- Automation Suite on Linux Release Notes
- Automation Suite on EKS/AKS Release Notes
2023.10.11
2023.10.11 release notes for Automation Suite on Linux.
Release date: March 25, 2026
Support for new RHEL version
We have expanded our OS support to include RHEL 9.7. For details on the supported RHEL versions, refer to RHEL compatibility matrix.
Release date: September 24, 2025
AI Units usage metrics available in support bundle tool
The Automation Suite support bundle tool now collects AI Units usage metrics if you use AI Center.
New RHEL version supported
We have expanded our OS support to include RHEL 9.6. For details on the supported RHEL versions, see Compatibility Matrix.
Bug fixes
- We have fixed an issue that prevented log forwarding when using S3 endpoints in non-AWS format (that is, without
.amazonaws.comin the URL), as the endpoint was not in the format expected by Fluentd. - We have fixed an issue causing a delay in Kerberos keytab rotation, which prevented immediate regeneration of authentication tokens and occasionally disrupted database connectivity for services.
- An issue prevented the required pods from being created when enabling GPU after adding a GPU node. This issue occurred only when using external registries with project names ( such as Harbor). We have fixed the issue.
- An issue prevented the installer from setting the
storage.useClientIDparameter when you selected a user-assigned managed identity for object storage. As a result, Orchestrator did not use your configured client ID, and in environments where access was restricted to user-assigned managed identities, Orchestrator could not start. We have fixed the issue. - We have fixed an issue that prevented garbage collection from running during in-cluster registry cleanup.
- An issue caused the Thanos compactor to stop metrics block compaction in the object store due to a race condition in Prometheus. This led to increased storage usage in the Ceph bucket. We have fixed the issue.
- We have fixed an issue in Document Understanding where document imports could fail with Primary key violation errors caused by duplicate sequential IDs in SQL Server. Now, multi-page document imports complete reliably.
Known issues
FIPS 140-2 support limitations
Erratum - added January 22, 2026: Insights is not supported on Automation Suite deployments that run on FIPS 140-2-enabled machines. To remain compliant with FIPS 140-2 requirements, you must disable Insights.
For details, refer to Security and compliance.
Deprecation timeline
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details
Product versions
The following table outlines the release status, version, and release notes for all UiPath products deployed under Automation Suite 2023.10.11.
Legend:
✅ New: This Automation Suite version includes a new product version. New release notes are available.
◆ Bundled: This flavor includes a previously released product version. No new release notes are available.
| Product | Version | Release notes |
| Action Center | ✅ New: 2023.10.11 | Action Center release notes |
| AI Center | ✅ New: 2023.10.11 | AI Center release notes |
| AI Computer Vision | ◆ Bundled: N/A | N/A |
| Apps | ✅ New: 2023.10.11 | Apps release notes |
| Automation Hub | ✅ New: 2023.10.11 | Automation Hub release notes |
| Automation Ops | ◆ Bundled: N/A | N/A |
| Data Service | ✅ New: 2023.10.11 | Data Service release notes |
| Document Understanding | ✅ New: 2023.10.11 | Document Understanding release notes |
| Insights | ✅ New: 2023.10.11 | Insights release notes |
| Orchestrator | ✅ New: 2023.10.12 | Orchestrator release notes |
| Process Mining | ✅ New: 2023.10.11 | Process Mining release notes |
| Task Mining | ✅ New: 2023.10.11 | Task Mining release notes |
| Test Manager | ✅ New: 2023.10.11 | Test Manager release notes |
Internal third-party component versions
This Automation Suite release bundles the following internal components:
| Component | Version |
| RKE2 | 1.33.2+rke2r1 |
| ArgoCD | v3.0.11 |
| Grafana | 12.0.2 |
| ceph | 19.2.3 |
| rook-ceph | 1.17.6 |
| prometheus-pushgateway | v3.4.1 |
| cert-manager | v1.18.2 |
| rancher-istio | 105.4.0-up1.23.2 |
| rancher-monitoring-crd | 106.1.2-up69.8.2-rancher.7 |
| rancher-gatekeeper | 104.0.1-up3.13.0 |
| rancher-monitoring | 106.1.2-up69.8.2-rancher.7 |
| longhorn | 1.9.1 |
| longhorn-crd | 1.1.100 |
| reloader | v2.2.0 |
| kube-logging/logging-operator | 6.0.1 |
| kube-logging/config-reloader | 6.0.1 |
| velero | 1.16.1 |
| csi-driver-smb | v1.18.0 |
| redis-operator | v7.22.0-15 |
| redis-cluster | v7.22.0-216.focal |
| oauth2-proxy | v7.11.0 |
Migration tool version
The migration tool version you need depends on the standalone products you plan to migrate and the targeted Automation Suite version. For more details, see Migration compatibility matrix.
For instructions on migrating a standalone product to the current version of Automation Suite, see Full migration.
