- Automation Suite on Linux Release Notes
- Automation Suite on EKS/AKS Release Notes
Automation Suite release notes
Release date: October 17, 2024
We have expanded our OS support to include RHEL 9.6. For details on the supported RHEL versions, see Compatibility Matrix.
Release date: September 24, 2025
We now support Instance Metadata Service Version 2 (IMDSv2) in high-availability deployments for AWS. For more information on IMDSv2, see the AWS documentation.
We have implemented a new kube-proxy check in the Node Monitor. If kube-proxy becomes functionally unavailable due to issues such as an iptable flush, the Node Monitor will cordon the node. Once kube-proxy functions correctly again, the node will be uncordoned.
We made the following improvements to the migration workflows:
When moving the Identity data of your tenants from standalone Orchestrator to Automation Suite, the tenant name in Automation Suite is now the same as the original tenant name in standalone Orchestrator. Previously, the Automation Suite tenant name was automatically generated in the
tenant_xxxxxxxxformat, wherexxxxxxxxsignified the first eight characters of the Automation Suite organization ID. For more information, see Step 1: Moving the Identity organization data from standalone to Automation Suite -
We updated our documentation of the migration steps to clarify that you have the option to migrate multiple standalone product tenants to either a single Automation Suite organization or multiple Automation Suite organizations. For more information, see Step 1: Moving the Identity organization data from standalone to Automation Suite and Step 4: Merging organizations in Automation Suite.
We are thrilled to announce an enhancement in our Fully Qualified Domain Name (FQDN) update process. Now, you can update the cluster FQDN from a single machine, replacing the previous multi-step procedure. This update is aimed at simplifying the process, making it more user-friendly and efficient.
For more on the FQDN update process, see Configuring the FQDN post-installation.
- Erratum - added May 21, 2025: For offline Automation Suite installations using the external docker registry, the uipathctl health check command did not work in Automation Suite versions 2023.10.0 to 2023.10.5 due to a known issue. This issue has been fixed.
If you resized the
rook-cephOSD PV, the new size did not persist following an Automation Suite upgrade. Now, the upgrade automatically inherits and retains the updatedrook-cephOSD PV size. -
We fixed an issue where the installation or upgrade failed on AWS machines where only IMDSv2 was enabled.
We have fixed an issue causing Automation Suite upgrades to fail due to the presence of failed jobs in the
system-upgradenamespace. -
In a proxy environment, if the proxy server used the same port as the TCP port of any other service in the Istio service mesh, such as port 8080, pods could not communicate with the FQDN, and an error message was displayed. The behavior no longer occurs.Note: If you previously created a service entry according to the workaround in Pods cannot communicate with FQDN in a proxy environment, we recommend that you delete the service entry after you upgrade to Automation Suite 2023.10.6 or later. To delete the service entry, use the following command:
kubectl delete serviceentry proxy -n uipathkubectl delete serviceentry proxy -n uipath -
We have fixed a
uipathctl-related issue that caused registry configuration corruption during upgrades. Previously, a port in the helm URL ofcluster_config.jsonwas treated as an external registry, leading to an omission inregistries.yaml. Now,insecure_skip_verify: trueis correctly included inregistries.yaml, regardless of whether or not a port is present in the helm URL. -
We fixed several bugs that caused issues during setup when AI Center was connected to an external Orchestrator and Identity Service, in the following situations:
During the installation of Orchestrator certificates for trusted communication.
When setting up an Identity Service client for Document Manager.
When configuring an Identity Service client for metering services.
We have fixed an issue where shutting down the
rke2-serverservice without executingrke2-killall.shcould lead to intermittent not ready reports from agent machines. -
We have fixed an issue that caused problems during the upgrade process if you had resized the Docker-registry PVC used by your in-cluster Docker registry. Now, the new size is accurately recognized and considered during the upgrade process.
We have fixed an issue causing Redis recovery job failures when the ArgoCD admin password gets updated in the UI without also updating the Kubernetes secrets. The fix includes special handling for this scenario. We recommend to update the Kubernetes secrets at the same time when you update the ArgoCD admin password in the UI to avoid any other unexpected issues. For more details on how to properly update the ArgoCD admin password, refer to Troubleshooting.
Kerberos keytab rotation does not trigger token regeneration
Erratum - added September 24, 2025: An issue causes Kerberos keytab rotation to not immediately regenerate authentication tokens, which may lead to temporary connectivity disruptions between services and the database.
To address the issue, you must manually trigger the Kerberos ticket renewal cronjob by running the following command:
kubectl delete job tgt-rotate-manual -n uipath --ignore-not-found ; kubectl create job tgt-rotate-manual --from=cronjob/kerberos-tgt-update -n uipathkubectl delete job tgt-rotate-manual -n uipath --ignore-not-found ; kubectl create job tgt-rotate-manual --from=cronjob/kerberos-tgt-update -n uipath
We fixed the issue in Automation Suite 2023.10.11.
GPU enablement fails with external registries containing project names
ImagePullBackoff error.
If you are using an external registry with a project name, update the NVIDIA device plugin daemonset with the following command:
# Replace REGISTRY_WITH_PROJECT_NAME with the correct value (Eg. my.registry.io:443/myproject)
# Replcae TAG with the correct value. You can get this from the <installer_directory>/versions/docker-images.json file (Eg. v0.17.1)
kubectl set image daemonset/nvidia-device-plugin-daemonset \
-n kube-system \
nvidia-device-plugin-ctr=<REGISTRY_WITH_PROJECT_NAME>/k8s-device-plugin:<TAG># Replace REGISTRY_WITH_PROJECT_NAME with the correct value (Eg. my.registry.io:443/myproject)
-n kube-system \
nvidia-device-plugin-ctr=<REGISTRY_WITH_PROJECT_NAME>/k8s-device-plugin:<TAG>We fixed the issue in Automation Suite 2023.10.11.
Orchestrator does not start when using user-assigned managed identity
storage.useClientID parameter from being set when you select a user-assigned managed identity for object storage. As a result, tOrchestrator
cannot start in environments where access is restricted to user-assigned managed identities.
To address the issue, you must manually set the parameter in ArgoCD, as follows:
- In the ArgoCD Orchestrator application, go to Details > Parameters.
- In the values text box, set
storage.isExternal : trueand save.
Thanos compactor stops on corrupted blocks
Erratum - added September 24, 2025: An issue causes the Thanos compactor to stop compacting metrics when it encounters corrupted blocks in the object store. This prevents compaction and leads to increased storage usage.
To address the issue, refer to the Troubleshooting section.
Task Mining Kerberos initialization failure
kerberos-discoverygroup-user-keytab secret is missing or when the discoverygroup app is not included in the enabledApps parameter of the IntegratedAuth app.
We fixed the issue in Automation Suite 2023.10.10.
Agent node addition failure in offline environments
Erratum - added June 26, 2025: An issue causes the addition process of agent nodes in offline environments to fail. Agent node additions require the temporary registry to be running. To address the issue, you must re-enable the temporary registry to successfully join the agent node.
Installation fails due to CA certificates with large policy OIDs
CertificatePolicies section with policy OID values exceeding 4 bytes. This issue prevents Automation Suite from recognizing these CA certificates,
interrupting the installation process.
CertificatePolicies section do not exceed 4 bytes, or avoid using CA generators that add the CertificatePolicies section to the certificates.
RKE2 custom configuration overwrite during upgrade
/etc/rancher/rke2/config.yaml) to be overwritten during upgrades.
To address the issue, you must reapply your custom changes to the configuration file after each upgrade.
Licensing SQL connection error
Erratum - added June 26, 2025: Licensing SQL connection errors occur when the Data Source property specified both a named instance and a port.
Grafana dashboard error
Dashboard not found and
Invalid dashboard UID in the request appear in the Grafana
dashboard.
Modify the helm parameter for the
fabric-installerapplication. This automatically triggers the sync operation forfabric-installerapplication.kubectl patch application fabric-installer -n argocd --type='json' -p='[{"op": "add", "path": "/spec/source/helm/parameters/-", "value": {"name": "global.rancherMonitoring.grafana.replicas", "value": "1"}}]'kubectl patch application fabric-installer -n argocd --type='json' -p='[{"op": "add", "path": "/spec/source/helm/parameters/-", "value": {"name": "global.rancherMonitoring.grafana.replicas", "value": "1"}}]' - Sync the
rancher-monitoringapplication from ArgoCD UI.
We have fixed this issue in Automation Suite 2023.10.7.
Kubernetes upgrade failure
certificate-injector-webhook in deployment.apps. To address the issue, you must run the following command:
kubectl delete configmap -n uipath-infra certificate-injector-webhook-configmap --ignore-not-foundkubectl delete configmap -n uipath-infra certificate-injector-webhook-configmap --ignore-not-foundWe fixed the issue in Automation Suite 2023.10.9.
Document Understanding deployment issue post-upgrade
du-digitizer-worker deployment from the old Automation Suite version not being fully cleaned up after the upgrade. Starting with Automation Suite
2023.10.0, the deployment was renamed to du-digitizer-worker-deployment.
documentunderstanding application, manually delete the old du-digitizer-worker deployment. After deletion, re-sync the documentunderstanding application.
We fixed the issue in Automation Suite 2023.10.8.
Incomplete Docker registry cleanup process
Erratum - added April 15, 2025: An issue prevents the registry cleanup command from effectively clearing the unused Docker images from all registry pods. To address the issue, refer to the Troubleshooting section.
Upgrade fails due to MongoDB to SQL Server migration
Erratum - added April 15, 2025: We have identified an issue impacting the side-by-side and the in-place upgrade of Automation Suite 2022.10 or earlier to Automation Suite 2023.10.0 or later. Due to a faulty migration from MongoDB to SQL Server, the upgrade operation fails if you have Apps enabled and use Kerberos authentication for the SQL Server database.
The recommended solution is to upgrade to Automation Suite 2023.10.9.
Kube-proxy health check not working
node-monitor component, which monitors the node for issues such as checking kube-proxy health or if ip_forward is enabled, and cordons the node if issues arise, is not working for specific nodes such as GPU, task-mining, or as-robot. We have fixed this issue in Automation Suite 2023.10.9.
Kerberos tickets do not automatically renew
Erratum - added April 15, 2025: Kerberos tickets fail to automatically renew after cluster restoration, requiring manual sync of the Windows Auth app.
This issue is fixed in Automation Suite 2023.10.9.
AI Center storage migration failure
uipathctl from correctly setting executeMigration to true during the migration process from Ceph in-cluster storage to external object storage in AI Center.
executeMigration to true in ArgoCD for AI Center and then proceed with a resync, ensuring to prune. This issue is fixed in Automation Suite 2023.10.8.
Email alerts configuration failure post upgrade
Erratum - added February 13, 2025: An issue affects the functionality of email alerts configuration and the setup of multiple receivers after upgrading from Automation Suite 2022.10. To address this issue, see Troubleshooting.
FQDN update failure
update_fqdn parameter to not being properly set in the service-cluster-configurations secret.
update_fqdn and update_fqdn_state parameters and update the service-cluster-configurations secret using the following command:
kubectl patch secret service-cluster-configurations -n uipath-infra --type=json -p='[
{"op": "remove", "path": "/data/UPDATE_FQDN"},
{"op": "remove", "path": "/data/UPDATE_FQDN_STATE"}
]'kubectl patch secret service-cluster-configurations -n uipath-infra --type=json -p='[
]'This issue is fixed in Automation Suite 2023.10.8.
Side-by-side upgrade failure when Apps is enabled
business-apps/ba-migration-k8-utils image.
business-apps/ba-migration-k8-utils image in the versions.json file from 2023.10.4 to 2023.10.6 before running the migration command.
We fixed the issue in Automation Suite 2023.10.7.
Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
Erratum - added December 18, 2024: Following an Automation Suite upgrade from version 2023.4 or older, reinstalling or upgrading Insights results in data loss due to an issue with Insights storage class changes. To address the problem, see Troubleshooting.
Node maintenance issue in non-HA Redis
redis-cluster-0 pod to get stuck in the terminating state when you perform a node drain in non-HA Redis scenarios. To address the problem,
you must force delete the pod using the following command:
kubectl -n redis-system delete pod redis-cluster-0 --forcekubectl -n redis-system delete pod redis-cluster-0 --forceWe fixed the issue in Automation Suite 2023.10.7.
Insights annotation issue blocks installer
Erratum - added December 18, 2024: An Insights annotation issue blocks the Automation Suite installer. We fixed the issue in Automation Suite 2023.10.7.
RKE2 log collector runs indefinitely
Erratum - added December 18, 2024: The RKE2 log collector runs indefinitely for some system commands. We fixed the issue in Automation Suite 2023.10.7.
Upgrade failure due to overridden Insights PVC sizes
Erratum - added December 18, 2024: An issue causes upgrades to fail when the existing Insights PVC sizes are inadvertently overridden. To address this problem, you must manually change the PVC sizes in ArgoCD UI. For details, see the Troubleshooting section.
This issue is fixed in Automation Suite 2023.10.7.
AI Center skills sync failure during side-by-side upgrade
aicenter skill sync and aicenter skill status commands during a side-by-side upgrade.
To fix this issue, you must manually edit the syntax. For details, see the Troubleshooting section.
Unnecessary Redis DNS resolution validations during Active/Passive checks
redis.<primary-fqdn> and redis-db.<primary-fqdn> during Active/Passive prerequisite checks. This issue is fixed in Automation Suite 2023.10.7.
Unintended RKE2 service upgrade on additional nodes
exclude= rke2-* is not added to the /etc/yum.conf file on nodes other than the first server. In specific environments, particularly online ones, an attempt to upgrade all
components can cause an unintentional upgrade of the RKE2 service on nodes other than the first server.
exclude=rke2-* to the /etc/yum.conf file on all the nodes of your Automation Suite cluster.
Test Automation SQL connection string is ignored
orchestrator.testautomation section of the
cluster_config.json file, the uipathctl binary
ignores the connection string and uses the one under the orchestrator
section instead. To address the problem, see the Troubleshooting section.
Longhorn REST API endpoint upgrade/reinstall error
Failed to set Longhorn RestApi Endpoint error when you upgrade (reinstall) the cluster from a version earlier than Automation Suite 23.10.0.
To fix the issue, see the Troubleshooting section.
Enabling Connaisseur causes installation or upgrade failures
registries.trust.enabled parameter to true in the cluster_config.json file.
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Product versions
To find out what has changed on each Automation Suite product, visit the following links.
If the product is greyed out, this new Automation Suite version does not bring any changes to it.
| DISCOVER | BUILD | MANAGE | ENGAGE |
Automation Ops 2023.10.5 | AI Center 2023.10.6 | Action Center 2023.10.6 | |
| Task Mining 2023.10.6 | AI Computer Vision 2023.10.6 | Insights 2023.10.6 | Apps 2023.10.6 |
| Document Understanding 2023.10.6 | Orchestrator 2023.10.7 | ||
| Test Manager 2023.10.6 | |||
Internal third-party component versions
This Automation Suite release bundles the following internal components:
Component |
Version |
RKE2 |
1.30.5 |
ArgoCD |
2.11.3 |
| gatekeeper |
3.16.0 |
rook-ceph |
1.14.6 |
| prometheus-pushgateway |
2.12.0 |
cert-manager |
1.14.5 |
rancher-istio |
104.4.0-up1.22.1 |
| rancher-logging |
103.0.0-up3.17.10 |
| rancher-logging-crd |
103.0.0-up3.17.10 |
| rancher-monitoring-crd |
104.1.0-up57.0.3 |
| rancher-gatekeeper-crd |
103.1.0-up3.13.0 |
| rancher-gatekeeper |
103.1.0-up3.13.0 |
| rancher-monitoring |
104.1.0-up57.0.3 |
longhorn |
1.6.2 |
longhorn-crd |
1.1.100 |
reloader |
1.0.95 |
csi-driver-smb |
1.16.0 |
velero |
6.2.0 |
redis-operator |
7.4.6-2 |
redis-cluster |
7.4.6-22 |
Migration tool version
The migration tool version you need depends on the standalone products you plan to migrate and the targeted Automation Suite version. For more details, see Migration compatibility matrix.
For instructions on migrating a standalone product to the current version of Automation Suite, see Full migration.
- Support for new RHEL version
- New RHEL version supported
- Instance Metadata Service Version 2 support
- New kube-proxy check
- Improved migration to Automation Suite
- FQDN update enhancement
- Bug fixes
- Known issues
- Kerberos keytab rotation does not trigger token regeneration
- GPU enablement fails with external registries containing project names
- Orchestrator does not start when using user-assigned managed identity
- Thanos compactor stops on corrupted blocks
- Task Mining Kerberos initialization failure
- Agent node addition failure in offline environments
- Installation fails due to CA certificates with large policy OIDs
- RKE2 custom configuration overwrite during upgrade
- Licensing SQL connection error
- Grafana dashboard error
- Kubernetes upgrade failure
- Document Understanding deployment issue post-upgrade
- Incomplete Docker registry cleanup process
- Upgrade fails due to MongoDB to SQL Server migration
- Kube-proxy health check not working
- Kerberos tickets do not automatically renew
- AI Center storage migration failure
- Email alerts configuration failure post upgrade
- FQDN update failure
- Side-by-side upgrade failure when Apps is enabled
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Node maintenance issue in non-HA Redis
- Insights annotation issue blocks installer
- RKE2 log collector runs indefinitely
- Upgrade failure due to overridden Insights PVC sizes
- AI Center skills sync failure during side-by-side upgrade
- Unnecessary Redis DNS resolution validations during Active/Passive checks
- Unintended RKE2 service upgrade on additional nodes
- Test Automation SQL connection string is ignored
- Longhorn REST API endpoint upgrade/reinstall error
- Enabling Connaisseur causes installation or upgrade failures
- Deprecation timeline
- Bundling details
- Product versions
- Internal third-party component versions
- Migration tool version
