2023.10.9
    • 2023.10.10
    • 2023.10.11
  • Automation Suite on EKS/AKS Release Notes
2023.10.2+patch4
2023.10.2 Patch 4 release notes for Automation Suite on Linux.
Release date: May 21, 2025
About this patch​
This release applies a patch to Automation Suite 2023.10.2. The patch addresses a cache validation issue that was preventing you from immediately receiving permissions when granted the App Creator role in Apps. With this patch, the issue has been fixed.
Important:
This fix will also be included in all future releases starting with Automation Suite 2023.10.9.
How to apply the patch​
To apply this patch, follow the instructions in Applying a patch.
Deprecation timeline​
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details​
Internal third-party component versions​
This Automation Suite release bundles the following internal components:
ComponentVersion
RKE21.26.11
ArgoCD2.7.7
logging-operator4.1.0
logging-operator-logging4.1.0
gatekeeper3.12.0
rook-ceph1.9.4
prometheus-pushgateway2.1.6
cert-manager1.12.3
rancher-istio102.2.0-up1.17.2
rancher-logging102.0.1-up3.17.10
rancher-logging-crd102.0.1-up3.17.10
rancher-monitoring-crd102.0.1-up40.1.2
rancher-gatekeeper-crd102.1.0-up3.12.0
rancher-gatekeeper100.2.0-up3.8.1
rancher-monitoring102.0.1-up40.1.2
longhorn1.4.3
longhorn-crd1.1.100
reloader0.0.129
csi-driver-smb1.10.0
velero3.1.6
redis-operator7.2.4-7
redis-cluster7.2.4-64
  • About this patch​
  • How to apply the patch​
  • Deprecation timeline​
  • Bundling details​
  • Internal third-party component versions​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
